E46 (1999 - 2006)
Old 11-04-2012, 01:29 PM
GegeW GegeW is offline
Mein Auto: 325 i
Bluetooth passkey for 05 325i
Ok so we located the module and there is no passkey on the box. Is there another way t get the passkey for the bluetooth? Help
So we went back into the trunk after some great advice and took the module out and twala the code was under it.
Thanks for all your help!
Old 11-04-2012, 05:20 PM
halltristan's Avatar
halltristan halltristan is offline
Bimmer Enthusiast
Mein Auto: 325i and X3
There is supposed to be a plastic sheet with the pass code on it that should have came with your car. Otherwise, you'll have to take out the radio, find the bluetooth unit, and hope to god the passkey it on a sticker on the bottom of the unit.
Member No. 470379
Old 11-04-2012, 09:34 PM
E46_Ci E46_Ci is online now
Mein Auto: 2005 325Ci + ZPP/ZSP/ZCW
The Bluetooth module is in the trunk... Remove the panel on the left (drivers) side and the module is in the rack. The pass key (labeled PK####) will be on top of it.
Alpinweiß 2005 325Ci
Spacegrau 2007 X5 3.0Si
Old 11-05-2012, 04:15 AM
Bimmer Enthusiast
My X3 came with bluetooth because of BMW assist. The dealer told me that the bluetooth module was behind the radio. Different car though.
Member No. 470379
Old 11-05-2012, 06:10 AM
G. P. Burdell's Avatar
G. P. Burdell G. P. Burdell is offline
Rambling Wreck
Mein Auto: E46
The X3's TCU is also located behind one of the carpeted side panels in the cargo area, at least on the models I've seen.
GegeW, if you've located the correct module in the trunk, be sure to look on all sides of the module for the passkey label. The label is sometimes located on the bottom side of the unit.
Old 11-05-2012, 12:03 PM
Mein Auto: 325 i
YOU ARE THE BESTEST! I told my husband what you said and he found it under the unit!
Old 11-05-2012, 12:04 PM
Mein Auto: 325 i
Thank you!
Old 11-05-2012, 12:06 PM
Bimmer Enthusiast
Thank you!
That'll be $70.00. (We charge by the hour)
Member No. 470379
