Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > E60 (2004 - 2010)
E60 (2004 - 2010)
BMW 5-Series (E60 chassis) was first seen in the Unites States in the fall of 2003 with a 2004 Model Year designation. The E60 is now available as a 528i, 528xi, 535i, 535xi, 550i and a 535xi sports wagon! -- View the E60 Wiki
Old 10-26-2012, 11:46 AM
benc008 benc008 is offline
Mein Auto: BMW 545i and Audi A4
Exclamation *** My Tires Are Getting Destroyed ***
I have a 2005 545i and my tires are getting destroyed!
BMW sport suspension - factory
Front tires: Falken FK-452 245/30/20
Rear tires: Falken FK-452 285/25/20
Wheels: 20' DPE R06
The wheels are aligned and I rolled my fenders - BUT the inside part of the tire is getting worn out until air leaks out.
How can I stop this from happening to new tires?
ID:	347491   Click image for larger version
Old 10-26-2012, 11:55 AM
watchurself watchurself is offline
George
Mein Auto: 2002 bmw 4.4i x5 sprts pg
Its related to CAMBER from what i understand - someone who knows more will chime in I'm sure
but this is common on some BMW's where the inside of the tires wear more due to a camber being off
GEORGE
"EVERY FORM OF REFUGE HAS IT'S PRICE"
2002 4.4i BMW X5 - 166K Topaz Blue Ext/ Tan/Beige Leather Int
1994 Nissan Pathfinder SE 132K Black Ext / Grey Leather Int
Old 10-26-2012, 12:36 PM
v8power v8power is offline
Mein Auto: 2008 550i M
Remember, incorrect toe setting will eat tires more than anything. Almost if not all cars on the road has negative camber.
Have another shop check/redo alignment. Not all shops or mechanics are equal.
The dependable- 2011 Acura MDX Advanced
The garage decorator- 2008 BMW 550i M Carbon Black
2013 Triumph Daytona 675R
Old 10-26-2012, 12:41 PM
tomstin tomstin is offline
Mein Auto: 2005 525i
Have another shop align the car. My guess is the camber may be fine sitting still, but when you turn its getting out of wack.
2005 525i sport, manual transmission, Dension Gateway 500 with bluetooth
Old 10-26-2012, 01:07 PM
TRS550 TRS550 is offline
Mein Auto: 2007 550i
Your car is set at a fairly negativer camber in the rear. It's how a 4000 lb car can be made to handle as well as a BMW. Negative camber causes wear on the inside edges of the tire. The fact that you've chosen to put 20's on the car only serves to exagferate that wear.
I suggest taking the car to an alignment shop that is familiar with BMW suspension setups and ask them to realign the car and to set the rear camber at it's least negative value and still be within spec.
Putting the stock 18's back on will help as well.
Old 10-26-2012, 02:52 PM
It's not just the rear tires. Both the front and rear tires are rubbing on the inside. What should the camber be set at for the front and rear? Since the tires are rubbing, should they be at zero camber or slightly positive?
Does anyone have actual Hunter alignment specs to prevent rubbing for my car?
Old 10-26-2012, 03:11 PM
dolfan13's Avatar
dolfan13 dolfan13 is offline
Mein Auto: 545i
Stock sport 545i 18" conti DWS and 20k shows less than half wear.
Old 10-26-2012, 04:08 PM
Ninjapotamus Ninjapotamus is offline
Mein Auto: E60/E90
i had this problem when i put my M5 wheels on. it was due to the tires being too wide and aspect ratio being a bit higher for m5. mine are only 19's
Old 10-26-2012, 05:24 PM
Ninjapotamus - what was your tire size and brand? Were you able to fix the problem?
What should be the correct tire width and aspect ratio for 20" rims?
Old 10-26-2012, 05:30 PM
Mein Auto: E60/E90
idk correct sizing for 20's but i think your main problem is ma be the 285 width. idk what others run
tires that were rubbing were 255/40/19 front and 285/35/19 rear pirrelli pzero rosso
i replaced with factory size of 245 35 19 front and 275 30 19 rear
Old 10-26-2012, 05:35 PM
I have a friend with the same exact car, rims, and tires and his tires are not rubbing. He has H&R coilovers though ... and I have factory BMW sport suspension.
Old 10-26-2012, 05:37 PM
Mein Auto: E60/E90
i am on factory sport too. mine were rubbing on passenger side. i thought it was weird and i am a bit disappointed as i was looking forward to rocking the bigger tires, + the replacement cost me 1300 since i had to do it in a pinch and couldnt wait for tires to be ordered.
Old 10-26-2012, 05:58 PM
Ninjapotamus - were your tires rubbing on the inside ... and after you did an alignment?
Old 11-01-2012, 05:07 AM
kskane kskane is online now
Mein Auto: 2004 BMW 525i Auto
I have an '04 E60 with sports suspension and 17" alloy, and same problem inside would wear off similar to rear tyres i.e. rear tyres wear off quicker than front, so when my rears are near gone, my front is okay but the inside of the front is gone. My tyre fellow said it because when turning, I should not take a full swing at the steering and my wheel alignment fellow said it is because my front tyres have low pressure compared to back ones. I don't trust any one of them, but yet to find out what is the real cause of fronter tyres wearing off from inside...................
Old 11-01-2012, 07:51 AM
Phil75070 Phil75070 is offline
Mein Auto: 545i
Had the same thing occur but only with the rear tires and, yes, attributable to the camber. Rear tires, as a result, wear twice as fast as my front tires and because tires can't be rotated the "warranty" mileage is typically halved if honored at all.
