Old 07-26-2012, 05:26 AM
jcobb jcobb is offline
Mein Auto: 2001 Z3, 2007 4Runner
Cool 2001 Z3 2.5i
Hi I recently found a 2001 z3 2.5 with only 58,000mi for sale by owner locally and I am hoping to join the ranks of proud z3 owners on this forum soon . My question is with particular year and model is there anything specifically I should watch out for or look for when buying? The seller has agreed to let me take the car to a local BMW mech for a check up so I feel pretty good about it, but I welcome any and all advice!
Cheers!
Old 07-26-2012, 06:04 AM
BStanton BStanton is offline
Mein Auto: 1998 BMW Z3
A common issue with most all Z3s, is a water leak in the trunk..If the Z3 that you are considering has water in the trunk, don't let that deter you from purchasing it.. Z3s have a few places where, over time, water can leak into the trunk.. 1.. The 3rd break light gasket dries out.. simply fix.,. 2.. The gasket around the antenna.. simple fix.. 3.. where the convertible roof meets the body of the car, just below the rear window.... the seal dries out and starts to separate from the car.. fixable..
Usually, you find the water on the battery well which is located in the trunk..
If you perform google searches, you can find out common "items" that need maintenance on all Z3s.. I like to use the term items rather than issues because the Z3 is a fun car to have regardless of "items".
Don't forget to also run a car fax on the car..
This is my toy. 1998 (2.8)
Old 07-26-2012, 08:06 AM
dougmcintyre dougmcintyre is offline
formerly updmst
Mein Auto: 2000 M Coupe, 1997 318ti
http://www.bimmerfest.com/forums/sho...d.php?t=391945 is a good list of common issues. All Z3s share basically the same issues.
But the pre-purchase inspection is absolutely the best thing you can do.
Good luck.
Old 07-26-2012, 07:51 PM
Thanks for the tips and info!
BStanton: I like your Z3, the one I am looking is also silver. I think it is the sharpest looking z3 color.
dougmcintyre: Thanks for the link, that list was very helpful. I am taking for the inspection tomorrow so hopefully all goes well.
Cheers!
Old 07-27-2012, 02:32 AM
Thanks jcobb.... I highly recommend picking up a set of rear fender stone guards. The flair of the rear fenders are a perfect target for debris and stones kicked up from the front tires. Little tiny paint nicks develop without them. I picked mine up at http://www.roadstersolutions.com/pag...FUFV4AodnVKUhg. They are magnetic, so they are easy to attach and remove.
You will love the silver color.... When polished well, in some light it looks like stainless. It's a great color.
Old 07-27-2012, 04:11 PM
amancuso's Avatar
amancuso amancuso is offline
Send a message via AIM to amancuso
Mein Auto: 128i, 330i, Z3 2.3, R56
Welcome to the forums!
Old 07-27-2012, 04:43 PM
ronpolley ronpolley is offline
car poor all my life
Mein Auto: 2001 Z3 3.0i Auto
2001z3
if your mechanical,its a great car to work on and maintain yourself
Old 07-28-2012, 07:47 AM
smayo964 smayo964 is offline
Mein Auto: 1999 Z3 Roadster
Ditto!!! Like Ronpolly mentioned, its a great car to play with. Bstanton, thanx for positng the info on the guards. I have been looking for something lilke that for mine. Love this forum.
S. Maykowski, Columbus MS.
My '99 Z3 Alpine White 2.8L Speed Buggy
Old 11-03-2012, 08:17 PM
Meant to post this a long time ago. Now the proud owner of a perfect condition 2001 Z3 2.5i. Love this car!
Old 11-04-2012, 03:31 AM
Beautiful!!
Old 11-04-2012, 08:23 AM
morrieschoice's Avatar
morrieschoice morrieschoice is offline
Mein Auto: 2001 3.0 Z-3 ROADSTER
fender stone guards
These fender stone guards are on sale for $20 a set on Roadster Solutions. I recently purchased a set to replace my old ones. Check it out.
Old 11-04-2012, 04:25 PM
Z3
What a great looking car,I see its an Auto Steptronic like ours,thats also fun to play with.
Old 12-25-2012, 06:51 PM
alcofribas alcofribas is offline
GLLOQ
Mein Auto: 2001 Z3 2.5i
Getting an analysis of engine wear through oil testing
Another thing to do eventually is have a sample of oil tested by BLACKSTONE LABORATORIES of Fort Wayne, Indiana. Check their website to see a sample of the $25 oil analysis. The in-depth results can indicate bearing wear (traces of babbitt metal will be in the oil) and various undesirable problems such as fluid leaks. If you contact them, you'll receive a kit (two nested bottles) with instructions on how to obtain an analysis. I purchased my 2001 Z3 2.5L / Steptronic w/83,300 miles in June 2012, spent about $2,500 to have all wear items checked and verified or replaced, including auto trans fluid and seals, water pump, power steering components, then had the oil analyzed after I had put 5,000 miles on the car. I was very pleased by Blackstone's analysis which indicated very little engine wear over the life of the car.
