Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series > E30 (1982 - 1993)
E30 (1982 - 1993)
Old 10-26-2012, 10:09 PM
nvmike nvmike is offline
Mein Auto: 1987 325iC
1987 325ic. fuel draining ?
can i drain the fuel from the line coming from the tank into the filter? meaning if i pull the line there will that drain the tank?
as always,
thanks!
Old 10-27-2012, 09:45 AM
Tkaczuk's Avatar
Tkaczuk Tkaczuk is offline
1 John 1:9
Mein Auto: E30, Rabbit GTI
as always,
thanks!
Yes, all the fuel in the line will come out but not the whole tank full of gas. Under 8oz. will come out. It is under some pressure so point it away from you.
Old 10-27-2012, 03:08 PM
downhiller's Avatar
livin large
are you trying to drain the tank or just trying to replace the filter?
Old 10-28-2012, 08:05 AM
BMWFatherFigure's Avatar
Old School
Depending on the various heights you might start a siphon and will empty the tank, just not fast.
Current:
Previous:
Old 11-05-2012, 09:15 PM
fporro fporro is offline
Send a message via MSN to fporro Send a message via Yahoo to fporro Send a message via Skype™ to fporro
Mein Auto: 87 325iC
there's a allen type screw on rear passanger side of tank, undo it and tilt car from front driver side.
cheers,
Frank
e30 parts
