E34 (1989 - 1995)
Old 10-26-2012, 06:29 AM
Ssuss34 Ssuss34 is offline
http://i1341.photobucket.
Mein Auto: '89 E34 535i
My rear calipers rattle. Can you see anything missing?
Check the pic, tell me if the retainer clip is installed wrongly or I'm missing shims or anything else you may find.
Old 10-26-2012, 07:01 AM
Banned
Mein Auto: car
Your calliper clip does not look right...its not curvy enough, so its probably loose and thus causing the rattle.
The calliper clip is the thing that looks like a miniature bow used for archery. Look it up on realoem.com.
This is a cheap fix and easy to replace if you know the technique.
Old 10-26-2012, 07:17 AM
Thanks, can the clips be bent to make them work?
Also, can someone post up a detailed up close pic of their rear calipers so I can compare. I also want to see if I am missing shims.
Old 10-26-2012, 07:44 AM
supertech777's Avatar
supertech777 supertech777 is offline
Mein Auto: 1995 525i
This I just got done doing , the rattle in my caliper was due to the inside brake pad by the piston was lose . All you have to do is take that brake pad out and spread the tension spring out and put it back in the piston .
Sent from my Desire HD using Bimmer App
Old 10-26-2012, 07:59 AM
1995i540 1995i540 is offline
Satin Black E34
Mein Auto: 1995 540I/6
Check the bolts behind it and make sure they are tight.
///////////////////////////////////////////// E34 Addicts
Old 10-26-2012, 01:22 PM
Banned
Mein Auto: car
No it cannot realistically be bent correctly and new ones are fairly cheap, just a couple of dollars, and this almost never fails, so I wouldn't bother.
Old 10-27-2012, 08:29 PM
Supertech 777 - can you please explain what work you did? I have the same problem as you had. Do you need to take the caliper off. And what do you mean by the tension spring?
Old 10-27-2012, 08:42 PM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is online now
Humble E34 lover
Mein Auto: 1992 525i
Noel's not on at the moment, but I'm pretty sure I know what he is talking about. When you get a set of brake pads, one of them (the one that abuts the caliper piston) has three prongs that are attached to the back of the pad . The tongs go into the caliper piston with tension against the lumen of the piston. He is suggesting that you take the pad out, spread the prongs a little and then place it back into the lumen of the caliper piston.
Hope this helps explain it for you.
PS: Noel, correct me if I am wrong.
Steve
Calypso Red 1992 525i with 170K miles
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 10-27-2012, 09:14 PM
Thanks Steve , LOL I know you've done it yourself . Best regards to you and your family , and that includes your e34
Noel
Old 10-28-2012, 01:40 AM
Thanks for the explanation. Will take a look at it next weekend.
Just to confirm to you all, my rattle was coming from both rear inside break pads ( pads furthest away from the wheel ). They both had a bit of play and rattle loudly even when touched with my finger. As a temporary fix I just knocked a thin peice of tin between the base of the pad and the caliper housing then bent it around so it would not fall out of place whilst still allowing the pad to move back and forth. Rattle has gone away. Will do proper fix on the weekend.
Old 10-28-2012, 03:12 AM
BMWFatherFigure's Avatar
Old School
+1 on suggested fix. You will need a 7mm hex key to get the caliper off. Rubber grease when you re-assemble.
Current:
Previous:
Old 10-28-2012, 03:19 AM
Thanks for the heads up.
