Performance
CAIs, SCs, differentials, SSKs, exhausts etc..... |
JB Racing flywheel and Clutchmaster FX300 clutch
The setup has about 7000 miles of only a few runs at the track. Almost entirely street driven. Retail is around $1300 plus shipping - I will take $500 plus shipping - OBO
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() From the JB Racing website: Fitment: 3/03 - 06 E46 325i, 330i w/ M54 2.5L, 3.0L - 6 cyl., 6-spd. only Note: Above models equip w/ 6-speedZF manual transmission Lightweight Aluminum flywheel replaces stock dual-mass flywheel. Accepts OEM clutch/pressure plate/throw-out bearing components as well as performance aftermarket direct replacements. Will also accept many aftermarket sprung-hub clutch discs. Provides improved throttle response and increased performance. Note: Flywheel includes the hub mounted pilot bearing necessary for 6-speed transmission input shafts. 520-190-240 Clutch Diameter: 240mm OEM Flywheel Wt. 25.0 lbs. List Price $722.50 Alum. Flywheel Wt. 10.5 lbs. Order JBR p/n 520-190-240 Price: $595.00 From the ClutchMasters site: Clutch or Flywheel Details BMW > 330I > 3.0L E46 6 Speed > 03051-HDTZ-R Stage: 3 > Years: 2003-2006 > Price: $895.00 > (File photo for reference only.) FX300 (Stage III) · Heavy-duty street & racing system · Holding capacity 110% over stock · Heavy-Duty reinforced pressure plate · Hi-Leverage™ pressure ring design · Sprung hub/cushioned disc · Steel backed Segmented Carbon/Kevlar -------------------------------------------------------------------------------- All Clutch Masters clutch kits come complete with: Pressure Plate Clutch Disc Throw-out Bearing (when applicable) Pilot Bearing or Bushing (when applicable)
- Stuart |
Is that ONLY for 6cyl motors or do you believe it will fit on a 1999 E39 540i6. I'm looking for a lightweight flywheel myself.
I do not know - but my hunch is that it only works with non M 6 cyl - but you could look up the part numbers on each site and verify
- Stuart |
bump
- Stuart |
Bump
- Stuart |
