Old 10-19-2012, 06:17 PM
shawnsheridan's Avatar
Mein Auto: 2011 535i M-Sport
Originally Posted by mateforrest View Post
This is my current I-step:
F010-12-03-500
Also as you can see in the next post i can active bmw live, but know the system try connect correctly but after a time says that internet start page is not available, try later.
Thanks.
yes you are right, my car doesn't has this entries:
Section 3000
- HUD_ENTERTAINMENT_ENABLE to aktiv (enables radio menu)
- HUD_TELEFONANRUF_ENABLE to aktiv (enables recent calls list to be displayed)
So now you have BMW Live working too. I guess we are done.
As for the "internet start page is not available", that is NOT your car or coding, that is BMW's Portal. Sometimes it's unavailable. Not sure why though.
F010-12-03-500 = ISTA/P 2.46.0, so you need the car updated or at the minimum KOMBI flashed with 47.x firmware.
Old 10-20-2012, 01:53 AM
mateforrest mateforrest is offline
Mein Auto: BMW F16 3.0D & mini F54
Thanks Shawn we did it
Also i tried to use this code:
HI_CIC - 3000 HMI - ECO_MODE = aktiv (Displays Efficient Dynamic Menu in CIC Nav menu)
KOMBI - 3003 FZG - VERBER_HISTOIRE_ENABLE = aktiv (Enables fuel consumption histogram)
KOMBI - 3004 ERM - CTR_HSTY_DISP_KI_APPL = aktiv (Enables fuel consumption histogram)
But only the CIC fuel Consumption in the CIC Nav menu is working, the rest exist but is dummy.
I think as you said in another post that is better :add option 4U2 to your VO and write it to the car. Then you would VO Code KOMBI, HU_CIC, JBBF, and IHKA.
But im not sure how to change production data.
Regards
Old 10-20-2012, 06:19 AM
Regards
Read this as an example for how to change FA (VO) to add 4U2:
https://www.rapidshare.com/files/322...ries%20car.pdf
QUIT AFTER STEP 7. You do not need to, and should not, write this FA to the car. Just use it for VO Coding, but let the car store the original FA.
What it does not explain is how to also change your FA Production date. For that, you need to change the FA Zeitkriterium field. You can only use dates that coincide with an actual Integration Levels (e.g. 0311, 0711, 0911, 1211, 0312, 0712).
I am using 0712. If your car was built before 0312, and you use a >= 0312 Production Date, your Oil Level Measurement Screen will change an no longer work. To return it back to the original style, FDL Code OELSTAND_OENS = nicht_aktiv after VO Coding it.
Make sure you read both of these posts first:
http://www.bimmerfest.com/forums/sho...d.php?t=642231
http://www.bimmerfest.com/forums/sho...d.php?t=647622
Name:	FA (VO) - Option Codes - SALAPA-Element.png
ID:	346547   Click image for larger version
Name:	FA (VO) - Zeitkriterium - Production Date.png
Old 10-21-2012, 01:46 PM
Hello Shawn,
I just do everything but the car of Efficient dynamics doesn't has animation. Please take I look:
What do you think?
Could it be because my car is diesel?
Is possible that the 4U2 code is only for petrol engines?
Another code for diesel?
Regards
Old 10-21-2012, 01:59 PM
Hello Shawn,
Attachment 346724
Attachment 346725
Attachment 346726
Attachment 346728
What do you think?
Regards
No. 4U2 is good for all F10 4 and 6 Cylinder engines, petrol or diesel.
What VO Date did you use and what ECU's did you VO Code?
Old 10-21-2012, 02:32 PM
Jbba, ihka clima, cic and kombi
Vo date 09/11.
Also I finished after step seven as you advice me the vo coding, and when I connect esys and read now FA shows 09/11
What's unit is Jbba? Gear shift?
Regards
Old 10-21-2012, 02:43 PM
Vo date 09/11.
Regards
JBBF = Junction box electronics
Maybe VO Code these too:
GWS = Gear selection switch
EGS = Electronic Transmission Control Unit
DME = Digital Motor Electronics (Car CAN NOT be Running - Just Auxiliary Power)
I would use a VO Date of at least 0312, which means you will have to go back and FDL Code HU_CIC / OELSTAND_OENS = nicht_aktiv afterwards.
Old 10-23-2012, 05:36 PM
Shawn i think that it could be because my car has IHKA unit and also rear climate control unit
(i have the option of high 4 zone climate contro), what do you think?
Regards
Old 10-23-2012, 05:38 PM
Regards
No. Did you use a 0312 date like I said?
Old 11-02-2012, 06:46 PM
shapa shapa is offline
Mein Auto: BMW GT 535d
Guys, sorry for a dumb question.
I've got UK 2011 car with all options except 614 (Internet), it was simply not available to order in march 2011
The question is short. Is it possible to continue to use Assist services (most valuable is google "send to car") but to force browser to use BT tethering? Or the only way to enable browser is to lost all my assist services?
