Old 10-26-2012, 08:51 AM
Bob H. Bob H. is offline
Mein Auto: 1998 740i
Question Steering Wheel
My steering wheel squeeks. Where do you apply lubricant to stop the squeek 1998 740i?
Old 10-26-2012, 07:03 PM
sealbeach740 sealbeach740 is offline
Mein Auto: 2000 740iS, 2003 540iS
If it were my car, I'd first try to push up on the bottom clam shell that's under the steering wheel column. If that doesn't change (no squeak, or a different sounding squeak), then try pushing down on the top clam shell.
If nothing else, it will remove the clam shell from the test equation.
Is the squeak just from turning the steering wheel left to right, or is it also from moving the steering wheel up & down, in & out?
2000 740iS. MKIV, 16x9, DDEs controlled by Euro fog light switch, reversed steptronic +/- pattern, paddle shifters, clear corners, Basslink, iPod video with stereo audio, TV tuner, gauge rings, ///M pedals, backup camera with 'on demand' switch, quad brake lights, Dinan engine & tranny software, windows/sunroof close via remote.
2003 540iS. MKIV, 16x9, PDC, CWP, TV tuner, backup camera with 'on demand' switch, paddle shifters, windows/sunroof close via remote, iPod video & audio.
Old 11-05-2012, 03:04 AM
mgoods50 mgoods50 is offline
OBDI Junkie
Mein Auto: E36 M3
to the area that is squeaking... sorry- could not resist that.
but seriously-- you must determine exactly what is causing the squeak. It could be bushings or the column trim.
It's not what you buy, it's what you build- Unknown
EN90283 - Stabled for HG repair
DH06247 - Running like a champ
Old 11-06-2012, 11:32 PM
BMWFatherFigure's Avatar
Old School
I M experience it will be the horn contact slip ring, Easy to get at. Use metal based 'Never Seize' on it. I think you guys also know it as "Spark Plug Grease'.
Current:
E38 Parts Car
Previous:
Old 11-07-2012, 08:01 AM
OBDI Junkie
Mein Auto: E36 M3
Ha Ha... I thought that was the result of leaking VCG...
