Old 10-07-2012, 08:48 AM
332701 332701 is offline
Mein Auto: 535xd
Software update with BMW ConnectedDrive
For those who want to Keep the Software up-to-date, there is a new version available.
UPD01005.bin
bmw.com/update
535xd with 20'' Wheel style 434 M in Sophistogrey II Brillant Metallic
Old 10-07-2012, 10:58 AM
clausx3 clausx3 is offline
Mein Auto: X3 20d f25
Thanks for the information
Old 10-07-2012, 01:52 PM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is offline
Mein Auto: 2011 535i M-Sport
Thanks for the heads up!
Just an FYI. After the dealer last programmed my car with ISTA/P 2.45.1.3, my Combox Software was at MX 3.4.31 & TX 3.4.31. I did the previous UPD01004 update afterwards, which had brought it up to MX 3.5.4 & TX 3.5.4.
However, when I just went out to apply the UPD01005 update, I was surprised to see my current version was reverted back to MX 3.4.31 & TX 3.4.31.
It's clear now that what happened is that when VO Coding my Combox, it reset the Combox Software to match the version included with the ISTA/P 2.45.1.3 Integration Level of the car, and wiped out the previously applied UPD01004 update.
Now after applying the UPD01005 update, it brought it up to MX 3.5.4 & TX 3.5.5.
So, if you VO Code your CMB_MEDIA ECU, you will need to reaapply the latest UPDxxxxx update afterwards.
Name:	MX 3.4.31 & TX 3.4.31 - 10-07-12.jpg
ID:	344701   Click image for larger version
Name:	MX 3.5.4 & TX 3.5.5 - 10-07-12.jpg
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11)
- BMWCCA #446923
- flick
Old 11-05-2012, 01:46 AM
donsultan donsultan is offline
Mein Auto: 750Li F02
Thanks a lot
Old 11-05-2012, 07:29 AM
octopump's Avatar
octopump octopump is online now
Brevity = soul of wit
Mein Auto: F10
Hi Shawnsheridan -
A few of those acronyms went over my head. Did a search but could not find any answers.
Could you please explain what they stand for?
VO
How to the Combox relates to iDrive
ISTA/P
CMB_MEDIA ECU
I also read on another thread that you had changed the "VO" on your car. Could you tell us what the benefits are when doing so?
Old 11-05-2012, 07:43 AM
Originally Posted by v12 View Post
Hi Shawnsheridan -
VO
ISTA/P
CMB_MEDIA ECU
VO is Vehicle Order (aka FA in E-Sys)
The Combox controls all USB/iPod, Bluetooth, and in the case of Telematics Combox, BMW Assist. All those functions interact with the iDrive system.
ISTA/P is the factory and dealer software used to update your ECU firmwares and program your car.
CMB_MEDIA is the Combox ECU (module) Programming / Coding Name, along with CMB_ECALL for Telematics (BMW Assist)
When you VO Code an ECU, E-Sys will code the entire ECU based on the VO's Option Codes and Production Date, all at once. When you FDL code, you are changing only individual parameters. VO Coding is convenient when you don't know all the required FDL Codes to do something, or there are just a bunch of FDL Codes, and it's easier to just add an Option Code to the VO and VO Code the affected ECU's.
- BMWCCA #446923
- flick
Old 11-05-2012, 09:35 AM
octopump's Avatar
Mein Auto: F10
Thank you!
