High Battery Drain - Solved! - Bimmerfest - BMW Forums
Old 07-17-2010, 10:48 PM
ghs235 ghs235 is offline
Desi
Mein Auto: 07 550i SMG, 09 MB ML550
Thumbs up High Battery Drain - Solved!
I have seen a lot of threads on "High Battery Drain" fault message but none really put a finger on what is causing this issue. Hence, this thread.
In my case, the fault for High Battery Drain is being caused by "defective passenger front door comfort access tag handle carrier". The dealership performed a test, determined the cause, replaced the part and I never got that fault message again. Problem solved! After doing my research in several forums, I believe that there might be other parts that may cause this issue for other people.
Please read below for more detailed information:
Background:
Bought my 2007 550i during Fall of 2009. The first time this message popped up was 2-3 weeks after I bought the car. Since then the message started showing up every 2-4 weeks regard less of how many ever miles driven just hours before a message. So I took it to the dealership and they kept the car for a couple of days to run tests and finally figured it out.
Below is the word-to-word description that is reported in my invoice provided by the dealership. I don't understand everything from their report but I am sure if you guys have any questions, the experts on this forum will be able to clarify.
Customer states the battery is weak, customer sees fault for High Battery Drain, check and advise.
Cause: E
0000555 Check Faults on DIS
308 WBC
1068 WBC
1 51-21-7-191-590 Carrier, Outside Door Handle: 512099TV
6120503 Closed Circuit Test On Battery
308 WBC
6120505 Checking Battery W/ Tester
308 WBC
6100006 Performing Energy Diag
1068 WBC
5121625 Repl Outside Door Handle Carrier
308 WBC
FC: 51210079UW
Part # 51-21-7-191-590
Count: 1
Followed test for energy diagnosis. Energy diagnosis determined number one cause of battery drain to be high closed circuit current draw. Charged car battery. Performed battery test. Battery test good. OK. Performed closed circuit current draw test. Confirmed intermittant closed circuit draw in excess of 80 milliamps. Determined current draw coming from defective passenger front door comfort access tag handle carrier. Replaced passender front door comfort access tag handle carrier. Rechecked closed circuit measurement. OK.
whew...
Old 07-18-2010, 10:57 AM
MSAMMY MSAMMY is offline
2007 550i & X3, 2002 X5
Mein Auto: BMW 550i, X5, X3
Wow, that dealer is a keeper! Battery drain problems are extremely difficult to diagnose and very time consuming. Sounds like your dealer really went the extra mile to resolve for you!
2007 550i, Sport Premium, Silver Gray Metallic, Gray Dakota, Navigation, Cold Weather Package, Comfort Access, Heated Rear Seats, HD Radio, Xenon
2007 X3, 3.0si ///M Sport Premium, Monaco Blue, Gray Dakota, Navigation, Cold Weather Package, Xenon
2002 X5, 3.0i Sport Premium, Titanium Silver, Gray Dakota, Cold Weather Package, Xenon, just a winter vehicle
Old 07-18-2010, 08:06 PM
Desi
Yep. That dealer had been good to me so far. I had him work on a few other stuff on my car since its still under CPO warranty.
Old 09-01-2010, 07:29 PM
MachtSchnell's Avatar
MachtSchnell MachtSchnell is offline
Mein Auto: 2008 535
Wonder how many people you just helped? Nice Job.
Schwarz | Premium | Sport | Nav | Sat | Paddles | PDC | Lead Foot | Hardwired Passport 9500ix w/ Escort Live | Convenience | Matte Grill | JB4 | DCI | ALP Jammers w/BT | smoked side markers | Specdock | rear spoiler | AutoWerke BOV | BMS Oil Catch Can | R1 Cross Drilled Rotors w/ Hawk HPS pads |
Old 09-01-2010, 09:18 PM
ressan ressan is offline
Mein Auto: 535xi
I had the same problem. And I had the same solution. The dealership said that my drivers side CA door handle would constantly " wake my car up while it was trying to sleep". I guess everybody needs their beauty rest
2008 BMW 535xi : Black Sapphire Metallic / Grey Leather Interior, Automatic Transmission, Premium, Sport, Cold Weather, Comfort Access, H.U.D., Navigation System, PDC, Rear Sunshade Package, Folding Rear Seats, Rear Side Impact Air Bags, iPod/USB Adapter, Sirius Satellite Radio.
Current Mods/Add-Ons : 3M Clear Bra , Front Illuminated Door Sills, Dinan Stage II, 19" Staggered M3 replicas.
Old 04-25-2012, 03:16 PM
louisrai louisrai is offline
Mein Auto: 2008 535i E60
Talking about waking it up.....when I sit the my E60, and turn everything off, every few minutes, the CD starts to roll and I can hear some equipments start to run...is this normal?
