Old 11-04-2012, 02:42 AM
D4T_POM's Avatar
D4T_POM D4T_POM is offline
Mein Auto: 2002 E66 745Li
Bloody Weep Hole
Hi Guys,
Just wanted to ask, I recently got the weep hole leak on my car (02' 745Li -129,000) and was wondering can i fix the weep hole without changing the water pump gasket?
I will buy everything needed i.e the Collapsible Pipe, Gaskets, O - Rings and other parts. But just wanted to get away with opening the fan, water pump, pulley and etc.
Sent from my GT-I9300 using Bimmer App
Old 11-04-2012, 06:37 AM
Khabar Khabar is offline
Mein Auto: 745i 2005
yes. Just take intake manifold off.
Old 11-04-2012, 07:45 AM
D4T_POM's Avatar
Hi Khabar, thanks for the reply.
So i dont have to replace the water pump gasket & other parts like the pipe to alternator?
Old 11-04-2012, 07:58 AM
http://www.bimmerfest.com/forums/sho...d.php?t=525719
Follow this link. it is almost the same as 745i. I did mine follow his instructions.
Water pump is on the other side of cross pipe. That is why u do need to take it off
Old 11-04-2012, 09:54 AM
D4T_POM's Avatar
Hi Khabar i saw this link and the guy does not take the water pump off when he done his pipes.
So i dont need to take it off?
Old 11-04-2012, 10:07 AM
no
Old 11-04-2012, 10:35 AM
D4T_POM's Avatar
no
Ok thanks Khabar.
Once i have done it i will come back and let you know how it goes
Old 11-04-2012, 10:43 AM
Ok! If you have some questions while doing the job, u can ask and we will help you. Be careful with all plastic hoses and connections. If you disconnect all wiring from comps underneath cabin filter. It will be much easier to remove and install intake manifold. I did not do it,i would if i knew that time.
Old 11-04-2012, 10:52 AM
D4T_POM's Avatar
Khabar many thanks, I really appreciate your help.
I will definately ask if I get stuck at any point also will keep everything you mentioned in mind
Old 11-09-2012, 03:41 PM
D4T_POM's Avatar
Just ordered the AGA collapsible coolant pipe. Should receive it by wednesday next week
Sent from my GT-N7100 using Bimmer App
Old 11-09-2012, 09:15 PM
sirstopher's Avatar
sirstopher sirstopher is offline
bimmerfest Supporting Member
Mein Auto: POS Honda
The last place I looked online I could get the AGA pipe for 650.00 I hope you got a good deal and good luck with the repair
97 740i e38 - SOLD
02 745i e65
03 Montero Limited
Old 11-10-2012, 02:22 AM
D4T_POM's Avatar
Hi Sirstopher,
I think I got a good deal, considering the fast shipping to the UK via DHL $606 for the pipe kit and $102 for the shipping as I need the pipe ASAP as my cars been parked for a week now.
The other parts i.e o-ring and valley pan etc I have ordered via BMW UK which turns out to be cheaper then ordering from US but the AGA Pipe no one in europe does it so I ordered that from Bimmerzone.com
Have to say Vincent from Bimmerzone.com is a great guy and the customer service has been great so far
Old 11-10-2012, 06:43 AM
I went with bimmerpipe. AGA was too expensive that time.
Old 11-10-2012, 07:14 AM
sirstopher's Avatar
Originally Posted by D4T_POM View Post
Hi Sirstopher,
Sounds better than what I had to do last month. I could not do the repair myself as work had me tied down.
I took it to a Indy and had the AGA pipe installed and a new BMW water pump. You might want to look into spending the extra $$ to replace the pump as my Indy stated its a 7 hour labor bill and its right there. With my car just rolling 112,000 miles I replaced every thing I could including the expansion tank. I think my total bill was 2100.00 +\~
97 740i e38 - SOLD
02 745i e65
03 Montero Limited
Old 11-10-2012, 09:55 AM
D4T_POM's Avatar
Why did you have to change your water pump?
Old 11-10-2012, 09:59 AM
cmpcpro cmpcpro is offline
Mein Auto: Nothing
$2100 for pipe and pump and expansion doesn't seem bad right? BMW did my water pump at 80k.. I was hoping they did the pipe too because they had the car for 8-9 days.. but I called the dealer and asked them to read the notes and it just said pump..
Old 11-10-2012, 10:52 AM
D4T_POM's Avatar
Nope sounds good
Old 11-13-2012, 06:24 AM
D4T_POM's Avatar
Got the kit yesterday, kinda surprised with how fast the shipping was from USA to UK then again paid $102 for shipping.
Now waiting on BMW UK to supply the Bolts with washers, O-Rings, Valley Pan with Gasket, Intake Manifold Gaskets etc.
Old 11-13-2012, 07:51 AM
Mein Auto: Nothing
Wait, so that little pipe was $600???? Why? Am I missing something?
Old 11-13-2012, 08:35 AM
745iguy's Avatar
745iguy 745iguy is online now
Besessen Deutsch Autos
Mein Auto: 2006 X5 3.0
URO has a kit with ORings for about 200$ then u need to buy the valley pan and etc in another kit for about 200 more and then theres the OEM pipe and parts that are kinda cheap in price but require much more labor to replace, most people go with AGA, ive never had to do this but maybe the AGA is more durable/lasts longer?
06 X5 3.0 Toledo Blue Metallic/Light Beige 2:
Adaptive Xenon Headlamps, Panoramic Sunroof, Rear Sunshades,
+Factory Aux Input in Ashtray, Bluetooth, Rear PDC Sensors, Rear Electronic Adjustable Seat Backs,
+White Angel Eye LEDs, +4300K Foglight HIDs, +Blacked Out Chrome Grill Surround
.. more updates to come
PREVIOUS 2002 745i
Old 11-13-2012, 09:46 AM
D4T_POM's Avatar
I had the choice between 3 - AGA, Bimmerpipe and URO.
But by searchig and reading around different forums I opted for the AGA, reason being did not feel comfortable with the Bimmerpipe as they mentioned putting some 'silicone sealant' on one end of their pipe (silicone sealant in my engine is a big no no personally).
Secondly URO has more o-rings then any of the other i.e AGA and Bimmerpipe + URO dont have any reviews online and couldnt find posts which involved people using them.
Spoke to Vincent from Bimmerzone who also said that they used to do the URO pipe but the AGA and Bimmerpipe collapsible pipes are more durable.
End of the day you get what you pay for to be honest.
I will be fitting the AGA pipe next week Monday/Tuesday as cant take a day off work this week.
Also looking at the work that needs to be done I know I will be saving alot of £££££'s by using the collapsible pipe.
Old 11-13-2012, 09:58 AM
I went with bimmer pipe. you put silicon (gasket) inside where robber ring goes. I has nothing to do with engine it stays between engine block and time chain cover. Hopefully u will fix it soon.
Old 11-13-2012, 11:18 AM
D4T_POM's Avatar
Yeh, I know but just didnt feel rite with the term silicone lol
Once I start fixing khabar I will keep you updated on how it goes
Old 11-13-2012, 12:46 PM
Mein Auto: Nothing
Wait a minute, so this AGA pipe is colapsable and thus alot less work? So basically this is a much easier job now with these aftermarket ones? What all is invloved not going the stock route? Thanks!
Old 11-13-2012, 01:09 PM
D4T_POM's Avatar
Cmpcpro,
If you see a link which khabar posted you can see what the process is.
He posted it above
