The X5 SAV Forum
Old 09-18-2012, 04:32 PM
RNDx5 RNDx5 is offline
!!! SILVER SURFER !!!
Mein Auto: 01 530i
Exclamation 4.4 x5 navi /dsp UPGRADE
did my homework ! on this factory navi with dsp bulls***.. im into loud systems and fancy headunits
so im installing my pioneer 8400 double din tv.
purchased the double din kit off ebay. $30 with the new style flat pinned harness
*mind you 01 x5 has the old style round pin harness
with the help of google i found a site
they sell a harness that takes your old round pin harness and converts it at the other end to the flat pinned harness. *saves your a hassle since there is no harness for the x5 with the dsp system
upfront the navi is just for display the actual radio of the x5 is near the spare tire in the rear; meaning you have to unplug the radio and from that harness run about 12 feet of wires from the rear to the front 8 for the speakers 1 for power 1 for ground 1 for remote and 1 for the antenna
to top it all off . im removing that side bracket that holds the navi cd rom and the 6 disc changer and ill install a nice small 4 channel amp in there
seems like a hassle but pretty much straight forward if your handy with electronics
below are pics of the harnesses
picture on the left is the harness for 175$ that converts the old to new harness
ID:	342428   Click image for larger version
Old 10-23-2012, 04:34 PM
cslee cslee is offline
Mein Auto: X5
RNDX5,
Can you share in more detail what you did? I am thinking of replacing the in-dash head unit (control-panel) with after market navi.. but keep the DSP AMP. I wonder if the output of the after market navi can be fed to the harness after unplugging from the radio module. And then connect the "on" white wire athe DSP amp to the head unit. I'm getting conflicting info from various forums. Can you share the links to places where you bought your harneses?
C Lee
