Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > E60 (2004 - 2010)
E60 (2004 - 2010)
BMW 5-Series (E60 chassis) was first seen in the Unites States in the fall of 2003 with a 2004 Model Year designation. The E60 is now available as a 528i, 528xi, 535i, 535xi, 550i and a 535xi sports wagon! -- View the E60 Wiki
Old 07-31-2012, 11:35 AM
racooper3 racooper3 is offline
BMW Master Wannabe
Mein Auto: 2005 BMW 545i
Originally Posted by lcompy View Post
The battery I bought has a 3 year free replacement warranty, so I think I'm covered.
Until they catch on and develop a tool to read battery program status to confirm BMW owners aren't registering battery and over/under charging them. Updating warranty to not inlude this sort of neglect.
Old 07-31-2012, 11:42 AM
BMW Master Wannabe
Originally Posted by itscoo2pyopants View Post
Is it really worth $100 for installation? 2 bolts right?
Actually 5 bolts/nuts, 2 terminals and the battery holder, and 2 for rollover bracket.
Old 07-31-2012, 08:28 PM
yrusrace yrusrace is offline
Mein Auto: 08 528i , 07 G35 6MT Coup
Originally Posted by sunny 2005 bmw View Post
I went to an independent shop. I forgot mention I put the battery in and didn’t get it registered till 3 days. The computer had a fault in it for battery needs to be registered
Hey I live in Ft. Meade MD. wher and whatr shop did you go to. Thanks
Old 08-01-2012, 06:53 AM
stevendc stevendc is offline
Mein Auto: 530xi
Battery Replacement, E60
The recommended method for battery replacement (without registration) is to keep power flowing to your E60 with jumper cables from another car attached to the terminals under the hood of your E60. You can then replace your battery without your car experiencing a loss of power.
While some have not had issues swapping out the old fashioned way, it's better to be safe than sorry.
Old 08-01-2012, 07:43 AM
legend700's Avatar
legend700 legend700 is offline
Mein Auto: 2008 535i
A pretty comprehensive "energy history" is stored in the DME for diagnostics, evaluation and use by control units.
2008 535i Monaco Blue
PP, SP, SAT w/paddles, AS, CA, L7,
NAV, PDC, Heated F Seats, SIRIUS,
iPod+Aux, Bamboo Anthracite Wood Trim,
Gray Dakota Leather
Old 08-01-2012, 07:54 AM
Mein Auto: 530xi
Wink Battery Replacement, E60
That may be true, but before I bought my 530, the dealer had installed an Interstate Battery.
Old 08-01-2012, 04:47 PM
osbimmerfest osbimmerfest is offline
Mein Auto: 2004 530i
to borderchris- i deeply apologize for missing your may 2012 response to my posting about draining the battery in my 04 530i in or around march 2012. you say it is impossible to leave the headlights on in E60s. this is what happened. the morning commute to work still needed the headlights on because of darkness at 7 am. i was rushing to get to my job and inadvertently left the car without turning the lights off. i did not hear the lights on alarm because of my hasty exit. when i finished work at 4 pm i noticed the headlights switch was still on. when i turn the ignition switch on it was very weak and luckily after a prolonged slow engine turning it picked up and was able to rev it up. i drove it at highway speed for 1/2 hour to recharge the battery plus i put it on battery tender for overnight charging. it has been fine since then. this is the same battery that was put on without registering 4 years ago. again sorry for the belated response.
Old 08-01-2012, 09:39 PM
vwvwvw vwvwvw is offline
Mein Auto: '08 X3, '08 535xiT (gone)
This so called intelligent charging system that needs battery registration.............no other cars need battery registration. Doesn't seem intelligent to me.
Old 08-02-2012, 05:21 AM
Mein Auto: 530xi
intelligent to the "bottom-line".........
Old 08-02-2012, 06:18 AM
legend700's Avatar
You can use any battery make, as long as the specs. are OK. There are Duralast, AutoCraft, and others that work perfectly.
Gray Dakota Leather
Old 08-02-2012, 10:21 PM
I really don't think this is a money making scheme on their part. It's just an overly complicated design with little upside.
Some people cite the "enormous power requirements" of the E60, yada yada yada...that's baloney. There's no reason an E60 would need more current from the battery than other cars. Even if it did require more current, that's nothing to be proud of- good designs don't need a lot of standby current.
