X5 E53 (1999 - 2006)
The X5 SAV Forum |
#26
A little of both I guess. The 4.4 just has more parts to fail. Twice the number of VANOS components is one problem. As an example, a common issue are leaks from the valve cover gasket. Pretty straight forward on the 6 but due the design of the 8 it is very tight and the drivers side valve cover is a mother as the steering shaft limits access. The v8 has the vally pan coolant issue which is a major repair that the 3.0 does not. Can you say water cooled alternator? Big bucks. I just know I have a choice and in the long run the v8 will cost more to maintain. I called a dealer once to get price quotes on the VC gasket job for both motors. The 6 was 700 and the 8 was about 1200. Stupid high even for a dealer. All of them have issues with cv boots failing early and suspension bushings. My seat of the pants oppinion is that the 4.4 only exasperates this wear. Also, the v8 loves to eat tires and at the larger sizes these trucks came with it can add up. The fueel mileage might not be bad for the 8 but at the cost of maintenance I'll take the 3.0. The power is nice but in the end you will grow used to that and want more anyway...I have a suoercharged M3 and still want more.
#28
U'r right Sunny, but right now I only have one car left which is my 09' 650i. Keep running it around for groceries and job apply are really hurt me with the economic situation right now. Maybe I'll just wait, after the election car price probably gonna drop. I just need an all-in-one car for these rainny days. thanks for your advises sunny.
#29
If you can afford $1500 per annum for servicing alone, you can afford to drive an x5.
#30
That's probably indy price not dealer price right?
#31
No, it's Dealer price. On average, I spend $1000 on parts including service per annum to keep my 2006 x5 e53 3.0i going, sometimes it can be $1500 if more work is needed to cover additional minor problems. To replace sunroof would cost $2800Au, brake pads front and rear $700Au, gearbox $5000 and on onboard computer $12000! These are all authorised BMW dealership quotes in Australia which would equate to approximately the same in USA, though in USA, since x5s are made in this country, you will pay slightly less.
I only ever take my car to an authorised BMW dealership as my car is still under extended warranty. When it expires, it will be off to the indies! |
#32
My experience buying a X5 that has nothing to do with the quality of the vehicle but that here in Canada the resale of the sav is high so.. people are fak'in it. Rolled back odometers and unreported accidents. A good TELL is the drives seat , beat and worn will let you know the milage is high. As for accidents I like to take the car for a test drive then a hand wash, upclose and personal you won't miss a scratch.
#33
Would a 2001 X5 with 154,000 miles be considered too old and too many miles?
#34
transmission would be the biggest concern. Might have been replaced at that mileage though.
#35
2001 X5, 154K miles, nav. system and all option but sports package and with int. and ext. colors that I really like - ~11k with taxes, reg. everything. 2005 X3, 94K miles, all options except headlight cleaners and sports package with ext. color that I like but tan/black two ton interior that might take some getting used to (nothing horrible; I'm just a fan of the full black int.) - $13,450 with taxes, reg. everything. Both vehicles have only had two previous owners. No accidents for either. The X3, however, has awesome upkeep records. Last edited by halltristan; 10-16-2012 at 08:51 PM. |
#36
I believe x5s are built to just keep going, provided they have regular service by authorised mechanics, and there has been no history of hard driving. My friend has had an x3 2.0d for 7 years now and the car has clocked 218000kms. The only big problem he has experienced so far was the radiator which had to be replaced. This car has taken him everywhere and still goes like a dream, no oil leaks, no computer or transmission problems, and he tows a small caravan quite often. My x5 3.0i 2006 has been a joy for 4 yrs and have had only minor problems.
#37
What is the average dealer cost to rebuilt a tranmission? Because basically all 2001 X5 E53 now have more than 100,000 miles. And after transmission rebuilt how long will it last? Probably not as long as OEM one right?
#38
Most places, most of the time will replace the transmission instead of rebuilding it. Few places have the expertise to rebuild them. As to the cost it varies depending on where you take it. Dealers being the most expensive as they're likely to replace it with a brand new, instead of rebuilt, unit.
#39
+1. Will need to most likely find a good independent that does German trans work. When I was at the dealer we changed a lot of transmissions. We would open them up at low miles under warr and repair For a long time there were not parts for these boxes but I believe that has changed. When I need mine rebuilt I'll do it myself. When I was at the dealer we would open them up and repair the issue at low miles under warr but the older ones just got a reman box from the factory.
#40
HOLLY mother of BMWs...! So your all saying that the trans will need rebuilt/replaced somewhere after 100K miles on the this no matter 4.4L 0r 3.0L??????
#41
As for 4.4 versus 3.0 I have seen no evidence supporting an increased failure rate of the 4.4 transmission than those in the 3.0. But I don't have a lot of direct experience...just haven't seen it as an issue on the forums I read. |
#42
x5 are nice
I probably gonna buy one at 130,000+ miles since the previous owner/dealer definitely rebuilt transmission. Save some cash. I'm considering between this and the E60 for my sister. Nonetheless, I can play with these car more since they have tons of mod than the later model.
#44
After reading alot of these X5 E53 threads Im sad to say Im no longer going to pull the trigger on a BMW suv
Hardly anything good said about it. At least E39 has alot of good stuff,but when your INDY says you will be in trouble with most X5s ... IM not going to worry with the headache. Looks like a Lexus RX 330 is in the near future for my wife Thanks for the info on this side of the site. Last edited by thecushion; 11-03-2012 at 12:24 PM. |
