E60 (2004 - 2010)
Old 11-07-2012, 06:04 PM
bearofkratos bearofkratos is offline
Mein Auto: f150
no cluster after battery install
okay i have been messing with this for about a week now. 2004 530i had a dead battery we jumped it and all the gauges ,power doors and locks worked until the car started. replaced battery now have no power windows,doors,cluster,ac .. but radio turns on and won't turn off even with key out.
Old 11-08-2012, 04:25 PM
w5lx's Avatar
w5lx w5lx is offline
Mein Auto: 2008 528i/2007 328i Coupe
Was the battery replaced by BMW? Was it registered to the car after installation? If not, there are several threads about problems of this kind after do-it-yourself battery installation that may be of help.
Old 11-08-2012, 06:21 PM
Mein Auto: f150
no it was not installed by bmw, i installed it. the cluster worked on the dead battery if had jumper cables hooked up. now with the new battery it only starts. i had searched for a cuouple hours on the other "threads" and found nothing towards a resolution
Old 11-08-2012, 10:00 PM
sw20 sw20 is offline
Mein Auto: 330xi
What kind of battery did you replaced it with? Same cold cranking amp or bigger?
If you put anything smaller the computer will turn off electronics.
Old 11-08-2012, 11:45 PM
Gustavoerod's Avatar
Gustavoerod Gustavoerod is offline
Mein Auto: 2006 530i
Take it to get it registered.
Sent from Gus' pad
Old 11-09-2012, 03:38 AM
z0lt3c's Avatar
z0lt3c z0lt3c is offline
what does this button do?
Mein Auto: 08 535xit
Was the old battery tested and found to be bad. Sounds more like a bad IBS then battery. I would have the car scopes for faults.
z0lt3c
Current:
2013 Ford Edge SEL AWD
2012 Jeep Grand Cherokee Laredo 4x4
Retired:
95 e36 M3/5spd, 96 328is/5spd, 97 540iA, 98 528iA, 01 X5 4.4iA, 03 325xiA, 04 530iA, 02 330Cic/5spd, 08 535xit
Old 11-09-2012, 06:22 AM
pcy pcy is offline
Mein Auto: '06 530i, '07 C280, ML320
^ I concur with the above post.
For this kind of problem, rather than guessing and replacing parts, I'd pay the diagnostic fee and let a competent mechanic/dealer find the root cause of the problem.
