E34 (1989 - 1995)
Old 10-25-2012, 11:57 AM
Banned
Mein Auto: car
Originally Posted by 1995i540 View Post
Wow some posters here should not give out suggestions if they do not know how the car works. Jesus, talk about online mechanics.
It would be better if you simply corrected the bad advice instead of merely criticising. Or at least, state the correction along with the rhetoric ! Jesus also talked about doing unto others as you would have them do unto you.
Old 10-25-2012, 12:08 PM
1995i540's Avatar
1995i540 1995i540 is offline
Founder @ Maintenr
Mein Auto: 1995 540I/6
It's too late for that, his issue would be diagnosed in 10 minutes by a good mechanic. People suggesting oxygen sensors for no start? What the hell?
///////////////////////////////////////////// E34 Addicts
Founder @ Maintenr. Take control of your vehicle maintenance.
Old 10-25-2012, 01:10 PM
Banned
Mein Auto: car
" Father, forgive them, for they know not what they do. "
Sorry my friend, it was just too tempting not to say that.
rgds,
Roberto
Old 10-28-2012, 09:45 AM
meb1970 meb1970 is offline
Mein Auto: 1994 E34 M60 540I
NEED HELP!!!! 1994 E34 540 Wont Start
SATURDAY 10/26/2012
Cleaned the MAF with CRC
Cleaned the Idle Control w/carb cleaner
Changed the fuel filters
Checked for leaks. Found a leak at the throttle body intake. Temporary fix using gasket sealer around around the mating surface.
Now car starts and idles better, but seems to be in "limp mode" ???
Car accelerates OK, but when I mash the gas, it doesn't throw me back like it used to. I can see the RPM's go up, but no power.
Codes: 1213 and 1221
Also the little triangle type warning light is on.
I get voltage at the MAF terminal from the harness that is correct, but I do not know how to check at the MAF..
Also, why are my resistance numbers at the Idle Air Control Valve higher than what the Bentley Manuals says they should be?
Old 10-28-2012, 09:46 AM
SATURDAY 10/26/2012
Old 10-28-2012, 04:00 PM
NEED HELP!!!! 1994 E34 540 Wont Start UPDATE !!!
SATURDAY 10/26/2012
540, e34, starting problem
