The X5 SAV Forum
Old 10-03-2012, 07:00 AM
dy8tes dy8tes is offline
Mein Auto: 2005 X5
ABS / BREAK /4x4 warning lights
Has anyone experienced these warning lights coming on after you have had an alternator and new battery put in? I have an 05 X5 4.4 I replaced both the battery and alternator and had the Trans failsafe warning come on and had that reset and now this the next day. Is this just my luck with a new issue or is this what happens afterwards?
Don
Old 10-04-2012, 02:36 AM
brunooo brunooo is offline
Mein Auto: 05 X5 4.8is
Hi dy8tes, did you reset the steering angle?
Old 10-04-2012, 06:25 AM
Mein Auto: 2005 X5
I have not reset the steering angle. Will this help?
Don
Old 10-04-2012, 08:07 AM
Hi Don;
Try this when you start the car, the lights should come off
Old 10-04-2012, 09:17 AM
Mein Auto: 2005 X5
Thanks for the info Brunooo,
I have tried the wheel alignment like you suggested. Lights are still staying on. I took the BMW to autozone to see if they could tell me if it was a speed sensor and which one. They couldn't pick up and issues at all with their tester. Any suggestions where to start next?
Don
Old 10-04-2012, 09:37 AM
Hi Don,
Try to get the codes pulled by a BMW specialist,
can be a sensor, can be the control unit or the pump...
Your speedometer is working fine?
One more thing, does the new battery have the same specs as the old one?
Old 10-04-2012, 10:25 AM
Mein Auto: 2005 X5
Speedometer seems to be working fine. As for the battery spec's I still have the old battery and the new one is from autozone and they looked up the spec's and I went with that one. I am not getting any codes on my dash like I did with the trans failsafe program when theses lights come on and wondering if that is normal. I appreciate your quick feedback!
Don
Old 10-04-2012, 12:19 PM
There won't be any dash message related to your DSC/4x4/ABS light problem. The lights are just going to be on.
You have to find either a BMW dealer or a BMW specialist or anyone with a scan tool to read the codes to see what is exactly the cause of the problem.
Let me know after that, it should be pretty straightforward
Also, before that, it can be worth a try to unplug your battery negative cable for the night; it will reset the ECU. Then plug it back and check if the lights are still on.
Old 10-04-2012, 12:44 PM
Mein Auto: 2005 X5
I will unplug the battery for the night and keep you updated. Once again THANKS!
Don
Old 10-27-2012, 07:56 PM
Mein Auto: 2005 X5
Ok here is an update. I thought I had this issue resolved but crazy things happen. No issues driving the x5 the other day until the trip home. BOOOM! Everything went nuts again. This time a new issue at the same time as trans fail safe/abs/4x4 and then check engine coolant light came on. Immediately pulled over. It looked like I over heated. Blew a radiator hose. Towed home! Next day I decided while I am replacing this hose and I have everything yanked out of the way so lets get the new alternator tested to see if this is the trans fail safe issue! New alternator was bad! Replaced it and the hose and as of now no issues with the trans fail safe program/abs/4x4.
Old 10-30-2012, 12:18 PM
88keys4u 88keys4u is offline
Mein Auto: 2006 BMW X5
I am receiving this now and do not know what to do...think the alternator bad, only 108K on the car. Put new battery in and had to tow 60 miles because like many others, in the summer of 2012, the heat gauge was stuck because the X5 did not recognize the new battery...so another $105.00 at dealer for "diagnostic" as they said to program the battery.....been teaching electronics for 25 years, still looking for one of those "programmable 12V Auto Batteries". Worked fine for about 2 months and then all of a sudden, daughter in car with my grand kids and the car fails, trans light on, and ABS and other 4X4 indicators. Jump car, runs well for less than one week, and first cold snap being this weekend, all goes haywire which indicated bad battery. On way to work this morning and have brown out and shut down of electrical system, tow for $75.00 and charge battery at my school and now trying to determine the problem. Is is the alternator or the voltage regulator. This car has gremlins and electronic demons and is beginning to resemble the misery of Range Rover owners. My 1996, 328i is great car as is my 1974 VW Bus....dependable.....if before 1999!!! Maybe prince had a point with song "1999"! Work at a school with brand new $10k scan tool system, getting now waveforms from the Alternator or Voltage Regulator indicating past problem or not on top of it yet............I need help!!!!!!!!!!!!!
Old 10-30-2012, 08:00 PM
Replaced expansion tank and cap which is located in a terrible place over the alternator, so if and when your expansion tank goes, look out. After I realized my was shot, it may have been too late for the damage to either the alternator or voltage regulator. I am haven same problems with lights and today it finally failed so when i get min fixed, will let you know. I am new to this site, but it is super helpful and the ones that speak out are great..Thanks to all for the help!!
Old 09-07-2014, 07:54 AM
Jimmy mactavish Jimmy mactavish is offline
Mein Auto: bmw x5
Don
Hi Brunooo
Changed my battery today on my x5 went to start and the three lights mentioned came up
carried out the instructions as per your video and the problem is now resolved, thanks for that excellent tip
regards Jimmy
Old 09-07-2014, 08:03 AM
Mein Auto: bmw x5
Hi Brunooo
Changed my battery on my X5 had the three warning lights came up carried out instructions as per your video now problem is resolved thanks for a brilliant tip
jimmy
Old 09-08-2014, 10:37 PM
AJR1982's Avatar
AJR1982 AJR1982 is offline
Mein Auto: 525i 2002 & x5 2002
Here's your answer
Do NOT use a computer to read codes
I've got the answer for what I believe will cover all AWD BMW models. I've spent two days troubleshooting to get this information so please read it before asking me any questions. If you like the information below and would like to donate $5 for my time please click here
Problem: While Bluebee, 540iman and others resolved the practical test for car series 5 and 3, similar methods have not been successful on X5. For test procedure click here
Hypothesis: Rear wheel drive vehicles do not use the same Module as the AWD BMW's. Resistance testing at all wheels resulted in very similar results (984-1013) with two higher resistances in the rear in one direction and (672-687) in the others. (I used a craftsman DMM set to 2MegaOhms.) If same results could be found in any 4 combinations, then those would be the wheel sensors. Disconnecting the sensors at the wheel and retesting at the module should reveal which circuits are for what wheels.
Test: (BMW X5 2002 126xxx) Resistance testing at both, wheels and Female adapter for control module had SIX probable continuity links. According to this picture the following was found to have possible circuit: (13-14 / 28-12 / 30-31 / 15-16 / 36-19 / 42-25). Then I tested those circuits with a single wheel sensor off at a time and gathered the following.
Results:
Please test the following circuits and advise if it worked for you. I will point out that "Diode" mode did not work for me, only resistance.
Open the hood and remove the air box from the driver side. You will find the ABS Module
Disconnect the ABS Harness Module
And with A DMM test the following circuits.
Test = Resistance = Speculated Location
13-14 = 700-1027 = Left Rear
28-12 = 704-1007 = Left Front
30-14 = 697-1033 = Right Rear
36-19 = 683-979 = Right Front
If any of them fail go to THAT wheel sensor and test it at the wheel sensor harness. If it fails then replace that sensor. ($100)
If none of them fail remove the ABS Module and send it in for an overhaul (About $300) I sent mine to BBA Reman. It's a little more expensive but people have said it is better.
Old 05-18-2016, 08:41 AM
Garrik22 Garrik22 is offline
Mein Auto: 2005 BMW X5 4.8is
The video Brunno posted isn't showing up any longer. Does anyone still have it so I can try it on my X5?
