leaking windshield washer reservoir or pump - Bimmerfest - BMW Forums
E46 M3 (2001-2006)
Old 11-06-2012, 06:44 AM
rruiter rruiter is offline
Mein Auto: 04 M3 Coupe SMG
I filled my windshield washer reservoir and it started leaking, slowly.
This weekend I changed my brakes so I removed the passenger side front wheel well cover to take a look.
Right behind it sits the reservoir. I noticed there is some water around the pump.
Would replacing the pump with a $7 pump from ebay fix this leak ? I am not sure if it is the pump or the seal between the pump and the reservoir.
How does the pump come out ? Just pull it up ?
04 BMW M3 Coupe SMG-II Carbon Black
Old 11-06-2012, 07:53 AM
DamienM3 DamienM3 is offline
Mein Auto: 330i
Disregard. I didn't notice this was for a M3. Sorry
2000 E46 323i | Sport and Xenon| 5MT | 208,000 Miles retired
2002 E46 330i | ZPP | ZCW | 230,000 Miles
2006 E90 330i | Black Sapphire | ZPP | ZCW | NO Turbos!
Old 11-06-2012, 10:17 AM
They don't use the same pump/seal ?
Old 11-06-2012, 10:38 AM
Mein Auto: 330i
I couldn't tell you if they do or not. I know on the 330i that I changed, it had two grommets and pumps, one for the windshield and one for the headlights. They were only a few dollars each at the BMW Dealer. I can't imagine the M ones would cost more or be different. I do know that a standard 3 series has the reservoir up top and not low like yours so that is why I deleted my post. I didn't want to confuse things and potentially make it worse.
Old 11-06-2012, 10:40 AM
I do not have the headlight sprayers.
I will see if they have the grommets for this model and try that first. I can always still order the pump later if it turns out to be bad.
Thanks for the comment.
