Old 11-05-2012, 03:46 PM
dcocke dcocke is offline
Mein Auto: 2000 z3 2.3
z3 dome light
My 2000 roadster dome light does not work in the auto postion. It stays on when door is shut. Any ideas? Thx
Old 11-05-2012, 05:17 PM
FZbar FZbar is online now
Mein Auto: 2002 Z3 2.5 Roadster
Shorted switch???
Fred
Old 11-05-2012, 05:31 PM
smayo964 smayo964 is offline
Mein Auto: 1999 Z3 Roadster
Dcocke,
I had the same problem with mine on the driver's door. Come to find out on mine it was the plastic latch on the inside of the door wears down on the diameter where it contacts the switch behind the post. Using aluminum roof flashing material, I made a "shim" that wraps around the backside of the post and switch so when the door shut there was enough pressure to activate the switch. As a test, turn your light on auto and push the switch button behind the post and see if your light goes off. If so, you have the same "opportunity" that I had. Good luck.
S. Maykowski, Columbus MS.
My '99 Z3 Alpine White 2.8L Speed Buggy
