E34 (1989 - 1995)
#26
However, if this is not done right, the pistons could end up hitting the valves. And even if that does not happen, your idle may not be correct. The literature on this subject on google is extensive and requires careful study. There does not seem to be adjustable cams for timing chain engines. You need to be an expert at this before you attempt it on your own, be guided by one (i'm sure there may be some on these or other forums though I've not encountered any such threads here) or you need to take your car to an outfit that does this regularly. The pulleys themselves are rather cheap...$100-$200, lasts forever, is lighter than stock, and can be changed along with the timing belt to optimise labour bills. The Ebay ads for adjustable pulleys for the timing belt M20 engines promise improved performance even in daily driving. : " BMW 3 SERIES VERNIER ADJUSTABLE CAM PULLEY Cam gears are CNC-machined from AL7075-T6 billet aluminum. The 6-bolt design eliminates any chance of slippage. They allow fine adjustments to cam timing with simple hand tools. Maximize engine performance anywhere whether you’re in the pits or in your own garage. It’s a well known fact that camshaft timing plays a vital role in performance tuning. By changing the cam timing (retard, advance/overlap), you tune the overall drivability and performance aspect of the car. Even stock engines can benefit by dialing-in cam timing/overlap. Fits: BMW E21,E28,E30,E34,E36 all with the M20 engine. " So this may indeed be worth looking at further. rgds, Roberto |
#27
What's a good set to pick up? Also, are there any decent cold air intakes?
#28
Good food, good people, good times. |
