E34 (1989 - 1995)
Old 11-07-2012, 10:18 PM
5seriesman 5seriesman is offline
Mein Auto: 1991 bmw 525i 5 speed
1991 bmw 525i dont like the cold weather
I have a 91 BMW 525i 5 speed! It will run fine in warm weather but as soon as it gets cold I will start it up to leave work and it will start reving up by its self and stay at a higher rpm then normal untill the engine heats up then it will run fine! Has any one else had this same problem and how can I fix it?
Old 11-08-2012, 12:13 AM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
try wiping the error codes on the ECU. may just be that simple. if it doesn't then read the codes that it throws.
Being a 91 model, do you know if it is the M20 or the M50 engine? that was the changeover year
E30 above Sold
Last updated 2nd January 2014
Old 11-08-2012, 12:28 AM
Banned
Mein Auto: car
The car runs at higher rpms at idle when cold, to heat itself up faster.
Old 11-08-2012, 01:37 AM
How do you wipe the error coded and what do you mean by change over year? Actually idk if its a m 50 or m 20 how could I tell?
Old 11-08-2012, 02:51 AM
Costa's Avatar
Costa Costa is offline
Mein Auto: Supercharged E34 540i6
Google the difference, if you don't feel like it - is the intake manifold black and made of plastic or is it silver and made of aluminum. Better yet, if you can. Take a photo of the engine bay and post it on here.
Old 11-08-2012, 03:58 AM
I sure will as soon as I wake up ill post a picture in the morning
Old 11-08-2012, 04:36 AM
Banned
Mein Auto: car
Google please. There are lots of very nice pictures of both types of engines online, you'll want to see it.
Old 11-08-2012, 09:24 AM
supertech777's Avatar
supertech777 supertech777 is offline
Mein Auto: 1995 525i
Sounds like you have a vacuum leak , it revs high when cold and when the rubber expands when its warmed up it seals . Spray for vacuum leaks around the intake .
Sent from my Desire HD using Bimmer App
Old 11-08-2012, 10:32 AM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
You may also have a bad temperature sensor (air temp or water temp).
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 11-08-2012, 11:20 AM
1995i540's Avatar
1995i540 1995i540 is offline
Founder @ Maintenr
Mein Auto: 1995 540I/6
Yet another stupid post.
As other person above me suggested this is most likely a result of unmetered air entering the system. Do a propane/start fluid/brake fluid test or a smoke test if you can.
Temperature sensors would not cause your car to rev it self up to compensate mixture.
///////////////////////////////////////////// E34 Addicts
Founder @ Maintenr. Take control of your vehicle maintenance.
Old 11-08-2012, 11:38 AM
Not true, but what i think you are meaning is that the trans shifts later when cold. However, before posting anything like this, you need to know what engine is in the car. if its the M20 engine, it did no have this feature. if its an M50, its actually the transmission that shifts later, it has nothing to do with idling differently. the transmission and engine control units cooperate on the M50 setup, but the M20 is mechanically operated, not electronic. As anybody that knowss how an engine works, raising the idle with no load on the engine is not good for it and creates carbon buildup etc
all of these maybes can be solved by scanning the engine. Both the M20 and M50 have fault diagnostics built into the ECU, why would you start anywhere else?
E30 above Sold
Old 11-08-2012, 01:12 PM
1995i540's Avatar
Founder @ Maintenr
Just FYI un-metered air, depending where it's at might not throw a CEL code. For example 2-3 bad o-ring on fuel injectors will cause misfire and rev adjustments but will throw CEL maybe once a week.
Old 11-08-2012, 05:07 PM
Banned
Mein Auto: car
This is incorrect, at least for the M50 engine. When cold, the car's idle is around 250-300 rpms higher and the gear shift points are also later (for automatics). These two features are there to generate more heat and to heat up the engine faster.
An engine takes anywhere fro 6-10 minutes to reach operating temperature from cold, depending on whether you're idling or driving throughout. Optimal temperatures ensure that the most efficient combustion is taking place and thus the least amount of fuel is wasted (there may be other reasons as well), according to the engine's design.
rgds,
Roberto
Old 11-08-2012, 11:13 PM
i have the m50 engine in my car and i just looked and my vacume hose has a crack in it! I do believe thats whats causeing the problem
Old 11-09-2012, 06:13 AM
Cool + 1