2005 545i, Jet Black, Black Leather, Cold Weather pkg, Logic7, 6 disk changer, Sport Package, Automatic, moonroof, electric rear sun shade, dark wood trim, PDC, Xenon Adaptive lights, Nav, Sat radio, 245/40 ZR18 - 275/35 ZR18 tires, Progman 30.02
Old 11-01-2012, 08:08 PM
booyaazaa's Avatar
booyaazaa booyaazaa is offline
Mein Auto: '09 AW 535i
You can try to have the alignment shop dial out your camber as much as possible to minimize the negative camber effect. However it will change the handling characteristics of your car slightly. I will say that the falkens I've put on my BMWs and Lexus tend to wear pretty quick on the inside part of the tire.
2009 AW 535i
-Sport, Premium Package, and Comfort Access
-20" Forgestar F14 Black Gloss, Cobb PTF E30 map, KW V2 CO's, Remus Sport Exhaust, BMS DCI, RPI Scoop, Full Front 3M PPF, 35% tint all-around, Orion V4's, Bruce v6.1L cables, LED interior lights, WeissLicht License Plate LED, Trinity Smoked LED side markers, Bimmian Smoked Reflectors, OEM black gloss grills, and Invisibulb turn bulbs.
Old 11-02-2012, 02:00 AM
GOR777's Avatar
GOR777 GOR777 is offline
Mein Auto: 2007 BMW 550I
a week ago I replaced the wheels and the tires on my car with 650i rims and m6 tires
255/40/19 at the front
285/35/19 at the rear
front ones are rubbing a little it seems like I need to pull out the front fenders a little (which I dont know how, correctly)
but looking at these specs, should I be aware of the same problem or no? if my car has the right alignment will it be fine or do I need to downgrade the tires?
Old 11-02-2012, 02:33 AM
SoLucky SoLucky is offline
Nothing to see here...
Mein Auto: '08 535i
If the tires are rubbing against the strut -- most likely the spring perch on the strut body -- then tweaking alignment settings will have no benefit. So first order of business is to determine where the tire is rubbing and then try one of the below fixes (which will potentially cause a new problem) until you solve the problem:
rubbing on inside of tire -- add a wheel spacer (5 to 15mm), switch to coil-over suspension (which typically have a much smaller diameter spring and give more tire clearance).
rubbing on outside of tire -- remove wheel spacer (if you have one), increase negative camber, flare fenders.
rubbing when wheel turned to extreme right or left -- reduce negative camber, switch to a lower profile tire, reduce tire width.
If you can't completely solve a rubbing problem, you may need to return to a stock (or near stock) tire size. These cars were designed for certain tire sizes and wheels (diameter, width, offset) and straying too far from stock sizes will cause rubbing -- there is just no way around these limitations.
________
2008 535i - Monaco Blue/Tan Leather, Sport, Premium, Cold (+ heated rear seats), Navi, HUD, PDC, CA, Sunshades, Fold down rear seats, CPO, Extended Maintenance
Old 11-02-2012, 02:42 AM
GOR777's Avatar
its rubbing outside of the tire and its only when there is a bump on freeway at speeds of 60mph+ and when there is a big bump or pothole on the streets, other than that it seems fine, I did kind of rolled the front fenders, it worked a little but seems it needs to be pulled out a little more.
Old 11-02-2012, 07:52 AM
WJGreer's Avatar
WJGreer WJGreer is online now
Mein Auto: '05 545i
If you look at an E60 from the rear, the toe-in camber is quite noticeable. Increased wear on the inside edges of the tires is happening by design.
You may be able to convince your mechanic to align the tires with a slightly less extreme camber setting. This will affect the car's handling academically, but if you drive it like 90% of us do you may never notice.
-Will
2005 545i Sport | 2001 X5 3.0 Sport (Retired)
Old 11-03-2012, 07:54 PM
MRV99 MRV99 is offline
Mein Auto: 2011 M3 DCT
Welcome to a heavy ass car with power which still is a noble sports car. The e60 eats tires due to power and negative camber for the handling. I had a e60 for 6 years and the same wear pattern happened. I had 4 different brands of tires as well as running winter set for the enter time. Drive with any pep the tires will fade away.
12 X5 50i Sport
11 M3 DCT
11 X5 50i (lemon)
-- SOLD --
08 550i M-Sport
04 BMW 545I sport
07 BMW X5 4.8I sport
02 BMW X5 4.4i sport
01 BMW 540I M/sport
00 SL500
97 SL500
Old 11-03-2012, 08:02 PM
E36 Phantom's Avatar
E36 Phantom E36 Phantom is online now
King of the Ballers
Mein Auto: Dreier, Fünfer & Siebener
Looks like too much toe to me.
Camber is NOT usually the issue with wear like that
Sent from my Galaxy Tab using BimmerApp
Chad // 2001 BMW 740i M-Sport // 2000 BMW 540i Sport // 1997 BMW 328i Premium //
E38 16" Style 5 Basketweaves, M52 Parts, and New Gaskets/Seals for Sale!! PM for info. .
Originally Posted by SlimKlim View Post
You're a derbanana
Old 11-03-2012, 08:38 PM
My rears have looked like this and the alignment/toe and every other measurement was spec. Does the OP drive spirited?
12 X5 50i Sport
11 M3 DCT
11 X5 50i (lemon)
-- SOLD --
08 550i M-Sport
04 BMW 545I sport
01 BMW 540I M/sport
00 SL500
97 SL500
Old 11-07-2012, 10:00 PM
CarGuyHere CarGuyHere is offline
Mein Auto: 535Xi before a 330Xi
Same thing just happened to me!
http://www.bimmerfest.com/forums/sho...d.php?t=656875
What did you end up doing??
And if you set it up, not factory spec, what specs did you use??
452, dpe, falken, fk, rims, rubbing, tires
