Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series > 7 Series - F01 (2009 - current)
The new re-designed 7 series leads off the BMW Fxx chassis code!
Old 10-29-2012, 02:56 PM
Caligan Caligan is offline
Mein Auto: 2007 750LI/1988 560 SL
Problem refueling 2007 750IL
Hello as a new member I thank you for this opportunity and hope to return the favors. I can not fill the gas tank without having to pull the nozle out and place itin back every few gallons taking a bit of time to fill up. Help!!!!
Old 11-19-2012, 09:30 PM
sdadept sdadept is offline
Mein Auto: 2012 750li X Drive
iv'e had a lesser version of the same problem. Frequently when I'm refueling, the nozzle thing clicks off.
Old 11-19-2012, 10:05 PM
azbimmer's Avatar
azbimmer azbimmer is offline
Mein Auto: 2009 750i 2006 330ci
Try this. After you insert the nozzle, pull it back a centimeter, and it'll work properly. Sometimes nozzles need a little breathing room.
Good luck.
09 750i, 06 330Ci, 03 MDX, 08 535i (Sold), 73 Piper Cherokee (sold), 82 Yamaha 750 (sold) Too many Audis, Mercedes-Benzes, and Lexuses to mention.
Old 11-20-2012, 01:54 AM
ChrisF02's Avatar
ChrisF02 ChrisF02 is offline
MCHTSCHNL
Mein Auto: 2013 750i
I have the same issue on my truck, I have to stick the nozzle in and turn it counter clockwise, from 6 o'clock where it typically sits to about 4-5 o'clock and it works. Might work for you too.
Good luck
2013 BMW 750i - Coded, Executive, Lighting, Cold Weather, M Sport, M 303 Wheels, 5% Tint, Conti DWS Tires, 3M Bra, Front DE Plate.
