BMW Coding and Programming
Discuss coding options and features on your BMW here. |
f01 rear DRLs on Canadian car?
I had my car coded and I wanted the rear DRLs but can't figure out how to enable the rear DRLs, could someone shed some light on what needs to be changed to enable the rear DRLs on f01? Btw, it is a Canadian car so the front are DRLs from the factory because it's the law in Canada.
2011 750i |
Drl_modus
drl_s |
2011 750i |
what is DRLs?
which one the orange one ? could u plz post a pic?
The DRL value turn on your angel eyes and rear LED tubes when you have your light switch in the off position hence "daylight running lights". All cars in Canada must have DRLs but I believe the rear DRLs were disabled on 2011+ models.
If you want the 3 orange LEDs completely off and only turn on when you use your turn signal, here's the value; FRM / 3060 FRM_U_EFFEKTIV, 20 / U_EFF_SM_V To turn off set to: Wert_01/werte=00 Default Value is Wert_02/werte=03
2011 750i Last edited by f01driver; 10-28-2012 at 04:29 AM. |
Check this page:
http://www.bimmertoday.de/2009/11/24...an-front-heck/ Andy |
Okay I got it, Thanks
In the morning, Is The Rear DLRs will be more brightness than evening time? I mean, Is it act like Front F02 2013 Led.
On F10/F01(2) the rear DRL are the same brightness with or without daylight/headlights.
Same on the f01, you can't change the brightness of the rear LEDs.
2011 750i |
