Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > F07 Gran Turismo (2010 - Current)
The 5 Series Gran Turismo -- now available in the USA as a 535i, 550i and 550i xDrive model.
Old 09-19-2012, 07:45 AM
cuorealfa1 cuorealfa1 is offline
Mein Auto: 5er GT 535d
Originally Posted by evacheung View Post
Hello,
I want to confirm that my 2010 F07 DOES NOT have HUD turn signal capability. BLINKER_HUD_ENABLE is not in the KOMBI and HUD_TURNSIGNAL is not in HU_CIC or anywhere else for that matter. I tried clicking F01 (as you should) and even F10 when connecting using ESYS and it's the same deal... those options are nowhere to be found.
RDC_SAFETY (TPMS temp and psi) doesn't work for me either.
Maybe the KOMBI and CIC need to be firmware upgraded?
Did you ever upgrade your car-software? MAybe you have to.
I'm on 47.4.002
You also need newer files for e-sys to enable some things.
I use the 47.4 data files. and the HUD Turnsignal is working fine
2010 BMW 535d GT
Old 09-20-2012, 09:04 AM
gt=hi&bye gt=hi&bye is online now
GT = hi&bye
Mein Auto: 550i gt
[QUOTE=cuorealfa1;7083127]Did you ever upgrade your car-software? MAybe you have to.
I'm on 47.4.002
cuorealfa, were you able to code tire pressure?
Old 09-20-2012, 09:36 AM
unfortunately I didn't try because i saw that i have the rubber valve stems :-(
2010 BMW 535d GT
Old 09-20-2012, 11:33 AM
Mein Auto: 535ix-drive GT
That's too bad! Are you running RFT? If so, in most places, that would be illegal. Some of them are so stiff, you may not notice a flat if driving straight on a nice highway until the tire failed or tried to exit at speed off of a ramp. Most people would notice it when turning, but may not notice at all just going fairly straight.
In most countries, it's standard, and required. SUrprised, it isn't there.
Old 09-20-2012, 12:56 PM
yes I'm running on RFT 20". I was thinking this spring to put Non RFT on the wheels. But i saw a women in the middle of the Highway with a Flat and a damaged 22" wheel and i was thinking "ouuuuutch" So i decided then to buy again the RFT's.
What would be illegal? To drive with RFT's?
2010 BMW 535d GT
Old 09-20-2012, 02:37 PM
In the USA, TPMS are now required on all models (some don't use sensors, but rely on the antilock brakes' sensor to detect variations in wheel rotations). Tire specialists aren't supposed to install RFT without the sensors, and they always come that way from the factory. Did you change tires or wheels sometime along the way? The tire installer may have (mistankenly or fraudulently) taken then out and just put in new 'normal' valve stems. If so, you got screwed. With a tire change, they're supposed to use a new gasket, but keep the TPMS sensor. In the USA, they're around $50 each, so not bad for him to sell to someone later on.
If you go to the vehicle status page, do you have an entry for Tire Pressure? If you do, your vehicle came with them, and somewhere along the way, they disappeared!
It can be quite unsafe to drive faster than the recommendations with a RFT when it is flat, or to drive further than they specify. Without the TPMS, you may not realize it until you try to turn at speed. This can make the vehicle unstable. The max speed when you have a flat with a RFT is moderately low, much lower than your limited access highways. So, at least where I live, it is illegal because of the potential unstable situation if you didn't realize you had a flat - the sensors at least warn you to both slow down, and be more cautious. I do not know if that warning is tied into the vehicle's stability program or engine management system.
Old 09-20-2012, 02:46 PM
ok here in Switzerland aren't such law's as i know.
I do not have the TPMS but the RPA, FTMS(ReifenPannenAnzeige, FLatTireMonitor).... which is looking on the rotation of the tires... so if a tire runs faster then the others, then it shows a message... this should be especially the case on a flat...