Old 08-03-2012, 06:35 AM
HPIA4v2 HPIA4v2 is online now
Mein Auto: E53, E60, E92
this batt-thing is child's play compare to the new F30 (at least on 328i with 4-TT engine), at idle with foot on the brake and the steering wheel is straight the engine shuts off to reduce emission for Europe and US new EPA regulation. Then when you lift your foot off the brake and hit the gas the engine starts and off you go (well I assume the batt is good of course). You can turn it off but default is always on, what a feature huh.
Sometimes keeping an old BMW is worth the effort, IMHO.
Old 08-03-2012, 06:51 AM
Mein Auto: 530xi
my 2002 also drained battery power, even when it was parked; but previous older models I owned did not draw any power until the car was started. OBD and Condition Based Diagnostics are the future....... and alot of other car manufacturers are doing the same thing. Point of fact, they don't want us to work on our own cars.
But we will do it anyway. The Bentley Manuals for my 2006 5 Series are very good as a DIY reference point.
Old 10-23-2012, 12:13 PM
CROWNTRAGEDY CROWNTRAGEDY is offline
Mein Auto: 530i '06
Hi folks, I need your help. Hi! I have a 530i 2006. Got this Duralast H8-DLG with specs: CC 950, CCA 760, RC 100. I haven't installed it yet. Will this work fine? my oem battery specs is 12 v, 110 AH, 850 A, 205 RC, 850 CC..do i need to register this battery? A..or shall i go with Duralast H8-AGM..help will be appreciated.. Thanks guys!
Old 10-23-2012, 08:14 PM
jesimmons jesimmons is offline
Crown.... see my post here: http://www.bimmerfest.com/forums/sho...6&postcount=27
2008 535i Platinum Bronze | Black Dakota | Light Poplar | Steptronic | Premium | Multi-Contour | Logic7 | Sirius | iPod |
Old 01-09-2013, 10:15 AM
George Ab George Ab is offline
Mein Auto: 325i
I just changed my battery yesterday.
There are two issues you should be aware of registration and coding CAS correctly if battery is different capacity then recommended.
Registering is letting the computer controlling the charging profile that you have a new battery as the charging profile changes over time. Registering can be done by the dealer or yourself using Tools32.exe, INPA in older models, Easy-DIS and others. If you have INPA, then it takes less then five minutes to register your battery.
Coding is only required if you purchase a battery of different capacity then recommended. I read my CAS module and saw that my E90 had 90ah_agm so I purchased the same. This is so the charging profile matches the capacities of the battery. It is easier to replace with same battery as you do not have to recode and for the person down the road who replaces with the proper battery and does not check that you reprogrammed CAS it could cause a problem. If you replace your battery with a 70ah battery and your charging profile is for a 90ah AGM battery it will decrease the life of the battery. Coding with NCSExpert is a ten minute job if you know what you are doing. Else, buy the proper battery. I purchased a 90ah AGM battery for $150.
There are good tutorials on removing/replacing the battery, registering, and coding on the forums.
The settings available in CAS are:
KLASSE_BATTERIE
46ah
55ah
70ah
80ah
90ah
110ah
40ah_agm
60ah_agm
70ah_agm
80ah_agm
90ah_agm
Old 01-09-2013, 10:37 AM
jsimon7777 jsimon7777 is offline
Giant Robot
Mein Auto: Scion FR-S
I replaced my battery with a lead acid and didn't register it. No problems after 5k miles. I just pulled the old one, put in the new, and put some shims in to keep it from sliding around as it wasn't a perfect fit. Saved 500 off the dealer's price. Just saying.
2013 Scion FR-S
2007 550i Sport - GONE
2008 528i - GONE
"What are you going to replace your BMW with?"
"Another BMW, with a bigger engine!"
Old 01-09-2013, 04:55 PM
BMW Master Wannabe
+1 and Ditto too.
Old 01-10-2013, 05:05 AM
Mein Auto: 530xi
E60 Battery Replacement
Way to go!
Old 01-10-2013, 08:12 AM
nguyendot nguyendot is offline
Mein Auto: 2008 528i
^^I did this, except for the shims. The e60 seems to have two mount points for the battery retaining bolt so I just moved it to the smaller one. The replacement battery at Pep Boys fit and started correctly. Two months in no problems. I'll pay $100 every 3 years that it kills my battery instead of $500 to the dealer. What a rip.
