E34 (1989 - 1995)
Old 10-29-2012, 08:06 PM
Larrick Larrick is offline
Mein Auto: 1994 525it
Brake pad replacement
I used ceramic brake pads last time. Are they the best?
The warning light just went on. I read in some threads that that gives you several thousand miles before you need to replace the brake pads.
I will do the job this weekend (of course) but ..is that true?
I also read that you can lay a bead of solder on the old brake pad sensor and it will work fine.
Is that true?
Old 10-30-2012, 04:52 AM
The Ornery Old Man
Mein Auto: 535i
That is a pretty open ended question. There are tons of pads on the market pushed on the public using key words like ceramic. Ceramic pads by who and for what application? Pads from autozone? no thanks. Pagid, Performance Friction, Hawk all make premium pads for diferent applications from street to hardcore track. All pads are some compromise between rotor wear, noise, cold/hot performance.
For 99% of people a basic pad that meets oe specs is more than enough. The brakes on the car are overengineered for US driving speeds. You do not need special pads for braking performance sake. You may want quiet, dust free pads though. I don't have a specific reccomendation, I am sure others will chime in.
Winter Rules
Old 10-30-2012, 05:38 AM
Banned
Mein Auto: car
Is that true?
Sir, have you checked your brake rotors as well ? They may be due for replacement too. The Bentley manual has specs on thickness, as a guide.
Old 10-30-2012, 06:48 AM
They looked good the last time I changed the pads. I will not see the car until next Saturday. The brake warning light supposedly comes on with 3mm left out of an original 8mm so I am hoping that no warping from heat or scoring from worn out pads has occurred.
What about the soldering of the brake pad sensor?
Old 10-30-2012, 06:54 AM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is online now
Humble E34 lover
Mein Auto: 1992 525i
Don't know if soldering the sensor will work, but they aren't very expensive, even at the dealer.
You could try the soldering technique and let us know if it works.
Steve
Calypso Red 1992 525i with 170K miles
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 10-30-2012, 11:11 PM
BMWFatherFigure's Avatar
Old School
7mm Alan key, rubber grease and anti seize. Soldering should work, +1 on giving a result
Current:
Previous:
