The latest X3 brings some added style and some new features to the BMW SUV family. Talk about the new F25 now!
Old 11-04-2012, 04:58 AM
wavewuver wavewuver is offline
Mein Auto: 2011 X3
Unhappy Steering Rack Replaced at 40K
I started a thread that was titled "tie rods replaced at 40K". Turned out that the real problem was the steering rack. BMW first replaced the tie rod, but that didn't fix it. Then they replaced the lower steering shaft and that wasn't it. Lastly, they found the problem.......the steering rack.
I noticed the problem when the car was turned off. When I turned the steering wheel left & right, I could easily hear a loud clunking sound from the front end......way down low.
I hope my problem was a fluke and not an indicator of a chronic issue.
Old 11-04-2012, 05:19 AM
lbjgh's Avatar
lbjgh lbjgh is offline
Mein Auto: 2013 X3 M-Sport
I've read about others who have had the steering racks replaced in their X3's so unfortunately the fault may not be isolated.
Old 11-05-2012, 06:05 AM
jman103099's Avatar
jman103099 jman103099 is offline
Mein Auto: 2011 X3, 2011 328i
I responded in your other thread... again, this might not solve your problem as others have had this done and the noise comes back.
I bought my car with roughly 4,000 miles on it and this same noise was there. Dealer said to keep an eye on it, but nothing appeared wrong. Next time I go in I'll have them look at the rack, but I hate to replace it if the noise is just going to come back.
2011 X3 28i (1/12 - present)
2011 328i (5/11 - present)
2009 MINI Cooper (4/09 - 5/11)
2006 X3 (03/07 - 1/12)
1995 325i (05/06 - 3/09)
1985 325e (08/99 - 12/04)
Old 11-05-2012, 07:11 AM
Mein Auto: 2011 X3
I will have BMW replace the rack every week if I have to. There is apparently something wrong with the design or production of the rack. Unless owners press BMW to keep replacing the defect, they won't do anything. BTW.......I noticed excessive tire wear the last few months and BMW initially attributed that to the bad tie rod and that turned into the rack replacement. So keep a close watch on your front tires. Mine were wearing noticeably on the outside edge.
Old 11-05-2012, 10:23 AM
lbjgh's Avatar
I get a very slight bumping sensation as I cross the concrete curb depression when I back out of my driveway (with the steering wheel turned to the left). Donno if it's related.
Old 11-06-2012, 06:59 AM
jman103099's Avatar
That's it. Try turning your wheel when the car is off and see if you get the same noise/sensation.
Old 11-06-2012, 12:46 PM
Mein Auto: 2011 X3 35i
I just tried turning my wheel when the car is off and in park and it makes the clunking sound. I've only heard it while out driving a couple of times. Would love to know how many other people hear this noise if they were to try it with the car off. If the car is on and in drive and you turn the wheel back and forth, there is no noise at all. Would they know if the steering rack needs replaced just by looking at it? Hate to take it in and have it replaced if it doesn't need to be.
Old 12-29-2012, 05:42 PM
vptrails vptrails is offline
Mein Auto: 2011 X3 X35i
Has anyone else experienced a knocking noise from the front of their x3? Mine is a 2011 and its been making this noise lately, particularly when the wheel is turned to the right and I drive over a bump. It even happens in reverse well. One time it happened while I was driving at a fair speed with the steering wheel straight but go over a couple of bumps.
Also, assuming it is the steering rack, does anyone believe this would be a safety issue or is the noise harmless in nature despite being a bit annoying.
Old 12-29-2012, 08:24 PM
glennk glennk is offline
Mein Auto: GTI
Could it be something within the CV joint?
Old 12-30-2012, 09:23 AM
Not sure. It's a possibility. I does sound like a steering component though based on the closeness of the knock to the steering column itself. It sounds like its right behind the dash and that something has a little too much play in it.
Old 12-30-2012, 10:08 AM
noka noka is offline
Mein Auto: 2013 x35i M-Sport
Maybe unrelated but there was a steering recall in 2011 (50 vehicles):
http://www.autoweek.com/article/2011...NEWS/110709955
2013 x35i (Space Gray, MSport, CW/CWII, DHP, Premium, Premium Sound, Technology, BMW-Apps)
Retired:'09 C300 4Matic, '09 GTI, '06 750i, '05 C55, '04 R32, '03 M5, '02 GTI, 01 M5, '00 M-Coupe, '00 540i/6, '99 M3 Coupe, '98 M3 Coupe, '96 328i, ..., '86 4000CS Quattro, ... too many to list
