Discussion pertaining to the flagship BMW here. |
#26
Rear DVD Navigation System with proper DVD Disc. 2005 745li
Fully Loaded 7 Microsoft SQL Business Intelligence Expert |
#27
Can you post a close-up picture of your DVD map disc - the label side?
#28
hey guys need some help.. I have a 05 745i NAVI02 i need the cd or dvd for it... i live in new england and right now it has a florida disk in it.. i checked and it does have the firmware 8.4.4
You should be using the 'High" DVD and not the 'Professional' I'm sure if you got it from the dealer then you have the right one. The DVD/CD drives are a common failure, My NAVI01 died and I have since replaced it with a NAVI03. You could try cleaning the lens, there is a fan in the NAV unit and it sucks loads of dust through the unit and alot gets deposited on the DVD/CD and lens itself, the disc in my NAVI01 had been in there 9 years! it was filthy! Worth a try, I would keep an eye out for a replacement on ebay, I waited ages and got my NAVI03 for $250 which was pretty good! Stuart |
#30
Can we get a re-up please?
#32
#33
#34
Question will this process update the map or this will only update the Firmware if so what does the Firmware do?
Your navigation system is a computer. Firmware is the operating system. The operating system won't change the pictures saved in the computer. |
#36
Ok I understand so how can I get and update DVD map disc? Can I download a copy and of North America or The USA
eBay is the way to go.
#38
hd750,
my sw version is 9.8.2 hex so do i need v32 firmware update or not? |
#39
New member here I have a 2006 750LI and trying to update my Navigation system. (hd750Li) I have followed your instruction to a T I have downloaded the cue and bin files to a cd-r and a dvd-r. But after following the instruction and get to the point of putting the firmware disk in. Once inserted all my screen say's is please insert cd/dvd? Kind of at a lost here could you possible tell me where I'm going wrong here?
#41
Try to insert that CD/DVD to a laptop or desktop to see if it can be read. My guess is the burn did not write data successfully to the disk. Or the disk was bad!
#42
Ok I think I see what I was doing wrong but we do need both files the cue and bin file correct?
#43
Sorry I reread your instructions it was either or lol let you know if I done it right going to try to update the Navi now.
#44
If you use ImgBurn, you only need one file. However you will need to download both cue and bin. The burning software is smart enough to select the right one.
#45
I used Roxio
#46
Hi
sorry but I'm confused.. mine is 9.8.2 hex is this the latest or shall I upgrade ? and if so which files shall I download from the three. thank you |
#47
you have the latest, good to go.
"If version is 8.4.4 hex, then your system is NAVI02 which already had the latest firmware. Nothing needs to be done. Skip the rest. If version is 9.x.x hex, but not 9.8.2 hex, then your system is NAVI03. Proceed to the next step. E65, E66 NAVI01 (CD-drive): later version is 7.3.2 (not applicable here) E65, E66 NAVI02 (DVD-drive): latest version is 8.4.4 hex E65, E66 NAVI03 (DVD-drive): latest version is 9.8.2 hex"
#48
Question, I have a 2007 - 750Li with E66 NAVI03 that needs the v32 software update. I found a 2013 Eastern High version map on e-Bay. Will I need to update to v32 in order to use the new map DVD disc? And if so, in order to make the v32 software update Disc, do I simply download both files and burn both to the disc and just put it in the Navigation DVD drive? Finally, if you know, will I need some type of access code for the Map DVD disc from e-Bay or do I simply get the disk and use it? I know it is allot of information I'm asking but I really do appreciate it.
#49
Thanks for the info hd750Li.
Sent from my SPH-L900 using Bimmer App |
