E36 (1991 - 1999)
Old 11-05-2012, 07:56 AM
Kdoherty's Avatar
Kdoherty Kdoherty is offline
bimmerfest Supporting Member
Mein Auto: A redhead E90
I love this thread so much.
Originally Posted by Los View Post
^He's been drinking beer and destroying pumpkins with brake rotors and sledge hammers.
So, pretty much just doing man stuff.
  • '06 325xi 6MT
Old 11-05-2012, 07:59 AM
bimmer claus's Avatar
bimmer claus bimmer claus is offline
Santa
Mein Auto: 95 M3
Originally Posted by JayMac View Post
I agree, but you also don't have any idea of how this was maintained prior to me. You can find plenty of pictures where the engines look spotless. You get more hp at the expense of heat so you have to find a way to get ride of it. There is a reason the the S54 is one of the few set ups that comes from the factory with an oil cooler. Another issue with oil is low mile trips suck. You get condensation in the block and if you don't get the oil up to temp for a suitable amount of time you don't distill off the water and that forms the acid that helps get you sludge. I was pleased not to find scoring on the cams, which is more of an indicator than the dark crap. If you go back and look at my shots of the oil pan. That was all caked on. It took two hours of scotch pad, WD40, brake cleaner and simple green to get that off. Oil choice is important too. BMW changed the weight spec of the oil after the bearing incident. It went from 5 w 30 to 10w 60. This opens up plenty of debate on oil and the like. For the record I don't plan on the specified oil rather something that is higher in zinc and phosphorus.
Amsoil all the way man. I know they used to make a Z rod oil that we ran in my dads chevelle. Stuff was high zinc and phosphorus....every time we pulled the block apart it was like the thing was cleannnnn. Stuff has awesome wear protection. Not trying to steer you towards one product but +1 on Amsoil.
Lots of junk.
Old 11-05-2012, 08:03 AM
JayMac JayMac is offline
Mein Auto: what ever starts
LOL I run AMO in everything
Old 11-05-2012, 08:05 AM
Kdoherty's Avatar
Motul makes hi-po BMW specific synthetic oil, I'm not sure about the mineral contents but if BMW NA uses it, I guess that's probably good enough for a street spec S54 http://www.vividracing.com/catalog/o...4400_6671.html
edit, you posted before i got the chance to finish haha.
  • '06 325xi 6MT
Santa
Mein Auto: 95 M3
I like this guy . Me too haha ....dominator amsoil for the ski-doo's
synthetic 5w-30 in the bimmer and i don't remember what i use in the four-wheeler
Threads looking awesome man and engines looking great so far.
Lots of junk.
Old 11-05-2012, 08:07 AM
Not looking to get into oil choices. I am very comfortable with what I run and you can only put one in there so that would leave all the others out.
Old 11-05-2012, 08:08 AM
Santa
Mein Auto: 95 M3
How's the LSD coming along?
Lots of junk.
Old 11-05-2012, 12:44 PM
HakenTT's Avatar
HakenTT HakenTT is offline
Mein Auto: '91 E30
One other thing on the oil. If that was 10w60 in there it is some thick goo. Any oil left sitting on hot engine parts will do this. What is amazing is the amount of oil on the upper end weeks, or even months after this thing was run.
How many miles were on the s54 engine? From what year is it? What kid of quote did you get for mss54 reflash for swap?
BMW probably went with much thicker oil because people were reving the crap out of the engine when cold. This is why the W60 but when the oil warms up it is still 10w.
these engines rev to 8000 rpm and make 333hp, that is tremendous kinetic energy stressed on the metals. This is true motorsports engine
Old 11-05-2012, 06:23 PM
hornhospital's Avatar
D'oh, You Kids!
You need to read up on multi-grade oils. You got it backwards. It's 10W when cold and 60W when hot.
Quotes to live by:
Old 11-05-2012, 09:07 PM
+1 to Horn on the oil.
