E36 (1991 - 1999)
The E36 chassis 3-Series BMW was a huge hit among driving enthusiasts from the first moment the car hit the pavement. The E36 won numerous awards over the years it was produced and is still a favorite of many BMW enthusiasts to this day! -- View the E36 Wiki |
Cars in neutral. Idling. Randomly starts making very minor piston slap/rod knock noise.
I cry, pray to Chesty, then push the clutch in to take off from the light cause idgaf. As soon as I push the clutch in, bam, no more noise. I let it out..noise. Wtf? Never heard a ****ing clutch make these types of noises....
Oh ****. I think I got that backwards..
Fml do I actually have to build my bottom end -_-
If it helps, when I push the clutch in and give it a slight rev, no noise from the bottom end. Also, when I hear this sound in neutral and rev it high, engine purs like a sexy kitten.
The trans has been feeling very notchy, and overall drives like ****. Might be running the original fluid. What I think I'm hearing is something in the tranny? I mean, even in neutral the engine is still spinning the tranny. I put the clutch in, rotating mass in tranny stops, therefor sound stops. Right??
You might have a lightweight flyhweel which exhibits "chatter" at idle speed. Its not a cause for concern unless the issue appeared out of nowhere.
Changing your transmission fluid would be a good first step.
thee antic....
how big are your rims? and what style front lights do you have?
nothing.
Just talked to the PO, stock flywheel. Sachs clutch.
Just bought the car. Stock headlights, clear corners, 18 or 19" ASA rims. I'll check tonight.
one item to check is the starter as well. in my 318 the starter wouldn't retract all the way causing the noise you describe. Replacing that solved my problem.
As for the clutch chatter, my current 328 only does that when engaged and moving with very low revs. Say in reverse up a hill where RPM's are less than 900... ![]() If you are having clutch chatter, then that would mean your clutch is not disengaging all the way. I would also check for a CEL. Make sure it works (key on, engine off, all lights should come on for a moment). If you can, post a video/sound clip of the noise.
Patrick ///98 328i hellrot///BMWCCA#465139 |
I will get on that tonight, so you don't think it's the bottom end then?
I don't know, it very well could be. its better to check and research first before tearing apart and throwing money away
I highly doubt its the lower end. If it goes, it would make noises so horrible it would be undriveable.
is it possible someone machined the flywheel?
I think i read somewhere you arent supposed to do that on our cars
After YEARS of believing the same thing was finally clarified to me. Most shops & machinists aren't capable of it, but resurfacing dual mass flywheels IS possible.
The Evolution of a Lady Quote:
Member of the Non-M Bumper By Choice Club![]() |
Turned out it was indeed low/bad trans fluid. Switched it out and voila, no more noise.
I assume you used lubricant appropriate to the gearbox.
(FYI, 30w non-detergent isn't)
Quotes to live by: guessing gets expensive...drivinfaster nothing is more expensive than a cheap BMW...c4harpe13 Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff BMW-CCA #441426 1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia" I NEED A NAP, DANG IT! Last edited by hornhospital; 10-28-2012 at 09:04 AM. |
You did not even say "thanks", next time don't be stupid and check the obvious fluid levels before wasting everybodies time here.
Are you ****ing kidding me?
![]() Last edited by Thee_Antic; 10-28-2012 at 07:40 PM. Reason: Too vulgar.. |
^Well that was odd... Maybe now would be a good time to pull those panties from your crack? In reality, we should be angry with you for recommending that someone put 30W oil in their transmission...
1998 BMW 328is 1966 Pontiac GTO 2007 Subaru Impreza 2.5i 5-door View my photos: Caught in the Wild Last edited by ZeGerman; 10-28-2012 at 05:38 PM. |
Hmm. Had some quality seat time with the car today, and noticed that the sound did indeed come back. I parked her, got on my back with my trusty stethoscope and listened away. Sound is gear noise from the trans..definitely. Engine sounds normal. Can hear the crank and rods, pretty smooth. The trans however, sounds like this:
Regardless..I"m just going to swap it out anyways. It definitely shifts better with the new fluid, no more grinds or notchiness.
Sounds like the transmission input shaft bearing. Common on e30s, not sure about e36s. If it is the input shaft bearing then it wont cause damage or fall apart, just be annoying. Changing fluid usually doesnt help.
A) There was the proper amount of fluid in the trans when I changed it out, it was never low, just old. Clearly the thing has been used and abused, case closed.
B)Detergent anything, no. C)Don't talk **** to Mr.German. If he has no knowledge on the subject I would much rather him not butt in with detrimental advice, like telling me to put 30w detergent oil in my trans. B)Kindly, gtfo.
![]() Irregardless. Its getting switched out sooner than later, so no worrys (They should arrive in the mail tmrw)
i wanna know how adding non detergent w30 to a trans saved him from rebuilding his engine...df
That guy is nothing but a troublemaker. One look at his youtube videos and his posts on other auto forums pretty much confirms his status as a jerk.
1998 BMW 328is 1966 Pontiac GTO 2007 Subaru Impreza 2.5i 5-door View my photos: Caught in the Wild Last edited by ZeGerman; 10-31-2012 at 09:43 PM. |
