Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > BMW Diesel Owners & Enthusiasts
Do you own a diesel powered BMW? Maybe a 335d or a BMW x35d? Come and talk about what makes your car great!
Old 11-02-2012, 12:40 PM
elester12 elester12 is offline
Mein Auto: F30 335
Anyone Have The Follow Fault Codes?
Hello all,
My check engine light comes and goes normally but has finally decided to stay on. I scanned it with my bavarian technic tool and found the codes 4D02 and 4804. It's in German but translated it says, "Reducing-agent pressure buildup".
Anyone know which SCR pipe would have the buildup? I've about had it with this car.
Old 11-02-2012, 01:41 PM
floydarogers's Avatar
Pedant and Curmudgeon
Have you had the recalls done? If not, get it done - they change the injector. If yes, you should be covered by BMW's warranty on replacement parts.
If you're below 70K miles and in one of the 13 CA emissions states (Maryland is one), you're covered, too.
Old 11-02-2012, 06:00 PM
GreekboyD GreekboyD is offline
Mein Auto: 2009 BMW 335d
Closest fault codes I see on the list are:
4D03 Exhaust Backpressure Sensor Bank 1
4803 Torque Control ACC
480A DPF -Bank 1
I'd say it's related to your DPF.
Old 11-08-2012, 11:42 AM
Mein Auto: F30 335
Fault codes 4D02 and 4804 are related to the urea pump under the rear of the car. The pump was not building up pressure. You have to drop the exhaust to get to the pump above the tanks. 6 hours of labor plus 300 ish for parts if you have this done out of warranty at a BWM dealer.
I'm praying for a service manual to be written for this car.
Old 11-08-2012, 07:21 PM
Flyingman's Avatar
Flyingman Flyingman is offline
hang up and drive!
Mein Auto: 335d
Extended warranty, get it!
2010 Black 335D Sport/Premium, Michelin PSS 235/265 (100k Club)
2000 Silver Z3 3.0i (Ret)
1999 Silver R1200C (Ret)
1968 Black 1600 Coupe (Ret)
Old 02-08-2013, 08:29 PM
quasimodem quasimodem is offline
Mein Auto: 2009 335d
Hello all,
I cant figure out what 4804 is and I have it showing. I also have 4A66 and 4B90. The first appears to be Power Management Vehicle Electrical system (maybe an old battery) and the second is Rail Pressure Control at Engine Start.
Yikes. Any idea what parts need to be replaced, the entire DEF pump? Or just a valve cleaning?
Okay, see ETK printout below. I see two main suspects -- the pump unit (16197205041 $507.84 at Tischer) and the Supply Module (16197244137 $299.45 at Tischer), any guesses as to which would be causing a 4804 fault code?
Old 06-23-2013, 09:25 PM
Bump, any resolution to the 4804 question? Is it the pump unit or the supply module?
Old 06-23-2013, 10:00 PM
Hoooper Hoooper is offline
Mein Auto: 335D
This is the most complete list ive seen but no 4804 http://www.endtuning.com/bmwcodes.html#DDE6
Old 12-21-2014, 02:00 PM
9mmkungfu 9mmkungfu is offline
Mein Auto: BMW 335d
Was this ever resolved? If so, could you post the details?
Old 01-21-2015, 07:35 PM
Mein Auto: BMW 335d
Still interested in the 4804 code if anyone else has seen it.
Old 05-22-2016, 12:12 PM
dadasracecar dadasracecar is offline
Mein Auto: e90
I have this code now persistently. Any information from those that have had this situation resolved would be greatly appreciated. TIA.
Old 05-23-2016, 04:57 AM
Mein Auto: BMW 335d
I ended up removing the SCR system and haven't had any related codes since.
Old 01-18-2017, 09:39 PM
rs0xn rs0xn is offline
DO IT
Mein Auto: 2011 X5 3.5d
I have a 2011 x5 35d. I get this error 4804 every time this year in January. This is the second year I've gotten it. The cold weather and thawing and back to cold seems to trigger something. Car is not under warranty anymore, bmw said to replace scr module sensor. My Indy mechanic said monitor it and replace if needed. His price was $1400 parts labor. After clearing the error last year it went away, but has resurfaced today. I use the Carly app to clear code. Is there any long term problems that could damage vehicle by clearing fault and ignoring issue. Like I said it only happens at beginning of winter here in CT. I'm also driving 15 miles city to from work. Not sure if car has enough miles / heat to start regen the filter and burn off diesel crud.
Is this just an emissions issue? Is Connecticut within the 13 states you referenced?
Does anyone have the recall number or something I can reference back to bmw about this recall I keep hearing about. The x5 just had a 60k mile service done by my Indy shop.
Sent from my iPad using Bimmerfest mobile app
______________________________________________
2011 BMW X5 3.5d (Sport Activity Pkg, 19" Y-Spoke Wheels, Premium Pkg, Technology Pkg) 3M CS20 Window Tint
HTML code is Off
