E46 (1999 - 2006)
The fourth generation 3 Series (E46 chassis) was introduced in 1999 and set the standard for engineering and performance during it's years of production including being named to Car & Driver's 10 best list every one of those years! ! -- View the E46 Wiki |
Bluetooth passkey for 05 325i
Ok so we located the module and there is no passkey on the box. Is there another way t get the passkey for the bluetooth? Help
So we went back into the trunk after some great advice and took the module out and twala the code was under it. ![]() Thanks for all your help! Last edited by GegeW; 11-05-2012 at 12:06 PM. Reason: Problem solved |
There is supposed to be a plastic sheet with the pass code on it that should have came with your car. Otherwise, you'll have to take out the radio, find the bluetooth unit, and hope to god the passkey it on a sticker on the bottom of the unit.
The Bluetooth module is in the trunk... Remove the panel on the left (drivers) side and the module is in the rack. The pass key (labeled PK####) will be on top of it.
My X3 came with bluetooth because of BMW assist. The dealer told me that the bluetooth module was behind the radio. Different car though.
GegeW, if you've located the correct module in the trunk, be sure to look on all sides of the module for the passkey label. The label is sometimes located on the bottom side of the unit.
![]() E36 DIYs: Air Pump | Vent Gauge | E46 Armrest | SmarTire TPMS E46 DIYs: Hella TPMS | Aftermarket Horns | Window Regulator Notes | Trunk Wire Harness | Trunk 12V Socket |
YOU ARE THE BESTEST!
I told my husband what you said and he found it under the unit!
Thank you!
