E34 (1989 - 1995)
Old 10-30-2012, 08:59 AM
wredas wredas is offline
Mein Auto: BMW 518 Touring
Can't open trunk
Hello. I have a BMW 518i Touring. The problem I need help with is that I can't open the trunk, nothing happends when you press the button to open it.
So I thought I could remove the plastic from the inside of the trunk, I have loosened all screws and "bolts", but at the bottom its still stuck? Anyone with a similar problem? All help appreciated! Thanks
Old 10-30-2012, 07:55 PM
BMWFatherFigure's Avatar
Old School
Is the lid locked shut or not responding to the central locking system?
Current:
E38 Parts Car
Previous:
Old 10-31-2012, 04:41 AM
It's been like this since I got the car
Old 10-31-2012, 06:43 AM
Old School
OK, which?
Current:
E38 Parts Car
Previous:
Old 10-31-2012, 06:45 AM
OK, which?
Nothing happends when I press the "open trunk button", I am trying to remove the plastic from the inside of the trunk, but its stuck in the middle at the bottom if you know what I mean , where the "lock" is.
Old 10-31-2012, 11:06 AM
paperplane94 paperplane94 is offline
Mein Auto: 1989 525i M20B25
I see, so its open already...
You just have to pull a little harder to get the trim panel over the lock/latch mechanism.
If you are afraid of it ripping you can remove the clips around the perimieter of the panel and remove it that way.
Old 10-31-2012, 12:23 PM
Okay thanks! I'll try harder then
Old 10-31-2012, 10:18 PM
Old School
Check carefully for screws in case a PO replaced broken clips with them.
Current:
E38 Parts Car
Previous:
