Old 11-08-2012, 05:32 PM
GSG1 GSG1 is offline
Mein Auto: 07 X5 3.0, 07 525i
Transmission Oil Change
Hi, I'm a new E60 owner. Its an 07 525i with 95k kms (60k miles). I heard the transmission oil on these is lifetime. I don't buy that and I was wondering when I should change the tranny oil? any opinions based on your experiences ?
Also, What what kind of change? flush? drain and fill?
Any input would be appreciated.
Old 11-08-2012, 05:41 PM
DIY'er
Mein Auto: 2004 545i
I would recommend you change it now. http://thectsc.com/ has the oil (only use ZF, I don't care what anyone else tells you you can possibly use).
I did a video somewhere of changing the entire mechatronics unit (valvebody), but it shows pull pan off which should show you what you'll have to do if you're doing it yourself.
Make sure to reset transmission adaptations (via INPA) right after changing the fluid. When I first changed mine it jerked and bucked and was HORRIBLE to drive--I thought I was going to need a new transmission, but a reset in INPA made a huge difference. I then changed out the solenoids in the valve body and that finished fixing all of my issues (but I have 180K miles)
Anyways. Yes, change it. You can only change about half of it at a time (other half is in torque converter, etc.). Some people recommend changing half now and changing again in a few weeks so you get most of the old out.
Change the filter as well. It's built into the oil pan (plastic). thectsc sells a kit with oil and filter
I would not recommend a flush. Just drain and fill, maybe twice.
Again: RESET ADAPTATIONS afterwards. I tried the "hold the pedal down for 30 seconds with the engine off" thing and it didn't do squat. You need access to BMW software
Old 11-10-2012, 06:57 PM
mfrasca mfrasca is offline
Mein Auto: 550i
Anyone in the Boston area I had custom fittings made for my transmission flush machine and it works great. Full system flush right through the cooler lines.
Old 11-16-2012, 12:33 PM
salexander salexander is offline
Mein Auto: 530i
Serpetine belt change?
DIY or ?
Old 11-16-2012, 07:26 PM
Oceans10's Avatar
Oceans10 Oceans10 is offline
Mein Auto: BMW 535i + 535XI wagon
Originally Posted by salexander View Post
DIY or ?
You could, but it requires pumping fluid back in and resetting some menus as described.
You need a lift to do this work and good tools. Might also need some new magnesium bolts, there are 21 of them i think.
I had it done recently by an indy. I brought the new pan (from ECS Tuning, $115, ZF stamped) and 7 quarts of transmission fluid. The car holds 9 quarts, but 3 of them are in the torque converter. I just added 6, which should be fine to mix with the remaining. It is rated lifetime, so adding 2/3rds fresh should be more than sufficient.
Now, key point: The main reason I did this on my 2008 E61 was to also replace the mechatronic valve sleeve. It's a $16 piece of tubing that separates electronics from the tranny fluid. Over time the original sleeve gets brittle and the seal leaks. This will cause the tranny to go into Park and throw a failure code. Happened on my sedan of same vintage.
The new updated sealing sleeve has a better, more durable design. So replace this and you will likely never have this problem, which is well documented and covered in BMW service bulletins and NHSB literature.
Audio: Jehnert Flatline speakers, Mobridge M1000 DA2 prepro, Helix P-DSP, Zapco Z-150.6 amp, CIC iDrive upgrade
Performance: MHD Pro Tune, AR Downpipes, ER FMIC/CP, DCI, RB turbos and inlets, KW V2 coilovers, Fuel-It Stage 2 pump w Ported fuel rail, Mfactory LSD
Old 11-17-2012, 09:22 AM
DIY'er
You don't need a lift or any special tools. Just a socket set, allen wrench and torx bit.
I'm sure it's a lot easier on a lift, but I have done it on the ground with just jack stands
The seal is a royal paint to get out, at least on the 6hp26's. On mine it looks like I needed to remove a mount on the back of the transmission, but I didn't have any female torx sockets so I didn't end up changing it