Is that like the car detects you sitting in the seat, so turn on some equipments? Or this should not happen?
Thank you.
Old 04-25-2012, 04:31 PM
Mein Auto: 2008 535
I hear my nav cd spinning up when I get in the car.
Old 04-25-2012, 04:32 PM
I suppose that is normal. But when I am sitting in the car, they would just spin up every couple minutes...constantly.
Old 07-04-2012, 08:26 AM
mcsigler mcsigler is offline
Mein Auto: 2009 528i
I was told by my SA that if the key is close to the car, the car will never go to sleep. That's why you would hear some things being active. She said she's had numerous issues where the owner puts the car in the garage but does not take the key with them (either leaving the key in the car or placing it close by). Since my 528 is parked outside, me leaving the key close by is not an issue.
Old 07-04-2012, 09:37 AM
Thanks. But how close is close? What if the car is parked just outside the bedroom window?
Old 07-04-2012, 10:45 AM
burnie35's Avatar
burnie35 burnie35 is offline
Old Timer (Really)
Mein Auto: 2009 BMW 535i Sport
I think I' m glad I didn't pay extra for "comfort access".
2017 X5 35 M-Sport, Carbon Black, Black
2009 535i Sport, Jet Black | Cobb Stage 2 Aggressive | Injen DCI | AR Downpipes | BMS Led Angel Eyes | Michelin Pilot Sport A/S Plus
2008 528i (Retired)
2006 328ci (Retired)
1975 US Army (Retired)
Old 09-12-2012, 06:18 PM
Anilkumarbn Anilkumarbn is offline
Mein Auto: 528XI
My car is currently at service center for 3rd time (open road BMW - Edsion NJ) for same issue "HIGH BATTERY DRAIN". I purchased CPO from same place on 5/27/2012.
1st time battery and terminal wiring changed, same issue next day, back to service 2nd time replaced rain sensor, drawing high current (200ma) again same issue. Return to service center on 9/10. After two days today received a call from SA, they could not figure out asked permission for technician to take home and do drive test.
I have mentioned all fixes details in this forum... is there any suggestions... please.... thanks...
Old 09-13-2012, 12:17 PM
Gilgorm Gilgorm is offline
Mein Auto: 2012 535i X-drive
My 2008 535i had three problems when I got it in 2009.
Entire Comfort Access module, not just individual door handles.
Electronic Gear shift.
After market Boomerang/Lo-Jack system from previous owner.
Problem finally solved.
2012 BMW 535i X-drive; Space Grey/Black Dakota, Fineline; Executive (Auto trunk, NAV, HiFi Prof, Lumbar, Rear Cam, SIRIUS, Voice), Technology (Blind Spot, Hi-Beam Assist, Lane Departure, Surround View), APPS, Rear heated seats, Tint.
Retired: 78 300D, 81 300SD, 87 190E, 88 Porsche 924, 89 260E, 93 300E, 97 Volvo 850, 98 E320, 03 BMW 325iT, 02 C230 Sport Coupe, 08 BMW 535i
Old 09-14-2012, 09:34 PM
Mein Auto: 528XI
Recieved call from SA still could not rectify, started indirectly telling me that I am leaving cell phone chargers. Though I repeatedly mention no charger connected... On above blaming its only happening when I am driving, its not happening in service center or when technician took overnight to his home for test.. Now they will keep over the weekend and check monday morning and if they dontbsee any ask pick the car..
BTW: I have submitted formal complaint to BMW customer relations dept.. Seems it sounded BMW will not be providing any help.
I love driving 'Ultimate Driving Machine' but it is causing 'ultimate headache, pain and unsafe' problems.....
Sent from my SCH-I500 using Bimmer App
Old 09-21-2012, 01:18 PM
SoCaLE39 SoCaLE39 is offline
Mein Auto: E60 M5, E46 325i
If you have high battery drain while driving its probably a good chance the alternator is on its way out.
Old 09-21-2012, 02:25 PM
phlfly's Avatar
phlfly phlfly is offline
Mein Auto: 07' 550i
I think door handle is common problem as I saw many replaced it.
BMW CCA Member, Capital Chapter
Old 10-20-2012, 02:08 PM
Mein Auto: 528XI
SA drove my car and parked in my driveway and picked next day for diagnosis, no issue found. Drove the car back on same day 9/17 evening this time parked the car in my garage. Came back next day noticed Same issue high battery drain message, he took it back got it diagnosed for Z-wave Radio Frequency interference triggering making car system come awake from sleep mode, mentioned possible cause from Verizon FIOS power supply installed in garage, and suggested to move to different location, and they cannot help anymore. I tried one day shielding with metal foil and grounded, no help, next I tried totally unplugged, next day same issue. I did researched on internet and checked regarding Z- wave frequency which are in range 900 to 910 Mhz. I do not have any home automation that uses Z-wave. One of my friend suggested to park the car backing in into the garage, and it did worked with no High Battery Drain Message. I cannot change my garage construction layout and cannot park backwards always. Specially its tough for my wife.....