I think the reason the went to 10w 60 is simply warranty work eats into the profits. Do research on oil shear and your head starts to spin. I run the Amsoil simply because it is good and the east coast distribution center is located in Richmond, Va so I can pick up what I need. I like Red Line also but it is hard to find. Advance Auto actually carried it for about 2 months but got rid of it. Hard for anyone to buy it when Mobil One was sitting next to it at half the price. Bimmerworld said they run 15/50 in there cars. Most of the zinc and phosphorus was pulled out of the modern oils because it supposedly wreck havoc on the cats. I read somewhere that the cats had to last for a certain amount of miles but can't recall where As for the black oil goo residue, there were actually some small chunks on the strainer. I will see if I can get you a shot. I am going to play around with some WD40 on one side and some SeaFoam on the other to see what eats through the crud. Was also toying with some good old fashioned Coca Cola. Old school.
The engine was out of a 2001 will 114,000 miles. That is the info but I can't verify. I am going to have the reflash done at Bimmerworld.
I want to order the Rogue cover for the dif and will probably do that Tuesday so i can get it here for the weekend. I snoozed on one on ebay and could have picked it up for $400. Oh well, it will make a swell Christmas present for my wife.
Old 11-05-2012, 09:17 PM
BMRfanatic's Avatar
BMRfanatic BMRfanatic is offline
Mein Auto: Bad Luck 46
This thread has so much win.
Almost was late to my 1st class looking at those pictures
Nice progress Jay
-Dino
Old 11-06-2012, 06:08 AM
Santa
Mein Auto: 95 M3
Nice progress Jay
School < This Thread
Lots of junk.
Old 11-06-2012, 06:20 AM
Thanks guys! Your the best. Got a line on some Euro headers and Rogue cover last night. The internet isn't just for porn! Who knew?
Old 11-06-2012, 06:28 AM
Santa
Mein Auto: 95 M3
......ooooo euro headers very niceeeee whatya doing for exhaust then?
Lots of junk.
Old 11-06-2012, 06:32 AM
Just like everything else, no idea!
Old 11-06-2012, 06:36 AM
Santa
Mein Auto: 95 M3
I like it
Lots of junk.
Old 11-06-2012, 06:44 AM
Unfortunately the "R&D" portion of my brain is a looped video of a dog chasing it's tail.
Old 11-06-2012, 06:46 AM
Kdoherty's Avatar
if it's not going to be street legal I vote race car pipes.
  • '06 325xi 6MT
Old 11-06-2012, 06:57 AM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
With O2 simulators!!!
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
Old 11-06-2012, 06:59 AM
Every car is street legal as long as you don't get caught. Building just for D/E use.
Old 11-06-2012, 11:43 AM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
This is a modified version of my own mantra: "It's only illegal if you get caught"
My vote is straight pipes. I don't think you need post cat O2 for the engine to run properly. And it will sound great.
Which part of VA are you located? I lived in Lynchburg (ugh) for two years after my college days in Blacksburg (Go Hokies!).
My folks still run their winery on the Northern Neck.
GGC BMW CCA #443004
Join the BMW CCA!
Old 11-06-2012, 12:11 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Meh, BMWs are way too raspy and annoying with straight pipes. Plus, many tracks have a dB limit, which you may exceed with a straight-piped S54.
1998 BMW 328is
1966 Pontiac GTO
Old 11-06-2012, 01:48 PM
Santa
Mein Auto: 95 M3
Get a muffler .... even my 318 straight piped gave me a headache after about 15 minutes cant imagine an s54 monster
Lots of junk.
Old 11-06-2012, 03:26 PM
FenderBender's Avatar
FenderBender FenderBender is offline
Needs Boost
Mein Auto: Red Sled
Resonator and maybe a little muffler?
Sent from my ADR6400L using Bimmer App
Turbo Build Here
Old 11-06-2012, 07:46 PM
dc_wright's Avatar
Fed statute requires 7 year or 70K mile warranty on the CAT(s) and the emission control computer if the car has a dedicated computer. The rest of the emissions system is only covered for the duration of the basic warranty.
