Old 03-20-2011, 11:18 AM
rwfisher rwfisher is offline
Mein Auto: 2005 M3Cic
CCV question
My wife's X3 had difficulty starting this AM, and when it did finally start it was with a good deal of oil smoke from the exhaust. Checked the oil level then took the car for a spin around the block. Seemed to run OK, no further smoking.
Also checked the battery...it needs replacement, so I'm taking care of that now. Regarding the smoke however, this seems to fit with the CCV sticking that people have described especially since we've had no oil (or smoke!) related problems in the past. My question is the sticking transient, or is it a terminal failure of the part?
Thanks!
R
Old 03-20-2011, 11:51 AM
X3emist's Avatar
X3emist X3emist is offline
Mein Auto: 06 X3 Sport
I don't think it is sticking
Usually when this thing goes I thought it was the tubes/hoses that crack and develop a leak.
2006 X3 Silver Grey/Black Lthr/Alum Trim/Sport Prem Pkg/Xenons/Servotronic/Prem Sound/Satellite Radio/Heated Seats/Carbon Fiber Pillars/Blue Tooth/Aux In/Cargo Net/Aluminum Pedals/V1 Hardwired
[SIGPIC]
Old 03-20-2011, 04:32 PM
szee1 szee1 is offline
Mein Auto: 2 2004 X3's
Quite a bit of smoke can go with a CCV failure but it seems odd that none of the other symptoms (rough idle and check engine light) are present. The CCV is a overly complicated PCV valve and can allow the engine to ingest oil which can be surprising. Mine suffered from the hole in the hose failure which on occasion would do the oil smoke trick, and once repaired never exhibited the smoke scare again.
Old 03-21-2011, 07:35 AM
starting issue...
I wonder if the oil smoke/potential CCV issue had anything to do with the low battery. My wife tried to start the car earlier in the day and couldn't get it to crank. I don't know how much effort she put into it, but the car sat in the driveway until the next day when I went out to start it (and that's when I noticed the startup smoke). It did take quite a bit of cranking before it started....
Long story short, a new battery has been installed and I'm keeping a close eye on the oil level and exhaust pipes. I will say cudos to BMW on the OEM battery....it was the original, in service since late 2004.
Old 03-21-2011, 11:00 AM
timarnold timarnold is offline
TA
Mein Auto: 2003 bmw 525i 2005 X3
This actually doesn't sound like the CVV. I have had the same condition occur once before on my X3 (2005 3.0L). It seems like under the right set of circumstances, one of which is moving the car a very short distance. In my case it was backing the car out of the garage to wash it and then pulling it back in. The next time we tried to start the car, it wouldn't start. I pulled the plugs & it was very obvious that it was incredibly flooded. I used compressed air to blow out the cylinders & with a lot more cranking was able to get it started.
When it started, there was a huge cloud of smoke, but it did very much have a gasoline smell rather than an oil smell. As I said, it happened once & never has repeated.
I assume there is some glitch in the FI software. Interestingly, I have had the same thing happen to my Volvo 850 & my E36 over the last 6 years.
Old 11-07-2012, 04:12 PM
codog2 codog2 is offline
Mein Auto: 5
Yes my 05 has done the same thing like 3 times since I've had it. Every time it is after a short start and stop and sit. Like moving the car from the driveway into the garage and then having it sit overnight. I believe it is somewhat common.
Every time it goes away if I stop and restart. Once I had to wait 30 minutes before it would restart
A lot of shaking, white smoke and rotten egg smell. The check engine light usually comes on too
Old 11-08-2012, 09:32 AM
halltristan's Avatar
halltristan halltristan is offline
Bimmer Enthusiast
Mein Auto: 325i and X3
The easiest way to know whether or not you have a CCV problem is to take a piece of paper and hold it over your oil filler (with the cap removed obviously) while the engine is running. If there is a lot of suction, your CCV is failing. A little suction is normal, but if it tries to swallow the paper, you have a bad CCV. Try this and report the results.
Note: Some people say to use a plastic bag, which I don't recommend simply because you might actually suck it into your engine and then you're really screwed!
In response to the other things you've mentioned, a low battery can cause rough idling but it would have absolutely nothing to do with the smoke. One other thing you need to pay attention to is the way the exhuast smells. When my CCV went out the exhuast smelled like old/bad gasoline. I actually replaced the fuel filter at first thinking I had just got some really bad gas.
Member No. 470379
Old 11-08-2012, 10:01 AM
Mein Auto: 5
check this thread
http://www.bimmerfest.com/forums/sho...993&highlight=
supercourse had a good explanation of "flooding the engine"
Old 11-08-2012, 07:50 PM
chewchewone chewchewone is offline
Mein Auto: X3
when I remove my oil cap, the engine shakes, is this normal? Sorry totally different subject.
Old 11-08-2012, 08:32 PM
Bimmer Enthusiast
Can you make a video and post it? This could be serious or it could be nothing.
Member No. 470379
Old 11-08-2012, 09:01 PM
x3brian x3brian is offline
Mein Auto: X3
No that isn't normal. I would bet money on ccv or disa hoses need to be replaced.
Old 11-08-2012, 09:46 PM
Supercourse Supercourse is online now
Mein Auto: 2004 X3 2.5i
Revs are going down because you have introduced a vacuum leak in what is essentially a sealed system.
Air from the removed filler cap will be drawn into the the intake without being metered by the MAF.
(In other engines that use a MAP instead of a MAF, the MAP compensates and the idle speed will be stable or even increase when the oil filler cap is removed.)
In most cases I wouldn't expect the idle to go down enough that the engine shakes and wants to stall.
Might be indicative that a slightly rough idle already exists because of some issue.
Not sure if all M54 and N52 engines should have the same idle speed, whether Auto or Manual?
Mine seems consistent at 800.
