E34 (1989 - 1995)
Old 10-27-2012, 03:07 PM
Costa's Avatar
Costa Costa is offline
Mein Auto: Supercharged E34 540i6
Subframe Noise
Under sudden acceleration from a standstill I hear and feel a clunk in the rear end. My first and only guess so far is the subframe mounts. I'm getting these replaced soon, I just want to make sure that's what's causing the clunk.
Old 10-27-2012, 03:22 PM
Banned
Mein Auto: car
Do you feel the clunk when you decelerate quickly from speed ? If you do, then its the rear differential, that has developed too much free play.
Old 10-27-2012, 04:42 PM
1995i540 1995i540 is offline
Satin Black E34
Mein Auto: 1995 540I/6
Subframe mounts don't really cause clunking, if it's 100% in the rear it's your diff mounts or the part where diff mounts to flange I forgot what's it's called but its responsible for major clunking when worn especially when doing downshifting.
Your best bet is to inspect it.
///////////////////////////////////////////// E34 Addicts
Old 10-27-2012, 07:31 PM
Costa's Avatar
Thanks for your posts guys, I am starting to believe it is the diff. I'm getting the gear oil changed on the 7th of November and during that time I'm going to try and replace all worn driveline pieces. I'll update this thread when I'm doing the work. (hopefully with photos)
Old 10-28-2012, 03:27 AM
BMWFatherFigure's Avatar
Old School
Could be slip joint on drive shaft?
Current:
Previous:
Old 10-28-2012, 12:42 PM
Costa's Avatar
I have no idea yet, just gathering ideas. It's to the point where it starting to annoy me a lot when I'm accelerating from a stop
Old 10-28-2012, 03:34 PM
M540FELLA's Avatar
M540FELLA M540FELLA is online now
Josh
Mein Auto: 95 540i m sport
It may be subframe mounts http://www.bmwe34.net/E34main/Mainte...ameBushing.htm
