E36 (1991 - 1999)
Old 11-04-2012, 11:51 AM
FenderBender's Avatar
FenderBender FenderBender is offline
Needs Boost
Mein Auto: Red Sled
Lol
Sent from my ADR6400L using Bimmer App
Turbo Build Here
Old 11-04-2012, 12:02 PM
Kdoherty's Avatar
Kdoherty Kdoherty is offline
bimmerfest Supporting Member
Mein Auto: A redhead E90
makes me wonder what a cam'd M52 would do with only 10 pounds
Originally Posted by Los View Post
^He's been drinking beer and destroying pumpkins with brake rotors and sledge hammers.
So, pretty much just doing man stuff.
  • '06 325xi 6MT
Old 11-06-2012, 06:21 PM
Needs Boost
Mein Auto: Red Sled
Depends on the turbo Ken.
Here are the vids, looks really slow though, blah.
Turbo Build Here
Old 11-06-2012, 07:05 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Nice! Yeah, it does look slow on camera, but I bet it sure felt a lot faster behind the wheel. Even though you were in the low 13s, you've got an easy 12-second car, which I consider to be quick for a street car.
1998 BMW 328is
1966 Pontiac GTO
Old 11-06-2012, 07:11 PM
Needs Boost
Mein Auto: Red Sled
Make sure you don't associate the noise at the end with my car's exhaust lol
It has 11 second power, a 12 second track, and a 13 second clutch and tires.
Turbo Build Here
Old 11-06-2012, 07:44 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
and a camera crew that needs a tripod...
made me dizzy....but i dig very much.
with some tires and a bit of reaction time training you could be quite fast. i thought that you had an f1 set up for the clutch, tho...
df
Old 11-06-2012, 07:47 PM
Needs Boost
Mein Auto: Red Sled
F1 stage two, installed before I did any turbo stuff. IIRC correctly it's rated for 360 lbs of torque or so. I'm making plenty more than that at 20-22 psi.
Turbo Build Here
Old 11-06-2012, 07:54 PM
gotcha...thought it was somethinglike that, but yeee-haa thatsalattatorkz...were you slipping?? or just spinning tires??
df
Old 11-06-2012, 07:57 PM
Needs Boost
Mein Auto: Red Sled
One or the other lol.
I tried to slip the clutch and keep the turbo spooling off the line on my last run and that's when it really died.
I did do 20 something runs and the car had ZERO issues other than the clutch.
Motor and turbo kit will be removed soon and sold for new turbo parts.
Turbo Build Here
Old 11-06-2012, 08:19 PM
cj.surr's Avatar
cj.surr cj.surr is offline
some kid
Mein Auto: whiny 318
Nice! What's left for the new build?
-CJ
Old 11-10-2012, 03:52 PM
Needs Boost
Mein Auto: Red Sled
Turbo, injectors, tune, MAF, wastegate, bov, intercooler, exhaust, piping, couplers, Tranny, clutch.
Nuttin really lol.
Turbo Build Here
Old 11-11-2012, 10:40 PM
Eight Thirty Eight Thirty is offline
Hellawut??
Mein Auto: who knows?
Why don't you sell the motor with the turbo bolted to it?
New turbo top mount? Still trying to find a 6sp?
Sent from my Desire HD using Bimmer App
-Franklyn
Old 11-12-2012, 04:02 AM
Needs Boost
Mein Auto: Red Sled
It's just an M50 with oil leaks and a leaking hg and S50 cams lol. Nobody wants that.
I want 6 speed meow so I can drop it in together.
Yes top mount turbo.
Turbo Build Here
Old 11-20-2012, 09:19 AM
Poeman446 Poeman446 is offline
Mein Auto: 1995 BMW 325i
Help?
Ive been reading through all of this and I'm new to turbos. I still havent decided whether I want to turbo an M50 or an M20 engine. I like the M50's much better. I have a question about what i need to physically run the turbo system. I understand the hardware, but as far as tuning, can I get a chip to plug into the DME (OBD I) and then I'm set to go? I don't know how that controls spark advance/retard and fuel. Do I need to get a piggyback ECM or do I need a complete new ECM? Also, For a turbo controller, what does that even mean/ Ive tried doing research, and even on noob forums im a bit lost. Any good books to read on the topic? Im looking at one now called "Performance Fuel Injection Systems" by Matt Cramer/Jerry Hoffmann. Its mainly for V8 systems, and everything is specific to them.
Thanks in advance. SICK car man. Very well done.
Old 11-20-2012, 04:22 PM
Needs Boost
Mein Auto: Red Sled
I don't know much about the M20s so I can't help you there.
Yes, if you are OBDI you just plop a chip in your factory computer. Easy as that. You'll want gauges to monitor things to make sure the tune is pretty close. As far as tuning you have many options.
TRM
Technica
Technique tuning
Miller
Nick G
Roadkill tuning
Dunno about books, but I am looking to get into tuning sooner rather than later and I need to start reading up myself. Thanks!
Turbo Build Here
Old 11-20-2012, 06:28 PM
just make sure that the tuning books you are reading up on are in regarding engine management, not pianos...
df
Old 02-22-2013, 03:30 PM
Needs Boost
Mein Auto: Red Sled
Evo shifter, DSSR, and clutch are here.
You can see I have the updated flywheel with the machine work already done. Of course, it came with no instructions (the clutch) or torque measurements.
Turbo Build Here
Old 02-22-2013, 03:32 PM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
105 ft/lbs on the flywheel and 25 on the PP.
Or so I've read! You should double check.
GGC BMW CCA #443004
Join the BMW CCA!
2005 X5 4.8is Le Mans/Black/6spd Steptragic SOLD 3/2016
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual FS
Old 02-22-2013, 03:45 PM
E36 Phantom's Avatar
I Am The Machine
From the engine swap I thought I recalled the flywheel torque setting being "grab a breaker bar and jump on it till it seems really tight"
// Chad //
// 1999 Chevy Tahoe //
You're a derbanana
Old 02-22-2013, 08:12 PM
and if you are short like me, a running start is advised...
matt, that flywheel is awesomesauce!! never saw anything like it!! essplain me...naowh!!!
btw, reading this makes me salivate all over again....this sort of thread *really* makes me pause at what i really want to do with the ti....turbo m52 w/cams, or small block swappy...
luckily, i haz plenty of time....
df
Old 02-23-2013, 06:06 AM
Needs Boost
Mein Auto: Red Sled
Thanks df!
Uuc twin disk feramic. They haven't been out long. There are people running them with 1000 (way higher than what I'll be aiming for)
Sent from my SCH-I605 using Bimmer App
Turbo Build Here
Old 02-27-2013, 04:25 PM
Needs Boost
Mein Auto: Red Sled
No real updates, still need to get the 6 speed sorted out.
In the mean time, I put my shifter together.
Turbo Build Here
Old 02-27-2013, 04:40 PM
petriej's Avatar
It's backwards. The shift lever should lean towards the pointed end of the shift arm.
GGC BMW CCA #443004
Join the BMW CCA!
Old 02-27-2013, 04:51 PM
Needs Boost
Mein Auto: Red Sled
It swivels :}
Turbo Build Here
Old 02-27-2013, 05:07 PM
petriej's Avatar
Indeed.
GGC BMW CCA #443004
Join the BMW CCA!
:3
