7 Series - E65 / E66 (2002 - 2008)
Discussion pertaining to the flagship BMW here. |
#51
To make it easier for you guys to understand if you have a 06 750 then you can add Aux if you Have a 745 then you need to buy a ask unit from 06 to 08
Thanks rookie
What's the best place to pick the cable up? |
#53
I do believe the link is posted on here somewhere.
my ask unit was manufactured in early 06 so it doesn't support the AUX function.
i bought an exact same ASK unit on ebay that was manufactured in 07 and will try it out this weekend. does anybody know if i need to do any type of programing to the new ASK unit or is it just plug and play? (my MMIGT already has the aux option turned on and i can see it in the entertainment menu) |
#55
1890
any one know what problem code 1890 on a 745i 2003
#56
I'm not sure why you would come into a topic about radio auxiliary
& ask a question about fault codes ??? here is your answer , & if you have any more questions the search feature is your friend , Or you can make your own topic . This topic has nothing to do with fault codes So please keep your questions out of this topic !!! P1890 trans control usually caused by low or unusual voltage , Also Speed change control linear solenoid valve failure & Transmission failure .
If you need a Custom 2013 DVD Navigation Map East or West for your E65 E66 PM me for price . Or if you Need an AUX Plug for your car hit me up |
#57
Ok i have missed any think
I have AUX showing in my MMI I have removed the ask and plugged the new cable in. I have changed the wiring on the plug to the correct pins. I have not sound out the aux. Also in the MMI I click on AUX and I still see my fm presets on middle screen. Could it be that my car is a 06 even thou it has a facelift the ask will not work. Any way to update the firmware on the ask? I have checked realoem and the same part number is from 03/05 so it should work unless its software. Last edited by bkc0508; 10-07-2012 at 01:44 PM. |
#58
Removed
#59
Ace you still on that bull****. Get over it or come to cali and deal with paper direct stop wasting space on our site. Ban this fool for keeping this **** going
![]() 04 745i 22s 6" lips l.e.d halos,parking lights,license lights.smoked headlights& tails. Acs roof spoiler,fiberglass box 2 10's. Split personality exhaust |
#60
I am deleting the thread
97 740i e38 - SOLD 02 745i e65 03 Montero Limited ![]() |
#61
This aux mod was out on a German site back in 2011.
You didn't come up with anything new acefx. Get over it
#62
Ace, I am happy you are on this site. I appreciate all of your efforts and you are if not THEE best, one of THEE best guys on here for info. We need to move on from here. Stopher, Im not sure if this whole thread needs deleting, maybe just the back and forth between Ace and Paper.
Nice to meet you! !
AUX items do not come out I was mounting as this video! ! no.2 red no.7blue no.8brown My car is Japanese model 05, E66 760Li (theater package unit MD) MD unit can not we do? ? ![]() HELP |
#64
Ok not sure what you mean "aux items not come out " Are you talking about the auxiliary Feature on Your MMI screen ??? You must code your MMI , the feature does Not show up just by adding the auxiliary plug . You can use NCS to add that feature to your MMI. Sent from my GT-N7000 using Bimmer App
#65
Thank you for your reply
I very helpful! ! Last edited by louis maeshiro; 10-16-2012 at 11:45 AM. |
#66
No prob happy to help out . When you use NCS you want to read Your MMI , then look for the line that Says Aux & set it to aktiv . Then write It back to the car . After that you should be all set. Sent from my GT-N7000 using Bimmer App
#67
Hey paper I have a 07 750 with the aux already if I want it to show up on my mmi screen I just have to code it with the NSC expert??
#68
If you already have the Aux plug ? But anyway your answer is yes , use NCS Expert to code it in your MMI . Sent from my GT-N7000 using Bimmer App
#69
Thank you!! Not sure either but I just bought the car a year ago and I haven't done any update to it i just order the cable and going to try it out hope it's easy to figure it out
#70
2006 model
Is this kit compatible with my 2006 760LI
I have trunk NAVI03 dvd changer on trunk 6 cd/mp3 changer at front 1 cd ask the aux option is not on my menu ( It will show it after you install the cable ) Thank you, your video is very good |
#71
No you also need to have your MMI coded So the auxiliary option shows up on the screen . Sent from my GT-N7000 using Bimmer App
#72
so if i have the aux jack in the armrest then i should be able to do this mod without any software update
If you have the auxiliary jack in your center console arm rest . Then there Is no need for this mod Since you already Have it !!! Sent from my GT-N7000 using Bimmer App
#74
Paper face-lifted my 2005, so I know he has the knowledge. Parts added up to about $1,200.00 to pull out my CD changer and install the iPod kit. Mine works great!!! I only say him because I had personal experience with his abilities.
I just finished soldering the aux cables to the radio tuner and it works just fine....
