E34 (1989 - 1995)
Old 10-22-2012, 05:39 AM
Peter's 525I Peter's 525I is offline
Mein Auto: 95 e34 525i
coolant leak
finally found the coolant leak on my 95 525i. it seems to originate from the back of the block around the exhaust manifold headers. i will take some pics and post them after work(if im not too tired). anyone experience this?
1995 e34 525i
M50 Auto K&N Sport Air Intake
THE TACK TACK TACK IS GOOOOOOOOONE!!!!!!!!!!! It's Like a new car!!!!!
Old 10-22-2012, 10:08 PM
luckydog's Avatar
luckydog luckydog is offline
Lucky to drive a BMW
Mein Auto: 2006 M5///
I doubt its a block leak .I would be checking hoses that connect to the block under the intake manifold there is a small one that is prone to split,I think the one to warm the intake throttle body. Also a heater hose from block could leak.
Old 10-22-2012, 11:46 PM
BMWFatherFigure's Avatar
Old School
Freeze plug?
Current:
E38 Parts Car
Previous:
Old 10-23-2012, 12:24 AM
u may be right about that small hose. i removed the throttle body and guess what... the intake and out take were CLOGGED. screwed a long thin screw in the holes and just kept pulling out solid green gunk. maybe the hose burst from pressure build up. who knows for sure. i am going to continue with the intake removal tomorrow, need to get at the starter and get it rebuilt. im going to go and take some snap shots and post them 2morrow. Thanks for the advice Luckydog.
freeze plug? those are below the exhaust headers right? aboot (im canadian) 2inches in diameter? its from above those.
1995 e34 525i
Josh429er Josh429er is offline
Mein Auto: 1989 BMW 535i
Head gasket? Mine on leaks on cylinder 6.
2003 GMC Sierra SLT 2500HD CC/SB
Old 10-23-2012, 08:48 PM
PLEAAAAAAASE N“OOOOOOOOOOOOOOO.:b anghead:
1995 e34 525i
Old 10-29-2012, 03:46 AM
Bugsie Bugsie is offline
Mein Auto: BMW E34 M50 2.5
Hi all.
I had a coolant leak from the hose connecting the block to the heater valve, on the block side. It's also around that area.
Best regards
