BMW 325i 2001 - Bimmerfest - BMW Forums
Old 10-29-2012, 05:33 PM
Greekgod1 Greekgod1 is offline
Mein Auto: BMW 325I 2001
BMW 325i 2001
Well recently i bought a BMW 325i 2001 for my b day which is today. Sometimes when i drive in the morning's or random parts of the days, this thing in the left head side pops up. And the hot and cold is always in the middle, is this normal? First time owning a bmw and im not sure what it is, If anyone knows it would help a lot. thanks!
All help is appreciated, Thanks
Old 10-29-2012, 05:57 PM
OfTheLost's Avatar
OfTheLost OfTheLost is offline
Mein Auto: 2000 328i
That is your coolant level sensor, it means youre low on coolant. Did you obtain any maintenance history when you bought your car? These cars are notorious for their weak cooling systems, with many parts that have a tendancy to fail over time. Add some coolant and if the light comes back then you may have a leak or worse...
Old 10-29-2012, 06:49 PM
Well the thing is my dad checked it, and that was full, and more bad news, i drove it again and it got almost in the Red hot when i jumped on it and went fast, then i found out more that the heat doesnt work, and the feet heat only works. Not hot at all. But im still confused on how that thing keeps popping up and its full?
Old 10-29-2012, 07:11 PM
halltristan's Avatar
Bimmer Enthusiast
Mein Auto: 318i xDrive
It sounds like you have an air bubble in the system. With the car cool and the engine off but the ignition on, you need to set the heat as high as it will go (91 f) and set the blowing speed to about middle. Under the hood, you need to open the coolant bleeding screw and keep it open until you see a steady stream of coolant come out. In the mean time you need to have some 50/50 coolant ready to go to refill the coolant tank as the air comes out of the bleeder. After all this, start the car let it run for about 15 minutes until the car gets warm. Then shut it off, reopen the bleeder and let any remaining air exit, recheck the coolant level and fill it up again.
That should get any air out of the system and fix your problem. Very easy to do and it should only take about 30 minutes. If this doesn't fix it, my next guess would be a coolant sensor, which still isn't a big deal. One thing you might also try is to hook up an OBDII scanner and let it read you coolant temp - depending on how hot your coolant is getting, you might also need a flush.
Member No. 470379
Old 10-29-2012, 08:58 PM
Mein Auto: 4 BMWs, 1 Jeep, 1 Vespa
Happy Birthday GreekGod1.
Lots of engines have been killed with this warning. Get it checked before it's too late.
Old 10-29-2012, 11:26 PM
Mein Auto: ///M
been there and it's really annoying
for the car heating part, u have one of the below symptoms:
1- leak somewhere in the cooling system
2- fan not turning on when it should
3- thermostat went bad
4- water-pump not pumping anymore (unlikely)
have your entire cooling system overhauled as it's most probably due to one.
Old 10-29-2012, 11:41 PM
Bimmer Enthusiast
Are you serious? You're honestly going to tell someone that its time to replace their entire cooling system at this point??
Greekgod1: Just do what I said earlier. It's cheap, fast, and easy. There's no point in jumping to ridiculous conclusions this early.
Member No. 470379
Old 10-30-2012, 03:35 PM
Thanks for everyone's help, but i found out like a fan blade is broke, so i guess that was the problem? Spending around 400 dollars for some new stuff, and one question, Is the heat only suppose to come out on your feet, or feet and blow onto you? thanks
Old 10-30-2012, 09:56 PM
lgr122 lgr122 is online now
Heat should be able to come to feet and/or windshield and/or on to you.
Old 10-30-2012, 11:44 PM
Mein Auto: ///M
i pointed him towards the reasons that might've caused the symptoms he's having. and to overhaul means to examine carefully for needed repairs, not "replace their entire cooling system"
Old 10-31-2012, 11:10 PM
Mein Auto: '04 330Ci 6-speed
Read the wiki before you ask another question.
That way if you cannot answer your own questions, you'll be able to understand our answers better.
Up at the top of this page.
Old 11-04-2012, 08:13 AM
Thanks everyone, got everything fixed hopefully, Does anyone know how to change the time?
