Old 10-19-2012, 10:27 AM
cuorealfa1 cuorealfa1 is offline
Mein Auto: 5er GT 535d
Originally Posted by marcosg View Post
I also found that you can enable the Fuel Consumption Histogram without changing the VO or Production date by coding the following:
HI_CIC - 3000 HMI - ECO_MODE = aktiv (Displays Efficient Dynamic Menu in CIC Nav menu)
KOMBI - 3003 FZG - VERBER_HISTOIRE_ENABLE = aktiv (Enables fuel consumption histogram)
KOMBI - 3004 ERM - CTR_HSTY_DISP_KI_APPL = aktiv (Enables fuel consumption histogram)
i just coded this... the consumption history is available..
also i can select the Efficient Dynamics Picture in the SplitScreen.
but is it possible to activate the full ECO Pro Modus? So that it act with ECO Pro.. for the air conditioning and all other ECO Pro stuff?
2010 BMW 535d GT
Old 10-19-2012, 10:31 AM
shawnsheridan's Avatar
Mein Auto: 2011 535i M-Sport
Have you tried adding 4U2 to your VO and coding the car as I describe above?
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11)
- BMWCCA #446923
- flick
Old 10-19-2012, 02:43 PM
did you have success with this? is it working for you?
I'm not sure if it will work because my F07 is from 05/2010...
is there any additional Hardware for the ECO Pro Mode?
2010 BMW 535d GT
Old 10-19-2012, 05:30 PM
As I wrote here in Post # 3, I was about 90% successful
http://www.bimmerfest.com/forums/sho...57&postcount=3
I have everything working except I can not get the DEC Switch to go into the ECO PRO Mode. I still do not know why. I am not aware of any required hardware, so I am puzzled for now.
- BMWCCA #446923
- flick
Old 10-20-2012, 03:30 PM
So you have also the Eco pro things showing up in the Kombi? Like in the pictures attached?
I have read on German Site about the Settings that:
The Sport+ is available just if you have DDC, due to the fact that you can configure the Things in the Sport (non +). And in the + you can deactivate the driving help things also incl. the sport transmission and Sport suspension.
With Eco Pro the:
"Normal" changed to "Comfort"
"Comfort" changed to "Comfort+"
And ECO PRO is New
The appereance of the different modes are in JBBF or IHKA as i know.
ID:	346585   Click image for larger version
2010 BMW 535d GT
Old 10-20-2012, 05:24 PM
With Eco Pro the:
And ECO PRO is New
No, I don't have those, but I assume that is because I cannot get my DEC switch to go into the ECO PRO mode.
My Normal mode changed to Comfort (works fine).
My Comfort changed to Comfort+ (works fine).
ECO PRO was added (can't engage it).
I don't know why ECO PRO won't enage.
Name:	4U2 Added.jpg
- BMWCCA #446923
- flick
Old 10-21-2012, 02:37 AM
shawn
did you have the Sport + before?
I think this things should be in the KOMBI ECU.
2010 BMW 535d GT
Old 10-21-2012, 05:34 AM
shawn
Yes, and I still have Sport+. You can't see it in the picture, as I have to scroll up the DEC list as it is the first one.
- BMWCCA #446923
- flick
Old 10-21-2012, 05:47 AM
for your problem....
could you check what value you have here:
HU_CIC / ECO_FDS_POPUP / ??
2010 BMW 535d GT
Old 10-21-2012, 05:54 AM
It shows nicht_aktiv. The CIC though is VO coded for 4U2 with a 0712 Production Date. In theory, every parameter required for 4U2, including the above, should be set as needed.
- BMWCCA #446923
- flick
Old 10-21-2012, 10:10 PM
chinese_food chinese_food is offline
Mein Auto: F10
I truly believe that the solution is hardware. There is no way to change from comfort to eco from the iDrive. We need the switches that would be on the center console.
I drove a 535 loaner and the only way I could change the modes were from the switches next to the gear shifter.
To make this happen, we need the switches and need to know how to retrofit them.
Old 10-21-2012, 11:07 PM
Changing modes from iDrive? I don't know where you got that from, but I have the switch, on the center console, next to my gear shifter.
From my Post # 3:
My DEC Switch now shows Comfort+ and ECO PRO modes in addition to Normal, Comfort, Sport, and Sport+. I can select Comfort+, but for some reason I still can not select ECO Pro.
And from my Post # 56:
...I cannot get my DEC switch to go into the ECO PRO mode.
So, as previously stated, I have the DEC (Driving Experience Control) Switch, and I can change from Sport+, to Sport, to Comfort, and to Comfort+. I just can't get it to engage the ECO PRO Mode.
