The X5 SAV Forum
Old 10-01-2012, 07:06 PM
SassyGirl SassyGirl is offline
Mein Auto: 2006 X5 3.0i
Angry Bluetooth malfunction - HELP
Re: X5 2006. BT was working fine wt my HTC incredible 2. Phone book did not sync but that was ok with me. Typically I turn off BT once in house and activate phone when in car without problem. One day got in car and phone would not connect. I tried everything. Resetting phone. Turning off and removing battery. I then noticed that BT appears to be disabled in the car. The tele button not fuctioning. Can't get to activate phone prompt. Checked fuses seemed to be ok. Eveything else is working radio all the panel lights, etc. is there a way to enable the BT or check anywhere else?
Old 10-11-2012, 08:40 PM
Turo37765's Avatar
Turo37765 Turo37765 is offline
GO GET IT $
Mein Auto: F10 550I
I don't know but I'm having the same issue with mine. Just picked it up 2 days ago and it was working and now... Bam. Done. Not working.. Hopefully someone responds..???
Old 10-23-2012, 09:07 PM
I was told that it may be the telematic control unit. Will need to take it to dealer. Bummer
Old 10-23-2012, 11:07 PM
Mudnyrey Mudnyrey is offline
Mein Auto: X5 3.0i
Here is what I found also: Might save you some $$ if your handy. (See last link) It allows you to find the TCU unit and disconnect the power to it. Might reset it?
http://www.bimmerfest.com/forums/sho...d.php?t=512965
http://www.justanswer.com/bmw/49tbg-...-suddenly.html
*This may help as well...
http://www.bimmerfest.com/forums/sho...d.php?t=378119
~Mud~
Old 10-24-2012, 12:26 PM
Thank you!!! will give it a try this evening.
Old 10-24-2012, 01:39 PM
Mein Auto: X5 3.0i
Good Luck!!
Any News to your issue...Update?
Old 10-28-2012, 06:11 PM
Good news Bluetooth working!
Bluetooth working! Located and unplugged TCU as instructed. Did not work right away. Wasn't sure if needed to be in 1st on ignition or car on. Tried both - nothing. Started process over again but also checked fuses again Looked at fuse panel # 7 in glove compartment and rear panel fuses #72 and 73. They all looked good so put them back. Feeling defeated i connected the TCU back started the car YES! Activate phone was there. Huge smile. Thank you
Old 10-28-2012, 10:56 PM
Turo37765's Avatar
GO GET IT $
Mein Auto: F10 550I
That's awesome... I will try it tomorrow if the hurricane allows
Old 10-30-2012, 01:56 PM
Mein Auto: X5 3.0i
Glad that helped you out Sas
