Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series > 7 Series - F01 (2009 - current)
The new re-designed 7 series leads off the BMW Fxx chassis code!
Old 10-20-2012, 06:29 PM
ZottiBMW ZottiBMW is offline
Mein Auto: 2006 BMW 530i
This might have already been asked but... My question is, do they fit right in or will you have to make modifications to the bumper and hood?
2006 530i Alpine White, Tan Interior, Sport, Adaptive Xenons
Old 10-20-2012, 07:17 PM
f01driver f01driver is offline
Mein Auto: 750i, S5
The headlamps fit pre-LCI fascias, you don't need to change the bumper or hood.
2011 750i
Old 10-25-2012, 03:49 AM
bmw1928 bmw1928 is offline
Mein Auto: E90 N52B25(2005)
maybe the pinouts of headlamps same with e71 facelift????
Old 10-29-2012, 03:55 PM
BMR2009's Avatar
BMR2009 BMR2009 is offline
Munchen bound
Mein Auto: Ferrari
Dang! And I thought I was out of control. That is some serious "I"m going to keep my car a long time" money. I can't wait to see the final product.
2009 750Li
400bhp! Milano/Saddle / Lux seating / camera / prem sound / sports pkg / convenience pkg / rear entertainment / heads-up display / iphone integration / 9.14 ED
Dropped in Munich on 9/18, Redelivered in Brunswick, GA on 10/12 by ELEKTRA. Delivered to my home on 11/2.
Old 10-30-2012, 02:05 AM
ChrisF02's Avatar
ChrisF02 ChrisF02 is online now
MCHTSCHNL
Mein Auto: 2013 750i
Haha, pricey indeed. I'd consider just trading it in after the first 2-3 grand.
2013 BMW 750i - Coded, Executive, Lighting, Cold Weather, M Sport, M 303 Wheels, 5% Tint, Conti DWS Tires, 3M Bra, Front DE Plate.
Old 10-30-2012, 03:50 AM
itschase itschase is online now
Mein Auto: F02 750li / E92 335i
Then you'd owe 100K for a new car. What if yours was almost paid off? Or does no one purchase anymore?
Old 11-08-2012, 12:14 AM
Loucas4u Loucas4u is offline
Mein Auto: BMW 116i
Cool Retrofit LED
Hi,
I am trying to retrofit this LED. I have done the wiring but the headlights does not work. The LED headlights has K-CAN line the Bixenon does not have this line. I will try to encode it but i am not sure.
Old 11-08-2012, 12:17 AM
AA9999 AA9999 is offline
Mein Auto: BMW 750
Originally Posted by Loucas4u View Post
Hi,
you need to buy new FRM-3 block and ZGV block
Old 11-08-2012, 12:23 AM
Mein Auto: BMW 750
ECU, footwell module 3
Control unit, central gateway module
but you need this units from LCI model
Old 11-08-2012, 12:32 AM
Mein Auto: BMW 116i
I have them. just install and it will be ok? or i need coding?
Old 11-08-2012, 12:44 AM
BaranE BaranE is offline
Mein Auto: '10 740Li
You'll probably need some coding too imho.
Old 11-08-2012, 12:59 AM
Mein Auto: BMW 116i
I took the module from a new facelift car and i install it to non facelift module. I try to encode it with the original bmw software but no luck.
Can you give me more help please?
Old 11-08-2012, 01:11 AM
Well the pinouts might be different. did you double check the wiring and whether any pin locations were changed between units?
Old 11-08-2012, 01:31 AM
Mein Auto: BMW 116i
I have change the inputs.
Pin 1 the left headlight, from Pin 50 to pin 13 (FRM)
pin 2 as it is
pin 3 as it is
pin 4 to pin 7 of the headlight
pin 5 as it is
pin 10 to pin 8 of the headlight
pin 9 to k-canH
and installe new wire to pin 10 for k-canL
Old 11-08-2012, 02:11 AM
Mein Auto: BMW 116i
do i need to order the new ECU or take it from a facelift car?
Old 11-08-2012, 09:35 AM
Mein Auto: BMW 750
shure! if you install led lamp with cic you need ECU from facelift with optic
if you install nbt you need ECU w/o optic
Old 11-08-2012, 09:42 AM
I don't understand, why would you need to change the CIC and what do you mean with optic?
Old 11-08-2012, 10:06 AM
Mein Auto: BMW 750
i`am in my f01 install LCI LED lamps and NBT-LCI navi system.
if you wont to add only led lamps you need ECU with optic
if you wont to add LCI LED and LCI NAVI you need ECU w/o optical output
Old 11-24-2012, 08:47 PM
Did they do away with MOST integration for HU_NBT? Crazy...
Old 11-27-2012, 07:13 AM
ras31 ras31 is offline
Mein Auto: 2009 750Li
So, how does one remove the headlight assembly?
Old 11-27-2012, 08:23 AM
Sonic Boom Sonic Boom is offline
Mein Auto: 7 series
Originally Posted by truckster View Post
Sure I will let you know! Now I'm waiting for other electrical parts to complete the installation
Hi Truckster, any progress? We await your (hopefully successful) results in eager anticipation.
Best of luck!
Old 12-04-2012, 05:47 AM
i want to install only headlamps and taillights.i know that i must change FRM
Do i need to change ZGM too ?
Old 12-04-2012, 06:08 AM
Mein Auto: BMW 750
for the taillights you dont need any block, just plug&play, but for headlights you need a facelift FRM3 and ZGV module with optic 451. for ZGV 449 you need Hu_NBT and CAS4 too
Old 12-04-2012, 08:11 AM
How can i know which modul i need.61359291451 or 61359291449.in car(F 02 2010 year) ZGM modul with optic.
Old 12-09-2012, 10:52 PM
Mein Auto: BMW 750
you need this 61359291451
