Old 10-29-2012, 01:25 PM
tgb1974 tgb1974 is offline
Mein Auto: 2012 X5 35d
iDrive -- find nearest diesel station?
I may be be demonstrating my ignorance here, but is it possible to have iDrive tell you where the nearest service station that sells diesel is? If so, how is that done, and can I store it as one of my shortcut buttons? Thanks in advance.
Old 10-29-2012, 01:56 PM
SkipSauls SkipSauls is offline
Mein Auto: 2011 X5 xDrive35d
I'm pretty sure that you can choose to show diesel only when doing a search in the nav. However, it's been my experience that getting through all of the screens to do so is silly. I haven't tried assigning a shortcut button to it, but it's certainly worth a shot. One thing I've found is that sometimes you can't assign a shortcut to the current screen, rather you have to have the menu item that selects the screen highlighted, then hold the shortcut button to assign it.
Also, if you have an iPhone, the Fuel Finder app works well and can filter for diesel, etc. You can find nearest, find by zip, and push the "On Fumes" button to quickly get results:
The iOS version is here:
https://itunes.apple.com/us/app/fuel...299969005?mt=8
Looks like an Android version is also available:
https://play.google.com/store/apps/d...inderpro&hl=en
Old 10-29-2012, 03:08 PM
Penguin Penguin is offline
Mein Auto: Z4 and X5 Diesel
Yes. I believe when you search in points of interest and get to the "fuel" screen, you can press again and get a choice of diesel or gasoline. Or maybe you have to press the "Option" button when you are at the fuel screen.
But.... the BMW navigator database is terrible, so it is very likely the information will be wrong. Think of it as similar to stopping to ask a senile old man standing by the street -- "Well, I reckon I sorta remember that the ol' station down by the bridge had a diesel sign a few years ago, so you might try there, but I'm not sure that station is still in business." BMW Nav has similar accuracy.
Yes, you can. I did it a couple of years ago, so I do not remember all the steps, but I believe if you navigate to the fuel choice screen, you just program the button at that point. I am 100% sure you can do it, since I have done it; however, you may have to do some trial and error to get the exact sequence.
Old 10-29-2012, 03:35 PM
AutoUnion's Avatar
AutoUnion AutoUnion is offline
Mein Auto: Deutsch Automobil
Use your iPhone/Android. iDrive POIs suck.
Old 10-29-2012, 04:45 PM
ChuckGr ChuckGr is offline
Mein Auto: X5 35D
I have find diesel set on one of my presets and it works well.
Chuck
Old 10-29-2012, 10:37 PM
RPsX5d RPsX5d is offline
Mein Auto: X5 Diesel xDrive35d
Chuck
+1
+1
Originally Posted by SkipSauls View Post
I'm pretty sure . . . One thing I've found is that sometimes you can't assign a shortcut to the current screen, rather you have to have the menu item that selects the screen highlighted, then hold the shortcut button to assign it.
+1
Originally Posted by Penguin View Post
But.... the BMW navigator database is terrible, so it is very likely the information will be wrong. . . . .
> can I store it as one of my shortcut buttons? . . .
+1
I have done everything listed above! Finally came to the conclusion smartphone app is the best way to go!
About the only place where you may revert back to the iDrive is a place where there is no cell coverage but there is satellite coverage . . . such a place most likely will not have a fuel station . . . and all that iDrive did for you is - confirmed you will run out of fuel and make you feel really bad!