Old 10-20-2012, 02:17 PM
phlfly's Avatar
Mein Auto: 07' 550i
Call Verizon and ask them to move it will cost you 100 bucks or so.
Old 10-20-2012, 02:30 PM
w5lx's Avatar
w5lx w5lx is offline
Mein Auto: 2008 528i/2007 328i Coupe
I think it's a BMW problem, not a Verizon problem. There are lots of Verizon subscribers out there and I've haven't' seen another post on any BMW forum where Verizon was causing a problem waking up a car because of RF emissions. I think your BMW dealer was passing the buck.
Old 10-23-2012, 06:01 AM
bimmerzone's Avatar
bimmerzone bimmerzone is offline
Supporting Vendor
Mein Auto: E63 650i, F13 M6
its so annoying, and keeps spinning as I drive mine too... hate it especially when stopped at lights, I just removed the disc since i don't use nav much
| Bimmerzone.com | 1-800-357-7797 | info@bimmerzone.com | 831 Lincoln Ave, Suite 3, West Chester PA 19380 |
Video about Bimmerzone: http://www.youtube.com/watch?v=me5pjPS88Bw
We are proud to be Authorized Dealers for: Sprint Booster, Peake Research, Eisenmann Exhaust, Hartge, RPI Exhaust, AutoEnginuity, Bentley Publishers, Zymol, P21S, PowerFlex USA, Brembo GT, KW, Hawk and much more!!
Old 10-23-2012, 09:47 AM
Maini Maini is offline
Mein Auto: 2010 BMW 535xi
If you are still under warranty and have the older white battery Lead Acid.. ask them to change to the AGM and do the upgrade of computers and register. They did all this on my car for free. These cars need AGM battery.. the Lead Acid is no longer an option and BMW is replacing the battery to AGM for any issues seen. I got this done for free
2010 535i xDrive AUTO
PDC, NAV, HUD, HD & SAT Radio, Premium Audio
Premium, Sport & Value Packages
Black Dakota Leather
Old 12-31-2014, 11:24 AM
jacrex1 jacrex1 is offline
Mein Auto: 1994 BMW 525i sportwagon
I have a 1994 525i sport wagon, changed the water pump and started noticing the battery was draining when lights were used at night , with radio on etc. Charged it up ,checked the belt tensioner , was good for a few days , started happening more often !
leaving the trickle charger on all night seemed to work and it would be fully charged until driving . ABS warning would come on first, then transmission , and so on . its a high miler (190k)
I replaced the battery as they were telling me it was "going out" at a couple places , still goes down while driving so I will have the alternator checked and take it from there !
let you know what happens .
last year had to repair power wire from the battery for not starting or cranking .
this year blower stopped working except on high .
its getting to the perpetual problems stage
1994 525i sport wagon @ 190K
Old 11-05-2015, 12:02 PM
Gadamsm5 Gadamsm5 is offline
Mein Auto: M5 e60
Battery drain and failure m5 e60
Help needed when I bought the car he fitted new battery, couple days later boom battery discharge but would always start would come on every morning, now over the last 3 weeks ish iv drove it 3 times at night lights on heater on seats heater on radio on, an after 10minns of driving battery completely dead, mechanic said alternator was ok just thinking its not an pulling charge over night and screwed under load, what do we think
Old 11-05-2015, 12:24 PM
w5lx's Avatar
Originally Posted by Gadamsm5 View Post
what do we think
That is one LONG sentence........
Old 11-20-2015, 07:56 PM
bobbyq bobbyq is offline
Mein Auto: bmw 530i
i wonder if this "door handle ajar also makes sense?"
2002 E-39, i started having these battery drain the last couple of days/weeks now and its frustrating.
1. my wife left passenger front door half ajar, after 5 hours parked, when we returned it will not start. battery drained not enough power to start, but lights/sensor working, it was at this point that i kind of concluded because door ajar light warning on.
jumped started , soon as we arrived home , charged battery using my home charger.
ever since , my car will run for 3 days, then battery is drained again not enough to start. go to the same cycle again by charging/trickle charging etc.
2. i finally went to O'Riely auto supply, they tried to diagnose: results= battery still good, alternator = passed. Granting battery is good, alternator is ok
what next step should i diagnose?
there is an orange triangle light ! warning on , but this had been on quiet awhile which i have been ignoring.....
waiting for ur opinion if its the right time to bring to dealer? which i hate because where i live, reviews are bad because of over charging folks ....
hoping to get some tips!
thank you in advance
Bobby
south san francisco
comfort access, fault message, high battery drain, passenger door handle
