Old 10-24-2012, 03:08 AM
kwmkoester kwmkoester is offline
Mein Auto: 2012 550ix M-Sport
"Flapper" Valve in my exhaust
I'm not sure which models have them and which don't, but, I do know that my 550IX has a "flapper" valve in one of the exhaust outlets. Anyone know exactly how it works and whether or not it can be coded?
p.s. Thanks to all of you guys that have helped me to get to the point where I am able to "code" my car.
Old 10-24-2012, 09:07 PM
shawnsheridan's Avatar
Mein Auto: 2011 535i M-Sport
The Exhaust Flapper Valve is standard in all V8 F10's, but I have no idea if it is codeable or not. I would think a muffler shop could force it open or closed full time depending on how you wanted it.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11)
- BMWCCA #446923
- flick
Old 10-25-2012, 07:26 AM
EIAlfonso EIAlfonso is offline
Mein Auto: 11 535ix MSport w/ Dot
If it's like my old 330 its vacuum actuated, if you want to keep it open you just remove the hose and plug it
Old 10-25-2012, 03:39 PM
Since nothing is simple anymore, I figured that BMW used vacuum for the energy to open the valve, but, still utilized a electrically controlled solenoid valve to control when it opens. Oh well, I'll give it a go and let you know.
Old 10-28-2012, 01:06 PM
wjjklj's Avatar
wjjklj wjjklj is offline
Certified 7
Mein Auto: 2004 745i
It is a butterfly valve. It cannot be coded as it runs off the vacuum pump. Search the golf tee method for plugging the vaccum hose. Some people have also just used a large nail through the butterfly valve to hold it continuously open. It sounds much more aggressive.
Old 01-27-2013, 02:09 PM
bmwessen bmwessen is offline
Mein Auto: M135i
In my F21 M135i ist is not vacuum controlled it is electrical, pulling the cable forces it to stay open. Found something in DME-Module will try to edit it
Old 01-27-2013, 04:01 PM
Donm Donm is offline
Mein Auto: '13 M 550i, BMW f800st
Let us know if progress is made!
Regards
Best regards,
Don M
It isn't broken yet but I can fix that!
2013 550i, BMW F800ST, ML350
