E46 (1999 - 2006)
Old 11-08-2012, 08:16 PM
chilo746 chilo746 is offline
Mein Auto: 2002 525 BMW
2004 330ci
My BMW is really acting up. Turn on car it idles really rough some lights on the dash turns on while idling bad, like if shutting down black smoke comes out and if I try to give it gas it dies out, starts back up and it cranks for longer than usual, replace the MAF sensor, throttle body, and still the same does it need to be reprogram the ecu???
Old 11-08-2012, 08:41 PM
halltristan's Avatar
halltristan halltristan is offline
Bimmer Enthusiast
Mein Auto: 325i and X3
Have you checked the battery? Same symptoms happened to me recently with a near dead battery. If that isn't the case, you need to pull a couple plugs and see if they've been flooded.
Member No. 470379
Old 11-08-2012, 09:40 PM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
Using the SEARCH function, read up a bit on what happens when your CVV is failing.....that`s one strong possibility, especially if the plugs are oily.
The road goes ever onward....
(R.I.P. Jever)
Old 11-08-2012, 09:48 PM
Yes the battery is new And spark plugs are not flooded but they are really black
Old 11-08-2012, 10:21 PM
Plugs are not oily
I'm guessing about the programming the ecu?
Battery is new, spark plugs, starter, engine mounts,
Old 11-08-2012, 10:37 PM
heztheone heztheone is offline
Mein Auto: ///M
what about fuel filter, air filter and alternator?
Give a man a fish and you feed him for a day. Give a man a Chef and he feeds him for a lifetime
Old 11-09-2012, 12:24 AM
Fast Bob's Avatar
Keeping it surreal
Plugs are not oily
Black plugs means they`re being fouled by oil....a "normal" plug color is greyish-tan.
(R.I.P. Jever)
Old 11-09-2012, 03:18 PM
Mein Auto: '04 330Ci 6-speed
Plugs are not oily
Keep guessing rather than listening to and responding to the advice you already got here from someone who knows years more than you do about e46's when he says to consider the CVV.
Old 11-10-2012, 05:27 AM
Mein Auto: ///M
easy on the new guy
OP, ur ECU does not need reprogramming, it has nothing to do with it. if the symptoms u posted are exactly what's happening, check the troubleshooting provided below. and get the car scanned, there might be some codes.
report back when u have further details to go from there
Old 11-10-2012, 10:48 PM
Originally Posted by heztheone View Post
easy on the new guy
Why, is he nine years old? Or English is his second language?
