Newb!!! QUESTIONS!!! - Bimmerfest - BMW Forums
E30 (1982 - 1993)
Old 10-24-2012, 09:01 AM
lowEYEguy420 lowEYEguy420 is offline
Mein Auto: 1993 325i
I just became a bmw owner. Found a nice clean 1993 325i for 2000 bucks. I have a few questions about a few minor things and one big problem.btw,check engine light has been on since it was purchased.
1. My rear taillight will not come on.ive replaced the bulbs and still nothing. I'm thinking it could be an electrical problem. "Brake light circuit" is what displays along with "tail light" or could it be the socket?
2. The second main this is the grinding noise when I stop.i checked the pads,they aren't worn down.im thinkin maybe struts or roters.
Old 10-24-2012, 01:01 PM
jhagar jhagar is offline
Mein Auto: 1987 BMW 325iC
Congrats on the find. If you haven't yet, pick up a Bentley manual. The troubleshooting sections may help you diagnose the first problem.
The second problem could be your rotors and it could also be your wheel bearings. Does it sound like it's coming from a particular wheel? Are you getting any shaking in the steering wheel while braking?
Old 10-24-2012, 04:14 PM
E30949/909 E30949/909 is offline
Mein Auto: 1990 325IC
For your tail lights check under the brake pedal. It has a lil button under the pedal an when you push the brakes it pushes the button. It's all black with a red circle on it. Might be the problem, sometimes have an issue with that also. Just realign it to stay there an you can pull the button out a lil so the pedal will hit it.
Old 10-24-2012, 06:17 PM
BMWFatherFigure's Avatar
Old School
Wires, joints and earths in the boot is where the problem is IMO.
Current:
E38 Parts Car
Previous:
Old 10-24-2012, 08:17 PM
Okay , Bentley manual . Check! Ill check the button under the brake first thing tmrw.
Old 10-24-2012, 08:19 PM
What are the earths in the boot? Is that ,the wires ,and the joints major fixes?
Old 10-24-2012, 08:31 PM
Old School
Earths are all over the car. Its how the electricity gets back to the battery (crudely speaking). If earths are bad globes are either dim or don't work.
Joints get oxide over time. Usually open them, spray with switch cleaner and connect and disconnect a few times to improve the contact. Also check for damage. Any problems PM me. All real easy 1 star skill level fix.
Current:
E38 Parts Car
Previous:
Old 10-24-2012, 08:40 PM
Okay thanx a lot. I do NOT work on cars , unfortunately, so ill be relaying this all to someone else. Earths are BMW specific or is it the same method in generally most cars? (In other words,will a mechanic not specializing in bmws suffice?) I have to take care of this ASAP. The dash lights ARE extremely dull ; I could barely see the miles. And no lights are no fun!
Old 10-24-2012, 09:53 PM
Old School
99% of cars use this system. Hope your guy is good.
Current:
E38 Parts Car
Previous:
Old 10-25-2012, 06:42 AM
Newman271's Avatar
Newman271 Newman271 is offline
That Guy
Mein Auto: 99' 540i M-Sport
earths = grounds
In a 12volt system( atleast newer than 65') the positive side of your battery goes to your elctronics while the negative side is grounded to the body of the vehicle.
1999 540i M-Sport
Silver/Black
Still fresh and Minty
1985 335i
Black on Black coupe 5spd
R.I.P
1979 Trans Am 10th Anniversary
#16 of 5,683 made
KOI Import Parts-- 513-771-7777
Old 10-25-2012, 07:38 AM
Well my car radio actually just went out.the power light is in,but the player won't turn on fully. Could that be because the positive side is bad?
Old 10-25-2012, 04:19 PM
anstead610 anstead610 is offline
dream chasin'
Send a message via AIM to anstead610
Mein Auto: 24v e30 -88 toyota pickup
You are on the wrong sub-forum, you should be in the e36 section, not the e30 section.
This e30 is now being parted out. NO body panels are for sale, bumpers/fenders/hood/mirrors/valance or front turn signals. Everything else is up for grabs. Euro grills/cluster are sold, suspension/brakes/LSD/rear tails are already spoken for.
Old 10-25-2012, 04:47 PM
downhiller's Avatar
livin large
i was waiting for someone to chime in on that.
good to see your back anstead.
Old 10-25-2012, 06:39 PM
Okay someone told me to come here before . Thanx
Old 10-25-2012, 07:52 PM
Tkaczuk's Avatar
Tkaczuk Tkaczuk is offline
if it wasn't for that...
Mein Auto: M3, & The Wabbit
Do you have a convertible?
Old 10-25-2012, 08:07 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x1,E30x1, F150
lowEYE, is it a convertible? The '93 convertibles were still E30s.
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 Forum & New Member Intro Forum Mod-
Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426
1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
Old 10-26-2012, 04:26 AM
No.4dr.
Old 10-26-2012, 11:02 AM
D'oh, You Kids!
Then it's an E36 and you're in the wrong forum.
Quotes to live by:
BMW-CCA #441426
Old 10-26-2012, 11:06 AM
Tkaczuk's Avatar
Maybe Mark will help you out and move it.
