Performance
CAIs, SCs, differentials, SSKs, exhausts etc..... |
I can clean your fuel injectors. Just pay for shipping and the fluid
I'm thinking about offering a service for the guys/girls on some forums i enjoy. It's *Free Injector Cleaning and Testing. I've been working for Bosch than Volvo and BMW in Europe, but my love for those cars is pretty much gone and I've been a Mercedes Enthusiast for a while. I remember the difference a clean injector makes in the way the car runs and how often i used to see them in poor condition. In case you have a faulty injector, i have a bunch of spare ones (Mercedes and BMW cars of late 80s to late 90s) i kept through the years and could sell those at half the market price for used units. This is WHY: R3VLimited Forums - View Single Post - I can clean your fuel injectors. Just pay for shipping and the fluid Here's How I bring them back to life 1. Initial Visual Inspection - Check the injectors for signs of physical damage. 2. External Degrease Soak - Soak them in a degreaser solution 3.External cleaning - Brush off the loosened grime from the injectors 4: De-filtering - Remove the old filters in preparation for ultrasonic cleaning. 5. Ultrasonic cleaning - The Injectors are soaked in Degreaser and Left pulsating in the Ultrasound Bath 6. Purge the injectors - Install the injectors on the Fuel rail and spray into a container to ensure none of the fluid we use in the ultrasonic cleaner gets put into the calibration fluid. 7. Initial flow - Flow through the machine checking for spray pattern and any signs of malfunction. 8. Filter Basket installation - Install the new filter basket. 9. Reassemble - Using all new applicable parts (O-rings, spacers, pintle caps) I'm in Southern California by the way. About 1 hour from LA I can do 2 kits a day or 3-4 on a weekend. So the turnaround should be 24-48 hours So for a kit of 8 I spend 25$ + shipping about 6$ I use Odorless Degreaser @ 17$/gallon Repair Kit @ 1$/Injector. USPS Flat rate priority mail 6.10$ I'm not doing this as a business, i just like working on cars in my spare time. (But of course will take donations) You can include a set of filters and o-rings with the package if you have a specific brand you like. And I won't charge you the 1 $/Injector If you care to see how specific injectors were performing, you need to mark each of them with the Cylinder number and i will make sure i keep those numbers for your record. Please note you forum nickname on the package to help me keep track of communication This is a nice article on how to remove your injectors with pictures. Applicable for the E36 engines but process is similar on most of the cars Pelican Technical Article: BMW 3-Series E36 Injector Replacement Here's the process similar to what I do. (i have nothing to do with the company advertised in the video or the original uploader of that video) Last edited by MEPEH; 12-15-2012 at 10:06 PM. |
IN STOCK (will update the list as I sort them) In stock injectors will be sold at 10 $/piece. Cleaned and tested. With 12 months - unlimited mileage BMW 0 280 150 415 - Rated at 156 cc/min @3bar - 15.9 ohm 0 280 150 715 - Rated at 155 cc/min @3bar - 15.9 ohm 0 280 150 440 - Rated at 200 cc/min @3bar - 14.5 ohm 0 280 150 778 - Rated at 200 cc/min @3bar - 14.5 ohm 0 280 150 779 - Rated at 200 cc/min @3bar - 15.9 ohm 0 280 150 211 - Rated at 155 cc/min @3bar - 16.2 ohm 0 280 150 129 - Rated at 196 cc/min @3bar - 2.3 ohm 0 280 150 552 - Rated at 156 cc/min @3bar - 15.9 ohm 0 280 150 714 - Rated at 200 cc/min @3bar - 15.9 ohm 0 280 150 126 - Rated at 196 cc/min @3bar - 2.3 ohm Mercedes Benz 0 280 155 203- Rated at 206 cc/min @3bar - 14.25 ohm 0 280 155 207 0 280 155 209 - Rated at 206 cc/min @3bar - 14.25 ohm 0 280 155 217 - Rated at 206 cc/min @3bar - 14.25 ohm Other Lucas D3761FA - 318IC Lucas D3763FA/1747406 - M60 M62 V8 Enines Lucas D3165KA - JAGUAR XJR SUPERCHARGED Bosch 078 133 55IN - Audi Siemens 000 078 8323 - Mercedes M119 V8 =============================== I will buy your older injector @ 3 $/piece. If you buy the reconditioned ones from me Last edited by MEPEH; 11-20-2012 at 08:29 AM. |
You can find more activity and reviews about this service on r3vlimited forum
http://www.r3vlimited.com/board/showthread.php?t=266477 |
injector
So for a 2003 530I it would cost me how much for the job I have a set of injectors. Let me know
5$ per injector to service yours or 10$ to replace. (not sure if i have yours in stock though)
I am interested in a set for the s52 motor maybe the 24lb if I can use them with a reflash or just a replacement of the 21lb. Can you email me how to do this and what your suggestions would be. I'm putting a m50 manifold and bored out throttle body on and a possible bigger maf if I need to with the 24lb injectors. If you can help that would be great. I'm rebuilding a M3 after a bad PPI and so I want to do it right and get the mist out of the motor before boosting it. Thank you. My email is Bshriver29@gmail.com.
Sent from my HTC PH39100 using Bimmer App |
Sorry for the super late reply. Just found my notification
I don't have any in stock but you can send your for servicing. Now speaking of pounds ... that's too complicated. I assume it's 220cc/min and you want to upgrade to 250cc/min Don't have any in stock either. I know the m5 uses the 260cc/min and that would work for your application if you intend to boost the engine. At least I can confirm that the upgrade does make sense for you application and is in fact recommended. If you decide to upgrade, just check a big supplier, they normally have the tables with flowrates and you can pick up the part number for your use. Stay with the same manufacturer and you'll be good |
Do you have injectors for a 2000 E38 M62TU? Here's the Bosch part # 0280155823. Thanks.
BMW '00 740il w/196,xxx miles (his), DIY timing guides complete! M60 Manifold, BDC Throttle Body, Muffler delete BMW '02 530iA w/140,xxx miles (hers) BMW '09 R1200GS Adventure w/13,6XX Smiles
Anyone have MEPEH's contact info? I got one PM from him but he didn't give me any contact info.
PM sent on the other forum. Sorry about the delays