- BMWCCA #446923
- flick
Old 01-03-2013, 12:40 PM
ad2k ad2k is offline
Mein Auto: F07
hi, I have 10/2011 F07 without EcoPro enabled (4U2) and i coded the car (HI_CIC - 3000 HMI - ECO_MODE = aktiv (Displays Efficient Dynamic Menu in CIC Nav menu, KOMBI - 3003 FZG - VERBER_HISTOIRE_ENABLE = aktiv, KOMBI - 3004 ERM - CTR_HSTY_DISP_KI_APPL = aktiv) and have nice histogram - thanks for that.
yet have some unexpected issues:
1. with DEC switch I still have sport+/sport/comfort/comfort+ - no Eco Pro displayed
2. I have neither EfficientDynamic Info nor EcoTips displays
any clues to make me happier than I am after enableing EcoPro histogram?
regards
ID:	355780   Click image for larger version
ID:	355781   Click image for larger version
ID:	355782   Click image for larger version
Old 01-03-2013, 01:12 PM
regards
So, it is identical to my results, except my DEC Switch now has ECO Pro, but it can't be selected.
I don't know.
- BMWCCA #446923
- flick
Old 01-03-2013, 01:49 PM
Mein Auto: F07
if it helps someone in investigation, my car spec is:
223
229
255
2b2
2va
302
316
322
323
3ag
402
423
430
431
441
455
456
488
494
496
4cb
4ur
4uy
502
508
522
524
534
5ac
5ad
5ag
5df
601
609
610
612
614
615
616
620
633
676
6aa
6ab
6fh
6fl
6nf
6nr
6vc
7rs
7sp
8th
and N57 engine (3.0d), xdrive, build 10/2011, ilevel F001-11-09-501 (if remember correctly)
Old 01-03-2013, 04:59 PM
Mein Auto: F07
just wonder if EcoPro mode visible (sth Shawn has and I don't) and EcoPro switchable by DEC is written in KOMBI/300C ECO_FDS
I have only FDS_MENUE_TEXT_1 to ..._4 active and ..._5 says Werte=0F while "ECO" should have "06" and "ECO+" should have "07"
Also FDS_MENUE_SIGNAL_5 is "0F" (kein text/reserve) while "modus ECO" is "07"
I have to gain a little more confidence with coding to change in my car but maybe there are brave ones around here
Please note that "06" (SIGNAL) stands for "modus RACE"
Old 01-03-2013, 05:56 PM
What is the Production Date of your Vehicle, and what Production Date did you use in your FA w/ 4U2 added to do your coding with?
- BMWCCA #446923
- flick
Old 01-03-2013, 06:01 PM
Mein Auto: F07
production date is 13.10.2011
I did not change FA, and no 4U2 added. Just changing FDL. I am a little bit affraid of changing FA/VO at the moment
Old 01-03-2013, 06:06 PM
The features you are missing (and the whole purpose of this thread) was because until a VO with 4U2 and a Production Date of 0312 was used, those features would not appear with any FDL Coding I did.
- BMWCCA #446923
- flick
Old 01-03-2013, 06:12 PM
Mein Auto: F07
ok, thought that marcosg's idea with changing 3 parameters is 'better' option that VO+4U2
i am going to search forum for instruction 'how to back up and restore oryginal VO before scheduled BMW Service visit' I would not like to left big fingerprints on my car electronics
Old 01-03-2013, 06:16 PM
I am not saying to write modified VO to the car. Just modify it, save it to PC, then use it for coding only, but don't write it to the car.
- BMWCCA #446923
- flick
Old 01-03-2013, 06:23 PM
Mein Auto: F07
well it seems it is to late for me...
you mean I should code HU_CIC and KOMBI under modified but not programmed (to the car) VO?
how 'car' would know that my 'new' HU_CIC+KOMBI are now for 4U2 equipped car?
anyhow - I try to do it when I wake up
Old 01-03-2013, 06:39 PM
Yes, that is what I mean. When you VO Code, it takes whatever VO (FA) you have activated in E-Sys, and codes the entire module(s) to support those options as they were for that production period as defined in the VO.
Once the modules are coded, the car uses them as coded. It does not compare their as coded state to the VO stored in the car, and automatically recode them based on the cars VO so that they match.
If you already modified your VO and wrote it to your car, all you need to do is change the VO back to the original (remove 4U2, and set original production date), and write that one to the car.
- BMWCCA #446923
- flick
Old 01-04-2013, 12:47 AM
Mein Auto: F07
hello again,
i'm not sure if i did it correctly but have a .xml file with added 4u2 and build date changed to 03.2012
i can activate FA so it seems to be ok
i can code modules (did it with kombi and hu_cic)
but... nothing changed - i still have neither ED Info/ EcoPro Tips nor EcoPro or EcoPro+ selection with DEC switch...
how can I determine if new coding data are 'signed' including 4u2 and 03.2012?
does coding 'flash' module or just adds changed data (I had kombi/hu_cic changed before new VO/FA preparation)...
there is also no 2-items engine oil level in vehicle status menu
any clues?
Old 01-04-2013, 06:34 AM
hello again,
any clues?
Yes, your VO Production Date Change looks correct.
I VO coded KOMBI, IHKA, JBBF, and HU_CIC. Try also VO coding IHKA and JBBF.
I do not understand you question regarding "signed".
Coding does not flash a module, it just reconfigures its programming using its existing firmware.
In 0312, the oil measurement system chnaged. Since you are using an 0312 production date, when you VO coded HU_CIC it changed OELSTAND_OENS = aktiv. FDL Code this back to nicht_aktiv, and your Oil Measurement screen will be fixed.
- BMWCCA #446923
- flick