2010 BMW 535d GT
Old 09-20-2012, 03:44 PM
So i did also some codings and here are my results:
Entertainment Details in HUD
Phonebook Details in HUD
Phone in HUD
Turn Signal in HUD
Confirmation tone DWA
VIDEO:
2010 BMW 535d GT
Old 09-20-2012, 05:28 PM
eyeatl eyeatl is offline
Mein Auto: 2013 650i GC 2010 Maserat
Thanks for posting the videos!
Please list the coding for getting the phone, phone contact list and radio info to display in the heads up display.
Old 09-20-2012, 05:51 PM
here we go:
KOMBI/3000/HUD_ENTERTAINMENT_ENABLE / aktiv / Werte=01
KOMBI/3000/HUD_TELEFONANRUF_ENABLE / aktiv / Werte=01
KOMBI/3000/HUD_TELEFONBUCH_ENABLE / aktiv / Werte=01
KOMBI/3000/HUD_SPRACHEINGABE_ENABLE / aktiv / Werte=01
2010 BMW 535d GT
Old 10-15-2012, 10:49 AM
xuzhen9241 xuzhen9241 is offline
Mein Auto: GT535i
I want to know how to code a GT Close Trunk from Inside Button.......Thanks a lot!
Old 10-15-2012, 11:54 AM
Mein Auto: GT535i
here we go:
I can't find these codes...Why? E-SYS 3.184 + PSDZdata v.46.6
Old 10-15-2012, 03:11 PM
you have to be on 47.x.x for this
2010 BMW 535d GT
Old 10-15-2012, 03:15 PM
me too...thank you
2010 BMW 535d GT
Old 10-16-2012, 09:08 AM
Mein Auto: GT535i
Thanks a lot! I downloaded 47.5 ...
Old 10-16-2012, 10:54 AM
Not just with the files. Also your car must have a Software Level with 47.x
2010 BMW 535d GT
Old 10-16-2012, 10:58 AM
Mein Auto: GT535i
Do you mean I have to upgrade my car-software?
BTW, how can I know my current version?
Thanks.
Old 10-31-2012, 02:34 PM
MINI+BMWtek MINI+BMWtek is offline
BMW master tech
Mein Auto: e30 318
If we are using F01 targets I will think I need to use F01 cheatsheets, is that correct?, I cant seem to find F01 cheatsheet
Old 02-14-2013, 03:20 PM
cn555ic cn555ic is offline
The Coder guy in N.Y
Mein Auto: bmw
So it has to be upgraded software to have it working on older models?
Coding Inquiry call 917-939-4980
Old 02-14-2013, 05:56 PM
GT = hi&bye
Mein Auto: 550i gt
Coding older models...
To be clear, I have an older model GT. 2010. I did not upgrade the software. I was not able to code turn signals in HUD or TPMS temp and psi. Also, I did not code getting the phone, phone contact list and radio info to display in the HUD.
However, I did successfully code Close Trunk from Inside Button.... along with the other coding options listed at the beginning of this thread.
It appears that if you want full functionality of the HUD, you must have the software updated.
You can definitely code the following without updated software
• Digital Speed in MPH on Dash (on Board Computer)
• Close Trunk from Inside Button
• Close Trunk from FOB
• Fold Mirrors from Comfort Access (Door Handle)
• Fold Mirrors from FOB
• Close Windows and Moon Roof from FOB
• Disable Driver and Passenger Seat Belt Reminders
• Disable Front and Rear Window Disruption - (keep closing when door is opened)
• Unlock Doors on Single Push of Start/Stop Button (allows single pull of door handle to exit)
• Fog Lights Stay On with High Beams
• Enable Welcome Lights (Fog lights, License Plate Lights, Taillights, Position Lights (Front Side LED's), Angel Eyes)
• Enable VIM (Video-In-Motion)
• Remove NAV Startup Disclaimer
• Remove Reverse & Sideview Camera Disclaimer
• Remove Night Vision Camera Disclaimer
• Daytime Running Lights set as Angel Eyes with no Taillights on
