Old 11-04-2012, 04:18 AM
laurieh laurieh is offline
Mein Auto: Z3 1.9i
Advice on coolant flush
Hi everyone
Needs some advice on coolant flush on my Z3 1.9 1999 M43
Have been experiencing cool air blowing in cabin when car idles, heats up fine when driving.
Not sure when the car had coolant change as I have owned the car only a few months.
Need to know where everything is...ie; drain plugs
Maybe a simple step by step
Was looking at this stuff at halfords Comma XStream G48 Antifreeze Concentrate 5 Litres
and also somewhere mentions distilled water??
Many thanks
Old 11-04-2012, 05:54 AM
Blacklane Blacklane is offline
Mein Auto: 1998 Z3 Roadster
It sounds like you have this problem:
http://www.bimmerfest.com/forums/sho...d.php?t=496311
If you do a search on this forum (use the button near the top right of the page that says "Search This Forum") for terms like "coolant drain" or "antifreeze" or "coolant bleed" or similar words, you should find all of the information you need.
These systems mus be bled correctly. Do a search on that.
Some of it will depend on how deep you want to go. Maybe you want to drain the engine block. That's a different drain. And maybe it's time to replace the water pump before it fails catastrophically taking out the engine. You should consider replacing any plastic parts in the cooling system that are original: radiator, coolant reservoir, thermostat housing, fan, and hoses.
