E36 (1991 - 1999)
Old 11-06-2012, 02:46 PM
Kiefer09 Kiefer09 is offline
Mein Auto: 1998 318is
idling problem
please help!
Old 11-06-2012, 03:09 PM
cj.surr's Avatar
cj.surr cj.surr is online now
some kid
Mein Auto: 1995 318is
Please make only one thread if you have related problems. It makes it easier for us to help you. Also... it helps if you actually have a question.
-CJ
Old 11-06-2012, 03:14 PM
Ok sorry about that and I'm wondering why it's idling weird and how to fix it
Old 11-06-2012, 03:15 PM
cj.surr's Avatar
some kid
It kinda sounds like it is idling rough. Any check engine light? And are you sure the check engine bulb is working?
-CJ
Old 11-06-2012, 03:34 PM
I will check but I'm pretty sure it is , any suggestions to try ?
Old 11-06-2012, 03:52 PM
cj.surr's Avatar
some kid
To see if the CEL is working? Turn the key to the third position (right before the starter) and the CEL should light up, along with the oil pressure light and others.
-CJ
Old 11-06-2012, 05:17 PM
nope not working
Old 11-06-2012, 05:19 PM
cj.surr's Avatar
some kid
Ok, then you'll need to remove the cluster and replace the bulb.
Here is a good DIY for removing the cluster:
http://forums.bimmerforums.com/forum...d.php?t=337504
-CJ
Old 11-06-2012, 05:22 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
I don't see or hear anything wrong. Sounds just like a BMW 4-cylinder with an aftermarket exhaust.
1998 BMW 328is
1966 Pontiac GTO
Old 11-06-2012, 05:25 PM
Ok thanks zegerman , and I will do that tomorrow as soon as I get a new bulb , what could be causing the weird idling then ? After market exhaust?
Ze German your like that mechanic genius friend everyone has haha !
Old 11-06-2012, 05:28 PM
ZeGerman's Avatar
Warm Leatherette
What is weird about your idling? Looks normal to me. Seems like you just revved it, and then the idle settled down at the correct speed as it should.
1998 BMW 328is
1966 Pontiac GTO
hornhospital's Avatar
hornhospital hornhospital is online now
D'oh, You kids!
Mein Auto: 1995 318is / 1993 325is
This^. It idles exactly like my 318.
Quotes to live by:
Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff
BMW-CCA #441426
1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia"
I NEED A NAP, DANG IT!
Old 11-06-2012, 05:30 PM
i reved it up then it sits at 1000 for a little and slowly makes its way to 500 ish
thanks for that diy too i found another one to fix my steering wheel squeak
Old 11-06-2012, 05:32 PM
ZeGerman's Avatar
Warm Leatherette
I think what you are experiencing is normal, and it looks as though your engine was not fully up to operating temperature either, which will cause the revs to hang a little bit.
1998 BMW 328is
1966 Pontiac GTO
Old 11-06-2012, 06:04 PM
Oh ok
318, idle, rough