I've tried to enable "Internet" option but there is a message "Internet is not available in your country" (as this option is not enabled for my car VIN on the BMW servers)
Thank you!
Old 11-02-2012, 07:10 PM
Thank you!
BMW Assist and Internet via Bluetooth can not coexist. It is one or the other.
Old 11-02-2012, 07:13 PM
Ok, thank you.
The last question - as I've got all hardware, and the limitation is purely software (on the BMW side), Internet is available in the UK officially, is it possible to work-around "internet is not availible" somehow?
Or the only way is to fully switch to BT connection?
Old 11-02-2012, 07:32 PM
Ok, thank you.
I don't think so because Internet via the car SIM requires 614 and is a paid service via BMW Assist.
Old 11-02-2012, 07:34 PM
It is not a problem to pay, the issue is that officially the retrofitting of 614 is not possible (silly...)
It's a pity.
Old 11-02-2012, 07:50 PM
It's a pity.
You can easily add 614 to your VO and code your Combox and Head Unit. I just don't know if your VIN will be recognized by BMW Assist when you try and activate the service with them.
You can try though. I am curious to know myself.
Old 11-02-2012, 08:12 PM
614 option is added (I've got "Internet" menu available)...
I activated the Assist service before 614 was coded, it is possible that the information is stored somewhere?
Old 11-02-2012, 08:30 PM
I don't know. My fear is they check your VIN's factory VO, and say that they can't activate it.
I would just call them and tell them you have Internet Option 614, and would like to subscribe to Internet Services. At worst, they can just say they checked, and your car isn't capable, at which point I would then volunteer that you retrofitted 614, and the car has been properly programmed, and see if they will do it then. You have nothing to loose.
Old 11-16-2012, 02:29 AM
gumes gumes is offline
Mein Auto: E90 LCI 318d 10/2010
Hello, I have a E90 LCI 10/2010 with S606A NAVIGATIONSSYSTEM BUSINESS . Is it possible to run the Internet via Mobile Phone in Poland? I have only d-can cable and
I have experience in coding by ncs expert.
My options:
S612A BMW ASSIST BMW Assist
S615A ERWEITERTE BMW ONLINE INFORMATION
S616A BMW ONLINE
S633A HANDY VORB. BUSINESS/BLUETOOTH-SCH.
S698A AREA-CODE 2
S6AAA BMW TELESERVICES
S6ABA STEUERUNG TELESERVICES
S6VCA STEUERUNG COMBOX
S854A SPRACHVERSION FRANZOESISCH
S863A SERVICE KONTAKT-FLYER EUROPA
Now i Have only BMW Online and when i try to connect i see the message "Homepage unavailable"
Is this possible?
Old 11-16-2012, 02:41 AM
My options:
S612A
S615A
S616A
S633A
S698A
S6AAA
S6ABA
S6VCA
Is this possible?
You should be able too, but you will need to replace 633 with 644, and add 614, and then change your Combox VIN to one with factory 614 & 615. Add 6AL too if you want BMW Live.
Being in Poland won't matter, because once you change your Combox VIN, your car appears to be in the country of the donor VIN's country.
Old 11-16-2012, 03:04 AM
Enough the same coding, or I have to replace the module $633 to $644?
Old 11-16-2012, 03:15 AM
No, not the modules, just the Vehicle Order (FA), and then VO code the affected modules (HU_CIC and CMB_MEDIA).
Old 11-16-2012, 03:29 AM
Ok, thanks
In summary:
1. change vin with tool32 in CMEDIAR.prg
2. -$633
-$612
+$614
+$644
3. ONLINE_BROWSER = beide_aktiv
4. TELEMATIK_VIN = Coding_VIN
Such a procedure?
Old 11-16-2012, 03:51 AM
Ok, thanks
In summary:
2. -$633
-$612
+$614
+$644
Such a procedure?
I have not done this on Exx Chassis, but that is the jest of it.
Use Tool32 CMEDIA.prg, job C_FG_SCHREIBEN to change the VIN. I believe with this method you need the extra Checksum digit at the end.
+6AL also if you want BMW Live.
Coding as follows:
HU_CIC:
CONNECTED_DRIVE = aktiv
ONLINE_BROWSER_LIVE = aktiv (if also +6AL)
ONLINE_SERVICES = aktiv
ONLINE_SERVICES_GLS = aktiv
CMB_MEDIA:
SIM_ENABLED_MB = csim
DATACOMM_CSIM = aktiv
DUN_PROFILE = aktiv
Old 11-16-2012, 04:28 AM
Coding as follows:
HU_CIC:
CMB_MEDIA:
DUN_PROFILE = aktiv
I dont' have options : CONNECTED_DRIVE, DATACOMM_CSIM, DUN_PROFILE
my files:
http://ghosting.home.pl/mcic.txt
http://ghosting.home.pl/media.txt
Old 11-16-2012, 04:33 AM
my files:
You looked in both Combox and CIC?
Try it without them then.
