Old 11-07-2012, 07:39 AM
Ferndell Ferndell is offline
Mein Auto: 2012 X5 Xdrive diesel
Exclamation Putting X5 off the road for 6 months
Hi all, I am going to be out of the country for 6 months so my X5 will be in the garage. With all my previous cars I would disconnect the battery (good security and stops the battery getting run down by the car), but with the X5 I have been told that this is not the right solution. Also those geniuses in germany built an SUV that does not have a manual way to open the trunk (no key access!!). I would appreciate any advice available as to how I could remove the battery and still be able to lock the car and then re-open the trunk on my return to install the battery again.
Old 11-07-2012, 07:48 AM
d geek d geek is offline
diesel evangelist
Mein Auto: Volvo V60+ Volvo S80
Aren't there jump-start terminals inside the engine bay that are remotely connected to the battery? If so, you can temporarily connect your battery to those points in order to open the hatch.
I would add biocide, Power Service Diesel Fuel Supplement, and fill your tank to the brim. Also put your vehicle on jackstands to avoid flat-spotting the tires. If you have any concerns about rodent infestation, I've read that the fabric softener sheets for your drier are good for repelling them.
Old 11-08-2012, 08:05 AM
UncleJ UncleJ is offline
Mein Auto: '09 Cayenne "S"
Just make sure you take the dryer sheets out before recommissioning the car.
